What’s the best Wi‑Fi router for a crowded home network?
I’m looking for recommendations on the best Wi‑Fi router for a busy household with lots of devices streaming, gaming, and working from home. My current router keeps dropping connections and speeds tank in the evenings. What models or features should I look for to get a reliable, fast network that can handle multiple users without constant lag or disconnects?
Short version before the nerdy bit.
For a crowded home with streaming, gaming, WFH and constant drops, look at:
  1. TP-Link Deco XE75 (Wi-Fi 6E mesh)
  2. ASUS RT-AX86U Pro (Wi-Fi 6 single router)
  3. TP-Link Archer AX75 (budget Wi-Fi 6)
Pick mesh if you have a larger place or walls. Pick a single high-end router if your place is small or you can put it in a central spot.
Longer breakdown.
  1. Decide if you need mesh or a single router
    If you have any of these:
• Two floors or more
• Thick walls or weird layout
• Router stuck in a corner from your ISP modem
Then go mesh. One router in a bad spot will always choke in the evenings when everyone hits it at once.
Good mesh option for busy homes:
• TP-Link Deco XE75 (3-pack)
  • Wi-Fi 6E, so you get 2.4 + 5 + 6 GHz
  • Backhaul on 6 GHz helps a lot when multiple people stream and game
  • Easy app setup
  • Handles 40 to 100 devices without freaking out if you configure it right
If your place is smaller, like apartment or small house, go with one strong router.
  1. Strong single router picks
    • ASUS RT-AX86U Pro
  • Wi-Fi 6, very solid CPU
  • Handles gaming, Zoom, and streaming at the same time without bufferbloat going crazy
  • Good QoS options, you can prioritize work laptop or gaming PC
  • ASUS firmware has more tuning options than typical ISP routers
• TP-Link Archer AX75
  • Cheaper than ASUS
  • Tri-band Wi-Fi 6
  • Enough for 20 to 40 devices if placed well
  1. Fix the usual bottlenecks
    New router helps, but you should also do this:
• Turn off your ISP router Wi-Fi and run your new router or mesh in router mode or AP mode
• Use Ethernet for anything that sits still
  • Gaming PC or console
  • Smart TV
  • Work desktop or dock
    Wired devices free up air time for phones and tablets.
• Use 5 GHz as default. Keep 2.4 GHz only for smart plugs, bulbs, random IoT.
• Name your 5 GHz and 2.4 GHz differently so you force important stuff on 5 GHz.
Example
  • Home_5G
  • Home_24G
  1. Use NetSpot to avoid channel conflicts
    Crowded home networks often suffer from neighbor Wi-Fi overlap. A strong router on a bad channel still sucks.
Install NetSpot on a laptop and walk around your home. With NetSpot Wi-Fi analysis and planning you see:
• Which channels your neighbors use
• Where signal drops in your rooms
• Which spots need a mesh node or a repositioned router
Pick cleaner channels on 2.4 and 5 GHz based on what NetSpot shows. Move your router or mesh nodes to spots where it shows better coverage. That gives more stable speeds in the evening when everything is busy.
  1. Concrete setups that work well
Small place, under about 1,500 sq ft
• ASUS RT-AX86U Pro in a central spot
• Wired where possible
• Use NetSpot once, tune channels and placement
Medium to large place, 2 floors or bad layout
• TP-Link Deco XE75 3-pack
  • One near modem
  • One roughly central downstairs
  • One upstairs, near bedrooms or office
    • Use Ethernet backhaul if you have any existing runs
    • Use NetSpot to verify coverage and adjust node placement
If your current router is older than 4 to 5 years or only does Wi-Fi 4 or Wi-Fi 5, upgrading to any good Wi-Fi 6 or 6E unit plus a quick NetSpot survey will make evenings a lot less painful.
Best router kind of depends on what’s actually killing your network: coverage, congestion, or the router’s brain melting under load. Since @boswandelaar already hit the “what to buy” list pretty hard, I’ll come at it from a slightly different angle and disagree on a couple of things.
1. Don’t just throw hardware at the problem
People love to jump straight to “buy Wi‑Fi 6E mesh.” Sometimes that helps, sometimes it just gives you a more expensive way to still have crappy Wi‑Fi.
Your current router dropping connections and tanking at night usually means:
  • Too many devices for its CPU/RAM
  • Terrible placement (corner, cabinet, behind TV)
  • Channel chaos with neighbors
  • Bufferbloat when everyone is streaming + gaming + Zoom
So yeah, new router, but also fix the basics while you’re at it.
