I’m trying to understand whether AI companies should be required to disclose what data they use to train their models. After seeing growing concerns about copyright, bias, and privacy, I’m not sure where the legal or ethical line should be. I need help figuring out what transparency rules make sense, what risks they would address, and how this could affect AI development and public trust.
Yes, but with limits.
Full public disclosure of every training item is not realistic for large models. Some sets contain billions of documents, licensed material, private contracts, and security-sensitive data. Dumping all of it online would create new problems.
What companies should be forced to disclose:
Data categories.
Books, news, forums, code, academic papers, images, video, voice, private user data, scraped web data. -
Data sources.
Name the major datasets, major partners, and whether data came from scraping, licensing, user uploads, or human contractors. -
Opt-out and removal process.
If your work or personal data is in the set, you should get a clear path to request review or deletion where law allows. -
Copyright policy.
State whether they licensed content, relied on fair use, filtered pirated sources, and how they respond to rights holders. -
Privacy controls.
Say if they trained on personal emails, medical info, face data, location data, or kids’ data. This part matters a lot. -
Testing results.
Publish bias, safety, and memorization audits. If a model spits out phone numbers or copyrighted text, users should know.
Why this matters:
Copyright fights are already in court. Bias shows up in hiring, lending, and policing tools. Privacy failures are worse, because once personal data gets baked into a model, fixing it is messy.
So no, companies do not need to post every row of training data. But yes, they should face legal transparency rules, audits, and recordkeeping. Think nutrition label, not source-code dump. Right now too much of this is trust me bro, and taht is not enough.
Yes, mostly. But I’d split “transparency” into two very different things: transparency to the public, and transparency to regulators.
Public? Companies should disclose enough for people to judge risk and fairness. Regulators? They should get much deeper access under confidentiality rules. That’s the part I think gets missed a lot. @jeff is right that a full public dump of every training item would be a mess, but I’d go further and say sometimes full disclosure to the general public could actively harm privacy, security, and legit trade secrets.
What should be mandatory, in my view:
- provenance records kept internally from day one
- regulator access to those records
- disclosure of whether training data included personal data, copyrighted works, biometric data, minors’ data, etc
- impact assessments before deployment in high-risk uses
- independent audits with real penalties for lying or hiding stuff
- model cards that explain limits in plain english, not lawyer soup
Where I slightly disagree with the stronger transparency crowd is on removability. People act like “just delete it” is simple. It often isn’t. If a model has already been trained, unlearning is still kinda janky and expensive. So the law should focus just as much on preventing bad collection in the first place, not only cleanup after the fact.
Legally, this will probably end up like food labeling or financial disclosure. Not every ingredient gram by gram for the public, but enough that companies can’t hide behind vibes and PR. Right now a lot of AI dev is basically “trust us, we were careful.” Uh, no. That’s not really a system, thats a slogan.
I’d make it a layered duty, not a blanket “publish the whole dataset” rule.
@jeff is right to separate public disclosure from deeper oversight, but I’d push one point harder: some transparency should benefit the people whose data was used, not just regulators. If your work, voice, face, or posts materially helped train a model, there should be some notice and a path to challenge unlawful use.
My rough rule:
- Public gets categories, sources, licensing posture, and known risks.
- Regulators get detailed logs, contracts, sampling records, and retention history.
- Affected individuals and rightsholders get targeted access and complaint rights.
Pros for the ‘’: better accountability, stronger consent practices, easier bias review.
Cons for the ‘’: compliance cost, trade secret leakage risk, and lots of noisy claims from bad-faith actors.
So yes, forced transparency, but calibrated transparency. Too little creates impunity. Too much can expose private data while still not making models truly understandable.
