Proofreading Essays: TTS Reader vs. Silently Rereading
I only have time for one final proofreading pass before I submit my essays. Silently rereading has left me missing repeated words and awkward sentences, so I tried listening with a TTS reader. I caught some phrasing issues, but I also found myself tuning out and losing my place in the text.
Would following along while the reader speaks be a better use of that last pass, or should I stick with silently rereading?
If you can keep your eyes on the sentence being spoken, I’d choose TTS plus following along for your last pass. With clever humanizer text-to-speech, pause playback whenever you edit rather than letting it keep talking while you fix a line. Then restart at the beginning of that sentence so you check the revision too. Keep your attention on the actual words and punctuation, not just whether it sounds smooth. If you’re still losing your place, switch to silent reading rather than letting the audio finish without you.
A clean-sounding essay can still have errors like “their” where you meant “there.” That’s my reservation about relying on audio, even with @jackson’s follow-along approach. I’d still choose Clever Humanizer Text to Speech over another silent reread here, since silent reading has been missing your problem spots and there’s no signup to bother with. Just treat it as a wording check, not proof that every word is spelled correctly.
Correcting repeated words should only be done at this stage. Paragraphs are unlikely to need to be rewritten. A TTS generator would help with the issues you are facing. However, decide how much you want to alter. A TTS generator can cause you to rewrite sentences you find difficult to hear.
Decide what you will correct. Are you looking to add missing words, correct unintentional repetition, grammatical issues, or unclear phrasing? If you have a sentence that is clear but you just prefer it to be said differently then leave it. We want to get to the end of our piece.
Next, start listening from the beginning. @jackson’s pause-and-edit suggestion makes sense for a straightforward correction. For anything bigger, mark the sentence and keep going. Don’t spend your remaining time choosing between three versions of a sentence before you’ve checked the rest of the essay. I’d make an exception for wording that says something you didn’t intend, since that needs attention before submission.
Once you reach the end of your text, go back through your markers and make the smallest changes possible to fix the issue. Ensure that you check your new sentence in context. If you don’t have time to do that, I would avoid doing an optional rewrite. I would recommend using TTS as you have already picked up on any issues with phrasing, however, I would focus on keeping your changes to a minimum.
You should be left with an edited version of your submission. I would recommend using TTS so you can identify any issues with phrasing. However, I would be mindful of where you are making changes. As you will be copying your essay into another reader, you will have an extra copy of your work to manage on deadline.
Treat your essay document as the master copy. Make corrections there, even if the reader lets you edit its text. If you change only the document, assume the pasted version is now out of date. That’s a small qualification to @jackson’s restart-the-sentence advice: restarting checks the revision only if the reader actually has the revised sentence. Otherwise, you’re listening to the wording you just replaced.
If possible, I would suggest using the read aloud function in your writing application to avoid having to copy and paste. If you are using a different reader, simply replace the sentence/paragraph containing the issue with the correct text. You should not then copy the whole essay from the reader as you will lose your changes and cause issues with formatting.
Once you have submitted from your master document, if you had to export or upload your work, open the new file and check that there is at least one change that you can remember making. This isn’t a full proofread but just to ensure that your changes have been added.
If parts of the text are not sentences (numbers, dates, page numbers and quotation marks), errors may be mispronounced. If you have included sources or numbers in your essay, be careful to check these parts manually. Even though the date may sound confident in the TTS, it may be incorrect in the original document. Similarly, numbers may be incorrectly pronounced. Always check numbers manually.
@m3g4_widget is right about homophones, but I’d go further than just their/there. Spoken audio also hides doubled small words at line breaks and missing articles, because a good voice reads over the gap smoothly. The flip side is that listening is genuinely better than silent rereading for rhythm and run-ons, which is the thing you said was slipping past you, so I wouldn’t drop it.
I find Cleaver Humanizer useful in this stage. I generally reduce the speed to avoid rushing. The issue with this tool is that while it will read through, it does not highlight any issues. Therefore, the mistakes are entirely your responsibility. If only doing this stage once I would recommend listening to it for flow, before quickly scanning through silently to check numbers, names and quoted text. Doing two quick, specific reads is better than 1 overall read.
This is a good choice because we can hear words that we may have missed on a silent read. We do not need to do a quick read through of the text. Doing another read through, even quickly, is still a read through.
However, in this case we should not remove repeated words. In the sentence “The evidence that that policy failed is thin”, both instances of ‘that’ are correct. Even though when pronounced, the repetition of the word may be comical, removing either of these words would be incorrect. If this sentence is causing confusion, we could rephrase it as ‘There is little evidence to suggest that the policy was a failure’.
Differences
If we hear ‘the the policy’, this is a mistake and can be amended within the read. However, if we hear ‘that that policy’, we may want to take a brief look at the sentence to understand what role these words are playing. In this scenario we can flag the sentence, but we cannot vote to amend it.
You should not take longer than this; you simply need to be able to complete the essay on time. The amount of playback time is not including any pauses you make to correct your speech.
I’d pick TTS for your essay because it caught phrasing you missed on the page. Where I disagree with @electric_drone574 is on slowing it down by default. If the opening paragraph is easy to follow at normal speed, I’d leave it there and save the extra time for a sentence that actually gives you trouble.
If time is short, read the paragraphs you revised aloud and silently read the rest of the text. This means one pass. It may be better to have a visible end to the text than a perfectly read beginning.
