Should I choose MP3 or FLAC for my music library?
I’m rebuilding my entire music library and I’m stuck between using MP3 or FLAC. I want good sound quality but I’m also worried about storage space and compatibility with my phone and car stereo. Can anyone explain the real-world differences, and which format makes more sense for everyday listening and long-term archiving?
If you’re choosing between MP3 and FLAC, you’re really choosing between convenience and efficiency (MP3) versus perfect preservation (FLAC). Neither is universally “better” – they just solve different problems. Here’s how most audio folks think about it.
Quick explanation: MP3 vs FLAC
MP3 is a lossy format. To reduce file size, it removes parts of the audio that are considered less audible to human ears. That’s why MP3 files can be 5–10× smaller than the original CD audio.
FLAC, on the other hand, is lossless. It compresses audio without removing any data. When decoded, it’s identical to the original recording.
A simple analogy:
  • MP3 = JPEG photo (smaller, some detail removed)
  • FLAC = ZIP file (smaller, but nothing lost)
Where FLAC makes more sense
  1. Building a permanent music library
    If you’re ripping CDs or buying digital music you want to keep forever, FLAC is a very safe choice. You can always convert FLAC to MP3 later, but you can never restore lost data from an MP3.
This is why many collectors keep a FLAC master library.
  1. Archiving and backups
    FLAC is ideal if you care about preserving the original quality. If storage isn’t a big concern, it’s the safer long-term format.
  2. Critical listening setups
    If you’re using good wired headphones, speakers, or a dedicated DAC at home, FLAC ensures you’re getting the full quality of the source. Whether you personally hear the difference is another discussion, but technically nothing is lost.
  3. Editing or production work
    If you plan to edit audio, FLAC is much better than MP3 because lossy compression can introduce artifacts that become more noticeable after processing.
Where MP3 makes more sense
  1. Phones and portable devices
    MP3 still shines when storage space matters. A 10,000-song FLAC library might shrink to 3,000-4,000 songs in MP3 at high quality.
  2. Streaming or bandwidth limits
    If you’re streaming your own collection or sharing files, MP3 is much easier on bandwidth.
  3. Casual listening
    For everyday listening – especially in cars, gyms, or over Bluetooth – most people won’t hear a difference between FLAC and a well-encoded 256–320 kbps MP3.
  4. Maximum compatibility
    MP3 is still the most universally supported audio format ever made. Basically everything plays it, including very old hardware.
Sound quality: can you actually hear the difference?
This is where expectations often clash with reality.
In controlled blind tests, most people cannot reliably distinguish FLAC from a properly encoded high-bitrate MP3. Differences become harder to detect when:
  • Using Bluetooth headphones (Bluetooth already compresses audio)
  • Listening in noisy environments
  • Using entry-level audio gear
Differences may become noticeable:
  • With very revealing headphones or speakers
  • With trained listeners
  • With certain difficult tracks (complex classical, cymbals, etc.)
  • At lower MP3 bitrates (like 128 kbps)
So from a practical standpoint: a good MP3 sounds very good.
Practical recommendation (what many enthusiasts actually do)
A very common real-world approach:
Use FLAC as your source format
  • Rip CDs to FLAC
  • Buy lossless when possible
  • Store this as your archive
Use MP3 (or AAC) for portable use
  • Convert copies for your phone
  • Use for streaming or sharing
  • Save space where quality differences are minimal
This gives you flexibility without sacrificing quality long term.
So which should you use?
My practical answer:
Choose FLAC if:
  • You’re archiving music
  • You want maximum quality preservation
  • Storage isn’t a big concern
  • You like future-proof formats
Choose MP3 if:
  • You need small files
  • You mostly listen on mobile
  • You want maximum compatibility
  • Convenience matters more than perfection
If you want a simple rule:
If it’s your master copy → FLAC
If it’s for daily use → MP3 is usually fine
Recommended players
If you’re working with both formats, it’s worth using players that handle them smoothly.
On Mac
Elmedia Player
A versatile macOS media player that handles FLAC, MP3, ALAC, OGG, and most other formats without needing extra codecs. It also offers useful features like equalizer controls, audio track selection, and a clean native interface. For people who run into format limits with macOS’s default tools, it tends to make playback much simpler.
QuickTime Player
Apple’s built-in option. Lightweight, stable, and perfectly fine for common formats like MP3. It’s a good starting point, though FLAC users often end up adding a more flexible player.
On Windows
5KPlayer
A player with strong format compatibility including both MP3 and FLAC. It also has some extra features like AirPlay support and media downloading, which some users find handy.
Windows Media Player
The familiar built-in choice. Works well with MP3 and most common formats. FLAC support exists in newer Windows versions, though older systems sometimes need extra setup.
MP3 is about efficiency and convenience. FLAC is about preservation and maximum fidelity. Most experienced users don’t pick just one – they use both depending on the situation.