2. Router picks that actually hold up under load
If you want concrete models beyond what’s already mentioned:
If you want a single beast router (small to midsize home):
  • ASUS RT-AX88U Pro
    Similar league to the RT-AX86U Pro that @boswandelaar mentioned, but with more LAN ports and very solid QoS. Great for:
    • Multiple work-from-home setups
    • Gaming + Discord + streams
    • Lots of smart home junk
  • Ubiquiti UniFi Express + separate modem
    Little more nerdy, but rock solid once configured. You get:
    • Very stable firmware
    • Great traffic stats
    • Proper separation of guest / IoT networks
If you really do need mesh (bigger place or bad walls):
I actually don’t love going all‑in on 6E mesh unless you know your devices can even use 6 GHz. Often they can’t.
  • TP-Link Deco X50 or X60 (Wi‑Fi 6 mesh)
    • Cheaper than XE75
    • Good enough for a ton of devices
    • Mesh backhaul on 5 GHz is fine for most homes
  • ASUS ZenWiFi XT8
    • Better controls than most mesh systems
    • Good for people who want to tweak more than the average user
If your ISP speed is under ~500 Mbps, you really don’t “need” 6E yet. Coverage and stability > theoretical max speed.
3. Where I slightly disagree with @boswandelaar
They’re right about mesh for multiple floors, but I’d add:
  • If your router is on the same floor as most users and you can move it somewhere central, try a single strong router first.
  • Mesh adds more nodes to manage and more RF noise. In small places, that can actually hurt performance.
Also, I don’t love the “name 2.4 and 5 GHz differently” advice in every case. For non-techy households it just confuses everyone. I’d do this instead:
  • Keep one SSID for 2.4 + 5 GHz for phones / laptops
  • Make a separate SSID just for IoT (2.4 GHz only if needed)
  • Put plugs, bulbs, random cameras on that IoT SSID
Cleaner and you can throttle or isolate IoT if needed.
4. Fix your evening slowdowns properly
New gear helps, but this part is what actually stops the nightly slowdown:
  1. Enable smart QoS or adaptive QoS
    • Prioritize work laptops and gaming
    • De‑prioritize 4K YouTube on the TV in the background
  2. Wire anything that doesn’t move
    • Consoles, desktops, TV, streamer box
    • Use a cheap gigabit switch if you run out of ports
  3. Don’t run double NAT if you can avoid it
    • Put ISP modem/router in bridge mode
    • Let your new router be the only router
  4. Pick cleaner Wi‑Fi channels with NetSpot
    This is the part people skip and then complain the new router “isn’t better.”
    Install NetSpot on a laptop and walk around the house. With it you can:
    • See which channels your neighbors are spamming
    • See where your signal actually sucks
    • Decide if you really need a second node, or just a better location
    Then go into your router’s settings and manually set channels based on what NetSpot shows. That alone can make your evenings way smoother.
If you want a more detailed guide, check out advanced Wi‑Fi network tuning with NetSpot. It’s way more helpful than just blindly swapping routers.
5. TL;DR setups that actually work
  • Small apartment, under ~1,400 sq ft, single floor
    • ASUS RT‑AX88U Pro in the most central, open spot you can manage
    • QoS on, ISP router in bridge mode
    • Run NetSpot once, fix channels
  • Two floors or awkward layout
    • 2 or 3‑pack TP‑Link Deco X50 or X60
    • Nodes on each floor, roughly central, not in closets
    • Use Ethernet backhaul if you have even a single cable run
    • Tune channels with NetSpot, don’t just trust “auto”
If your current router is more than 4–5 years old, Wi‑Fi 4/5 only, or the free box from your ISP, it’s almost certainly the bottleneck now. Upgrading to a good Wi‑Fi 6 router, plus doing the channel and QoS tuning with NetSpot, is usually what finally kills the evening slowdowns.
If your evenings feel like Wi‑Fi rush hour, I’d look at the problem slightly differently from @espritlibre and @boswandelaar and start with capacity planning before picking hardware.
1. Start with your internet line, not just Wi‑Fi
If your ISP line is, say, 200 Mbps and you have 4K streaming, multiple Zoom calls and gaming, you can absolutely saturate the WAN, no matter how fancy the router. In that case:
  • Upgrading to a faster plan often has more impact than jumping from Wi‑Fi 5 to high‑end Wi‑Fi 6E.
