My internet plan advertises much higher speeds than what I’m seeing on every WiFi speed test I run. I’ve tried multiple devices, different rooms, and even restarting the router, but the results are still way below the promised Mbps. I’m not sure if it’s my router, my ISP, network congestion, or something in my home setup. What steps can I take to accurately test my WiFi speed and figure out what’s causing the slow results, and how do I know if my ISP is actually at fault?
Your WiFi speed tests rarely match the number on the ISP ad, and there are several concrete reasons for that. Here is what I would check and do.
Understand what your plan number means
• ISPs quote “up to” speeds. That is the maximum under ideal conditions.
• The speed is also for wired, not WiFi. Over Ethernet to the modem or router, not through walls.
• If you pay for 300 Mbps and see 230 to 280 Mbps on a wired test, the ISP is usually within spec. -
Test it the right way first
• Plug a laptop directly into the modem or router with an Ethernet cable.
• Turn off VPN, downloads, cloud sync, streaming, game updates.
• Run several tests on fast.com and Ookla.
• If wired speeds are close to your plan, the problem is WiFi, not the ISP line.
• If wired speeds are way low, report it to your ISP as a line issue. -
WiFi limits and your devices
• Old laptops and phones often only support 2.4 GHz and older WiFi standards.
• 2.4 GHz is slower and more crowded. Use 5 GHz or WiFi 6 if your router and device support it.
• Some devices top out at 50 to 100 Mbps even if your plan is 500 Mbps or 1 Gbps.
• Check the WiFi specs of your phone or laptop model. Many users miss this and blame the ISP. -
Placement and interference
• Put the router in a central open spot, not in a cabinet or behind a TV.
• Thick walls, metal, mirrors, and floors all weaken signal.
• Neighbor WiFi, cordless phones, baby monitors, and microwaves interfere, especially on 2.4 GHz.
• If far rooms show poor speeds, that is normal for a single router in a large home. -
Router quality and settings
• ISP combo modem routers are often weak. A decent separate router helps a lot.
• Make sure you use WPA2 or WPA3, not old WEP or “open” modes.
• Turn off old legacy modes if you never use old devices. That forces faster standards.
• Reboot helps sometimes, but a bad or old router firmware limits throughput all the time. -
Network congestion inside your home
• If someone is streaming 4K, someone else is gaming, and backups run, your test will drop.
• A 200 Mbps plan split across 10 devices will not give each one 200 Mbps.
• Run tests when nobody else is using bandwidth to see the real maximum. -
Use a WiFi analysis tool
• To avoid guessing about channels, signal strength, and dead zones, use a survey tool.
• NetSpot is popular for this. You install it on a laptop, walk around your place, and it maps signal strength, channels, and problem spots.
• Check out analyzing and improving your WiFi coverage to see which rooms are weak, which channels are crowded, and where you need a better router or mesh node.
• This helps you pick better 2.4 GHz and 5 GHz channels and place your access points more effectively. -
When to blame the ISP
• After you test wired, multiple times, at different times of day.
• If you pay for 300 Mbps and wired tests show 50 to 70 Mbps regularly, note dates and screenshots.
• Call support, tell them your wired results, and ask them to check signal levels and node congestion.
• If they refuse to fix it or it stays low, consider a different provider if you have that option.
If you go step by step like this, you find where the bottleneck is. Many times it ends up being WiFi limits, device limits, or bad placement, not the ISP line itself.
Your plan says one thing, your WiFi tests say “lol nope” – super common.
@mike34 covered the basics really well (wired vs WiFi, “up to” marketing, old devices, etc.), so I’ll hit some different angles and push back on a couple of points.
1. The ad number is not the speed you see on one device
The big number from your ISP is:
- Total shared bandwidth to your home
- Measured in ideal lab-ish conditions
- Often rounded up and marketed aggressively
So your 500 Mbps plan does not mean your phone in the bedroom should see 500 Mbps over WiFi. That’s your whole pipe, before WiFi overhead, before multiple devices, before distance and walls.
Where I disagree a bit with the “if you get 230–280 on 300 Mbps you’re fine” line from @mike34: if you consistently get ~70–80% of the advertised speed on a quiet wired test at all hours, I’d still push the ISP. Many ISPs overprovision slightly so you should sometimes see above-plan bursts on wired.
2. The speed test itself can be lying to you
Not all tests are equal, and not all servers are equal:
- Some speedtest servers are overloaded. One bad server makes your connection look slow.
- Some tests use TCP only, some use multiple streams; results can differ 20–30%.
- Browser extensions, ad blockers, or VPN plugins can throttle or mess with tests.
Try:
- 2–3 different test sites
- 3–4 different test servers within the same app
- Both browser-based and app-based tests if possible
If one server always looks terrible and others are fine, your line is probably fine and the test server is trash.
3. WiFi overhead & real‑world loss
Even in perfect conditions, WiFi will not hit the raw link speed:
- A 433 Mbps WiFi link speed in your device settings often means ~200–250 Mbps real throughput at best.
- Every packet has overhead, plus WiFi is half‑duplex (can’t send and receive at the same time on one channel).
- Add encryption overhead, retries due to interference, and latency from buffers.
So if you have a 300 Mbps line and your phone’s link speed is showing 144 Mbps on 2.4 GHz, seeing 70–100 Mbps in a test is actually expected behavior, not a failure.