For what you described, I’d do this:
  1. Decide what you want your “master” to be
    If you still have your CDs or buy downloads, use FLAC for your main library on a PC, NAS, or external drive.
    Reason: once audio is thrown away for MP3, it is gone. FLAC keeps the full signal, so you never need to re‑rip.
Rough size difference per album from real libraries:
• FLAC album: about 300 to 500 MB
• 320 kbps MP3 album: about 100 to 150 MB
So FLAC uses about 2 to 3 times more space.
If you only listen on your phone, in the car, on Bluetooth buds, and you do not care about “future proof”, you can skip FLAC and go all‑in on high bitrate MP3. Many people do and are fine.
  1. Think about your actual listening gear
    From tests and studies:
    • 128 kbps MP3: often audible problems, especially on busy tracks.
    • 192 kbps: good, small issues on some music if you listen carefully.
    • 256 to 320 kbps: most people fail blind tests vs FLAC on normal gear.
In a car with stock speakers or via Bluetooth, 320 kbps MP3 is usually indistinguishable from FLAC. The car noise and Bluetooth compression hide the difference.
With good wired headphones in a quiet room you have a better chance to notice small artifacts. Even then it is subtle at high bitrates.
I slightly disagree with @mikeappsreviewer on one practical point. If you do not enjoy “critical listening” and do not plan any audio editing, FLAC is often overkill for a phone plus car setup. The extra storage and backup hassle might not be worth it for you.
  1. Compatibility with phone and car
    • Phone: Android and iOS both handle FLAC in many apps, but some default players skip it. MP3 works everywhere.
    • Car stereos: many older or basic head units only like MP3 and maybe WMA. FLAC often fails or glitches.
If your car is more than a few years old, assume MP3 for total safety. You do not want to sit in the driveway debugging formats.
  1. Storage planning
    Example with 128 GB phone:
    • System and apps: say 40 GB used.
    • Left for music: 80 to 90 GB.
That gives you roughly:
• FLAC: maybe 250 to 300 albums.
• 320 kbps MP3: closer to 600 to 800 albums.
So decide what hurts more for you, less total music on the phone or some theoretical quality loss you mostly do not hear in a car or on the go.
  1. Simple setup that works well
    Here is a clean, low stress approach.
At home:
• Rip or store everything as FLAC on your main drive.
• Back it up to another drive.
On the go:
• Convert selected albums or playlists to 256 or 320 kbps MP3 for phone and car.
• Sync only what you actually listen to.
This way you get:
• Long term archive with no quality loss.
• Small files and strong compatibility for everyday use.
You do not need anything fancy to play FLAC on a computer. On macOS, Elmedia Player is a solid option that plays FLAC, MP3, and a lot of other formats out of the box and handles libraries cleanly. That helps if the default player complains about FLAC.
  1. If you want a one line decision
    • If you hate the idea of re‑ripping and you have a PC with decent storage, use FLAC for your main library and MP3 copies for phone and car.
    • If you care most about space and zero hassle with compatibility, rip everything straight to 256 or 320 kbps MP3 and be done with it.
Pick based on your real use, not on perfection on paper.
For what you’re describing (phone + car, worried about space), I’d flip the usual “FLAC master, MP3 portable” advice on its head unless you’re sure you care long term.
Couple points where I slightly disagree with @mikeappsreviewer and @viaggiatoresolare:
  1. If you’re not an archivist, FLAC is often just extra chores
    Re‑ripping hundreds of CDs sounds awful, but a lot of people rebuild once, then barely touch that library again. If you:
    • listen mostly on phone / car
    • do not own nice wired headphones or a hi‑fi setup
    • never do audio editing
      then keeping a giant FLAC archive is like using a Blu‑ray collection to watch movies on a 20‑year‑old TV. Technically cool, practically pointless.
  2. Sound quality vs your actual use
    In real life:
    • Car: road noise + mediocre speakers + often Bluetooth. A 320 kbps MP3 is already limited by the car, not the file.
    • Phone: Bluetooth buds, noisy environments. You’re more likely to notice a bad mix than MP3 artifacts.
    • At home sitting quietly with good gear: this is where FLAC maybe wins, and only slightly, and only if you care enough to notice.
    If that last scenario is rare for you, a good 256 or 320 kbps MP3 baseline is honestly fine. Blind tests back that up.
  3. Space and sanity check
    Roughly:
    • FLAC album: ~300–500 MB
    • 320 kbps MP3: ~100–150 MB
    On a 128 GB phone, that difference is brutal. I’d rather carry 600 albums in MP3 than 250 in FLAC and keep deleting stuff every week.
  4. Compatibility reality
    • Phones: both formats are usable, but MP3 is guaranteed everywhere, any app, any OS.
    • Cars: many head units still act like FLAC is an alien format. MP3 just plays.
    Sitting in the driveway fighting your stereo is… not a vibe.