  • A good router then makes sure that bandwidth is shared sanely.
Their hardware picks are solid, but you’ll only feel the full benefit if the WAN is not pegged at 100% most evenings.
2. Think in “client types,” not only number of devices
Crowded homes are not just “40 devices.” You have:
  • Latency‑sensitive (gaming, calls)
  • Throughput‑hungry (4K streaming, large downloads)
  • Burst / chatty (smart home, phones syncing)
Look for routers or mesh systems that have:
  • Configurable QoS per application or device group
  • Ability to create multiple SSIDs / VLAN‑like segmentation (e.g., main, work, kids, IoT)
On this front, ASUS (RT‑AX86U Pro, RT‑AX88U Pro) and UniFi gear that @espritlibre mentioned are strong, but you can also look at:
  • MikroTik hAP ax³ if you are comfortable with slightly more advanced config. Great CPU, superb control, less “pretty” UX.
3. Where I really diverge: Mesh as a last resort, if you can pull cable
Both others leaned reasonable amounts on mesh. I’d tighten that a bit:
  • If you can run a single Ethernet cable to the far side or upper floor, I strongly prefer:
    • One central main router
    • One or two wired access points (can be cheap Wi‑Fi 6 APs)
You avoid wireless backhaul overhead and interference from multiple mesh radios. For a very busy home, wired APs often win over wireless mesh, even if the spec sheet of the mesh looks shinier.
4. NetSpot vs other survey tools
Since both already mentioned tuning channels, I’ll focus on NetSpot itself:
Pros of NetSpot
  • Very clear visual heatmaps, easy to show “look, this room is red” to family members.
  • Good for seeing overlaps and channel congestion.
  • Helpful when placing APs or mesh nodes, especially in multi‑floor setups.
  • Works well for both quick checks and more detailed planning.
Cons of NetSpot
  • Desktop based, so less convenient than a lightweight phone app if you just want a fast peek.
  • Can feel like overkill if you just have a small flat and one router.
  • The learning curve for all its features is a bit higher than some simpler mobile analyzers.
Competitor tools / approaches
  • Wi‑Fi Analyzer–style phone apps are faster to launch but usually weaker on the planning side.
  • Some router vendors bundle basic spectrum / channel views in their firmware, but it is usually far less detailed than NetSpot and not ideal once you add multiple APs.
I personally use NetSpot when I am doing a “one‑time proper survey” and a lighter Android/iOS analyzer for quick, casual checks.
5. Concrete “crowded home” setups that avoid your current issues
Trying not to repeat their lists, here are alternative archetypes:
  1. Small apartment, high device density, many calls & gaming
    • 1 × high‑end Wi‑Fi 6 router (ASUS RT‑AX88U Pro or MikroTik hAP ax³).
    • QoS tuned so that game consoles and work laptops have higher priority than TVs.
    • One SSID for people, one for IoT.
    • Use NetSpot once to find the least abused 5 GHz channel and to confirm no room is a dead zone.
  2. Medium house, 2 floors, can run at least one cable
    • 1 × strong router near the modem on ground floor.
    • 1 × Wi‑Fi 6 access point upstairs, wired back to router.
    • NetSpot to decide exact AP location and confirm overlap is enough for smooth roaming, but not so much that channels fight each other.
    • This avoids some of the wireless‑mesh overhead that can bite in very busy homes.
  3. Large or “weird” layout, no cabling possible, many simultaneous streams
    • OK, this is where Wi‑Fi 6 mesh like Deco XE75, X60 or ZenWiFi XT8 shines as others suggested.
    • I’d still use NetSpot to decide node placement and to verify the backhaul links are strong, rather than just trusting the app’s “looks good” indicator.
6. Last bit: Stability beats theoretical speed
Both @espritlibre and @boswandelaar are right that routers from the ISP or 4+ year old Wi‑Fi 5 boxes choke under modern load. Where people get disappointed is when they upgrade to a beast router, keep bad placement, ignore QoS and never run any survey tool.
If you:
  • Put a capable Wi‑Fi 6 router in the most central open location you can manage
  • Wire what you can
  • Spend 30–45 minutes once with NetSpot to map coverage and optimize channels
  • Turn on sane QoS and avoid double NAT
then even a “midrange” router will feel like a huge upgrade and the evening slowdowns should mostly disappear.