4. Hidden bandwidth hogs you may not be seeing
Even if you “made sure no one was using the internet,” stuff might still be pulling data:
- Cloud backup (OneDrive, iCloud, Google Drive, Dropbox)
- Game launcher updates (Steam, Battle.net, Epic, console updates)
- Smart TVs doing auto updates or “phone-home” telemetry
- Security cameras uploading video to the cloud continuously
Open your router’s device list and real-time bandwidth graph if it has one. You might find a random TV or camera eating 20–40 Mbps constantly.
5. Router CPU & bufferbloat: the silent killers
One piece most people miss: the router’s processing power.
- Cheap or old routers choke when you have many connections (smart devices + phones + tablets + consoles).
- Some can technically do “up to 1 Gbps” on the box, but only with hardware acceleration and minimal features turned on. Turn on QoS, parental controls, traffic analysis, and the real throughput can drop hard.
Also, bufferbloat:
- When your upload or download queue fills up, latency spikes like crazy and everything feels slow.
- Your speed tests might still show decent numbers, but your real experience (streaming, gaming, browsing) feels awful.
- You can test this specifically at waveform.com’s bufferbloat test.
If bufferbloat is bad, enabling a good “smart queue” QoS or CAKE / FQ_CoDel on a more advanced router can make your connection feel much faster without changing the plan.
6. Channels and neighbors: WiFi spectrum is a warzone
Everyone in your building or street is blasting WiFi on the same small set of channels. Especially on 2.4 GHz, the usable non‑overlapping channels are basically 1, 6, and 11.
Instead of guessing, this is where NetSpot is actually useful:
- Install it on a laptop
- Walk around your place
- See which channels your neighbors are using, how strong their signals are, where your own dead zones are
That lets you:
- Pick a less crowded channel
- Decide if you need a mesh system or another access point
- Confirm if that “one weird room” is just too far or blocked by concrete/metal
If you’re serious about fixing WiFi performance, using something like a professional WiFi analyzer for better coverage beats random router reboots by a mile.
7. Your device’s WiFi chip might just suck
Not all WiFi chips are equal:
- Cheap phones, smart TVs, and some laptops have 1x1 stream radios that cap at 72–150 Mbps link speed.
- Older WiFi 4 / WiFi 5 cards might never use wider channels or higher MCS rates in noisy environments.
- Some budget laptops have truly awful antennas; standing 3 feet from the router still gives bad performance.
So if your fancy speed test on your gaming PC via Ethernet shows 400–500 Mbps but your TV and old tablet show 40–60 Mbps, that’s not “ISP scam,” that’s “device limitation.”
8. When the ISP actually is the problem
After all that, it can still be the ISP:
- Evening slowdowns at the same time every day suggest node congestion.
- Big difference between off‑peak (like 3 AM) and peak tests on wired is a red flag.
- Repeated tech visits blaming “inside wiring” when your internal tests look fine is a classic dodge.
If your wired tests are consistently way below plan at different times of day, and you’ve ruled out your gear, document:
- Date and time of each test
- Speed test results
- Whether it was wired or WiFi
Then open a ticket, escalate if needed, and if they won’t fix it, vote with your wallet if you have another provider.
SEO‑friendly version of your issue
Why is my WiFi speed test much slower than my internet plan?
My ISP advertises high download speeds, but every WiFi speed test I run on different devices and in different rooms shows much lower results. I’ve already restarted the router and checked multiple times, yet my actual wireless speeds are still far below what I’m paying for.
If you want to narrow this down fast:
- One wired test to the modem/router.
- One WiFi test right next to the router on a modern phone or laptop.
- Run NetSpot or another analyzer to see how bad congestion / signal is.
Those three will usually tell you exactly where the bottleneck lives.
You’ve already covered testing, interference, and device limits. Try changing the router’s location before buying equipment.
Move your router onto an open shelf, closer to the center of your home. Keep it out of cupboards and away from metal furniture. Google recommends central, open placement for better coverage. (blog.google)
Take a speed reading before moving it, then repeat from the same device and spot afterward. Keep a seperate note of each result, and dont change other settings during the comparison. If speeds improve, keep the new position.
Watch out for range extenders if you’ve got one plugged in. A basic single-band repeater roughly cuts your throughput in half, because it talks to the router and to your device on the same radio and has to take turns. People stick one in a hallway to kill a dead zone, then run a test in that room and panic at the low number. If that’s your setup, wired backhaul or a real mesh node solves it. Another cheap repeater just stacks the problem.
The thing nobody flagged in all the channel and wall talk: if your 2.4 and 5 GHz share one network name, your phone tends to cling to 2.4 GHz long after it should have hopped to 5. Walk out of the house, come back, and it’s still glued to the slow band while you swear you’re standing next to the router. For testing, split them into two named networks and connect directly to the 5 GHz one. That alone clears up a lot of the ‘slow even up close’ confusion, and it costs nothing.
On the analyzer people keep pointing to, NetSpot, the crowded-channel graph gets all the love, but that’s not the part I’d lean on. Look at signal to noise, not the raw signal bars. You can be sitting on a strong signal that still performs like garbage because the noise floor around it is high, and moving to a ‘less busy’ channel does nothing if the noise follows you. The SNR reading is what tells you whether a channel change is actually worth doing or just theater.
One realistic expectation to set: a phone speed test is a mediocre measuring stick. Phone radios throttle, background apps chew bandwidth, and the app itself picks whatever server it feels like. If you want a number you can trust for comparing before and after any of these changes, use a laptop, close to the router, on 5 GHz, wired result noted first as your baseline. Everything else is guessing with extra steps.