  5. Simple path that matches what you actually do
    If you’re leaning “I just want good sound and no drama”:
    • Rip or download to high‑bitrate MP3 (256 or 320 kbps CBR/CBR‑ish) as your main format.
    • If you later get into nicer gear and really care, you can re‑rip selected favorite albums to FLAC instead of doing the entire collection. Most people’s real “must have in best quality” list is like 50–100 albums, not 1,000.
    That’s the opposite of the “archive in FLAC, transcode down” scheme from @mikeappsreviewer and @viaggiatoresolare, but it fits your current usage better.
  6. Where FLAC actually makes sense for you
    I’d only bother with FLAC if:
    • you already have a decent desktop / laptop with lots of storage,
    • you sometimes plug in real headphones and sit down just to listen,
    • and you enjoy the idea of a “perfect” library.
    In that case, yeah, do FLAC on the computer and MP3 copies on phone / USB stick for the car. On macOS, something like Elmedia Player is nice because it just plays FLAC and MP3 without you chasing codecs, and its library handling is a lot less annoying than some default players.
If you want a brutally simple rule for your situation:
  • Mostly phone + car, hate storage stress: go all‑in on 256/320 kbps MP3 and don’t look back.
  • Only add FLAC for a small set of absolute favorite albums if you later end up with better listening gear at home.
Quick way to un‑stall your decision: separate “archive brain” from “real life listening brain.”
1. Where I actually disagree a bit with others
  • @viaggiatoresolare and @mikeappsreviewer are right about FLAC as a perfect master, but if you are never going to sit and do critical listening or audio editing, a giant FLAC archive can turn into busywork.
  • @himmelsjager is closer to what I see most casual listeners end up doing: high bitrate MP3 and call it a day.
Given you care about phone + car, storage, and compatibility, you can lean more practical than purist.
2. Make one core decision
Ask yourself:
“Am I the type who will be annoyed in 5 years if I know my library is lossy?”
  • If yes, you want some FLAC in the picture.
  • If no, you can safely choose MP3 only.
You are not choosing “good vs bad.” You are choosing between:
  • FLAC: more storage, more future proof, less compatible with old car stereos.
  • MP3 (256/320 kbps): less space, easier everywhere, quality loss that you probably will not hear in car / on the go.
3. A slightly different split that might suit you
Most replies say “FLAC master, MP3 portable.” Let me flip it a bit:
A. Start with high bitrate MP3 for everything
  • Rip to 256 or 320 kbps MP3 and use that for phone and car.
  • See if you actually miss anything.
  • This instantly solves:
    • car stereo playback
    • phone storage
    • easy syncing and copying
If six months later you get nicer headphones or a home setup and start caring more, you can:
B. Upgrade only your favorite albums to FLAC on a computer
  • Take the 30–100 albums you truly love.
  • Re‑rip those to FLAC.
  • Keep them on a PC, external drive, or NAS as a “premium shelf.”
  • Keep using the MP3 versions for phone and car.
This avoids the huge “rip everything twice” project that @mikeappsreviewer leans toward, while still giving you lossless for the music you care about most.
4. About actual sound difference for your case
In your real use:
  • Car stereo: Road noise, mediocre acoustics, often Bluetooth compression. High bitrate MP3 vs FLAC is practically a tie.
  • Phone: Wireless earbuds or basic wired buds, plus outside noise. Again, 256 / 320 kbps MP3 is rarely the bottleneck.
You only really exploit FLAC when:
  • quiet room
  • decent wired headphones or speakers
  • you like to listen to the sound itself, not just the song
If that is not you yet, you do not lose much by standardizing on MP3 now.
5. Player choice and Elmedia Player
On desktop, especially macOS, a player that handles both MP3 and FLAC gracefully is useful even if you mostly go MP3.
Elmedia Player pros:
  • Plays FLAC, MP3 and a long list of other formats without chasing codecs.
  • Handles playlists and libraries cleanly so you can mix FLAC “favorites” with MP3 bulk.
  • Nice for testing your own ears: you can A/B the same track in FLAC vs MP3 quickly.
Elmedia Player cons:
  • It is an extra app to install and use instead of the default player.
  • Some features you might not care about if you only ever hit “play and forget.”
Compared to the more archivist‑leaning workflows that @viaggiatoresolare and @mikeappsreviewer hint at, Elmedia Player is handy for a lighter approach: small FLAC island inside a big MP3 ocean, without format headaches.
6. Concrete recommendation for your situation
Given what you described:
  1. Rip everything to 256 or 320 kbps MP3 as your main library.
  2. Test a handful of tracks in FLAC on your computer with something like Elmedia Player to see if you personally care about the difference.
  3. If you do, keep FLAC only for a short list of “forever albums” on your PC or drive.
  4. Phone and car stay MP3 only for simplicity.
That balances quality, storage, and compatibility without turning your rebuild into an endless project.
