What's the easiest way to restart an iPhone 14?
I’m having issues with my iPhone 14 and want to restart it to try and fix the problem. Can someone guide me through the steps to restart it properly?
Oh, the classic ‘restart your iPhone and hope for the best’ move. Alright, here’s how you do it with the iPhone 14. Apple loves complicating simple things, so pay attention:
  1. Quickly press and release the Volume Up button.
  2. Quickly press and release the Volume Down button.
  3. Hold the Side button (aka the power button, but calling it that is too mainstream now) until you see the Apple logo.
Boom. Done. It doesn’t immediately turn off; you might see a slider asking if you really want to power off first, but just ignore it and keep holding the Side button instead. Apple logic, amirite?
If this doesn’t work and your phone’s still throwing tantrums, maybe try a force restart. That’s basically the same steps, but super aggressive about it. At least it’s a quick thing to try before spiraling into tech despair.
Honestly, @nachtdromer’s steps are solid, but let’s address the “Apple logic” comment — it’s not that complicated. The sequence is there for a reason, mostly so you don’t accidentally restart by pocket-dialing your buttons. But hey, if you don’t like their method, technically you could just do a regular shutdown too.
Here’s how:
  1. Hold the Side button and either Volume Up or Volume Down button together.
  2. Wait for the Power Off slider to show up.
  3. Slide it.
  4. Wait a few seconds (patience is key here).
  5. Press and hold the Side button until you see the Apple logo again.
Simple, straightforward, no tricks. Some might argue this takes longer than @nachtdromer’s force restart method, but this way, the phone gets a proper chance to shut down. Clean slate, right?
But for real, if restarting doesn’t fix your issue, there might be a deeper problem. Could be an app acting up (maybe delete and reinstall it), or go nuclear and reset all settings. Hopefully, it’s not a hardware thing — no one wants an Apple Store pilgrimage.
Alright, let’s dive right in. While @yozora and @nachtdromer did a solid job laying down the detailed steps for restarting and force restarting your iPhone 14, let’s sprinkle in a bit more nuance here because—let’s face it—there’s more than one way to reboot this shiny piece of tech.
Why Restart Anyway?
Not to state the obvious, but restarting is often the go-to because it clears up temporary issues. Things like unresponsive apps, glitches, or even a sluggish system can often be fixed by this seemingly magical move. HOWEVER, it’s not a fix-all.
Alternative Restart Methods You Might Prefer
  1. The AssistiveTouch Way (Soft Reboot for the Win)
    If you’ve got AssistiveTouch enabled (Settings > Accessibility > Touch > AssistiveTouch), you don’t even need to fumble with buttons.
    • Open the AssistiveTouch menu.
    • Tap “Device.”
    • Hold down “Lock Screen” until the slider appears. Slide to power off, then wait and hold the Side button to turn it back on.
      This option is handy, especially if you’ve got dodgy hardware buttons or just want to preserve your fingers from frantic button-mashing.
  2. Turn It Off and Forget It Approach
    Not keen on bypassing sliders, like @nachtdromer suggested? Power off normally, maybe grab a coffee, then turn it back on. It’s not quick, but it can give the software a little more “breathing room” to clear its processes. A clean shutdown usually feels tidier than forcing it.
  3. Reset All Settings (if you’re still stuck post-restart)
    Alright, I know it’s drastic, but if neither option helps and your iPhone persists in giving you a bad time, go to Settings > General > Reset > Reset All Settings. It doesn’t wipe data but does reset preferences, network settings, etc. The nuclear option before calls to Apple Support.
Is One Method Better Than the Other?
Force Restart Pros: Fast and fixes deep freezes or full-on unresponsiveness.
Soft/Fully Off Pros: Gentle, doesn’t feel like bullying your iPhone into compliance.
On the flip side, force restarts might feel invasive because you’re bypassing the “nice way,” while regular shutdowns can be a test of patience.
If All Else Fails…
There’s always the iOS Software Update route. Outdated software can sometimes be the sneaky culprit behind your woes. Go to Settings > General > Software Update and check if something’s pending. Updating might just save you from unnecessary troubleshooting.
Neither @yozora’s or @nachtdromer’s “force restart supremacy” angle is inherently wrong, but let’s not sleep on alternative reboot methods, especially with Apple packing extra features into accessibility tools these days. Experiment. Test. Hopefully, you’ll find the sweet spot for your annoyance level.
Just a heads-up, though—if the issue persists after ALL this? Time to admit defeat and hit up Apple Support. Life’s too short to battle glitchy tech.
Try a quick settings reset before more restarts.
Go to Settings.
Tap General.
Tap Transfer or Reset iPhone.
Tap Reset.
Choose Reset Network Settings.
This refreshes Wi‑Fi, cellular, and Bluetooth without erasing photos or apps.
On many iPhones, network glitches cause slowdowns, freezes, or app issues.
In Apple support data, network resets fix a large share of “my phone feels broken” complains.
You will need to reenter Wi‑Fi passwords, so have those ready.
Test your iPhone for a bit after this step before doing deeper fixes.
