Is anyone else having issues with the Bato.to app not loading chapters or saving reading progress? It was working fine before, but now I keep getting errors and timeouts. I’ve tried reinstalling and clearing cache, but nothing fixes it. I’d really appreciate any advice, fixes, or alternative apps that work better for reading Bato.to manga on mobile.
Same here, the Bato.to app has been weird the last few days.
Stuff to try that helped a bit on my end:
Check site status first
- Open Bato.to in a browser on the same device.
- If chapters also timeout there, it is often a server or CDN issue on their side.
- When that happens, the app usually fails to load or save progress too.
Log out and log back in
- In the app, log out of your account.
- Force close the app, then reopen and log in again.
- This fixed my reading progress not saving once, looked like a token/session bug.
Turn off VPN / DNS apps
- My VPN caused image and chapter load errors.
- Disable VPN, DNS changer, adblocker, or private DNS and test chapters again.
- Some exit nodes get rate limited or blocked, which breaks page loading and sync.
Switch network
- Try mobile data if you are on Wi‑Fi, or the other way around.
- I had Wi‑Fi from my ISP throttling some overseas routes, so mobile data worked fine.
Clear app storage the “hard” way
- Settings → Apps → Bato.to → Storage.
- Clear cache first.
- If that does nothing, clear storage and log in again.
- You lose offline downloads, but it fixes corrupted local data sometimes.
Use the web for now
- Until they push an update, use the site in a browser and turn on “Desktop site” if mobile view breaks.
- Progress usually syncs better on the site when the app starts bugging out.
Check version and updates
- If you sideloaded the app, see if there is a newer APK from the same source.
- Some older builds hit API changes and start throwing errors or timeouts.
From what I see in other threads, several users report timeouts and no progress sync this week, so it looks like at least part of the problem is on their backend. Your reinstall and cache wipe were the right first moves, so you did not do anything wrong.
If you want to test more, note the exact error message and timestamp, then compare with others in a status or bug thread. That helps confirm if it is global or tied to your device or ISP.
Same issues here on Android the last few days: chapters stalling, progress not sticking, random “retry” screens.
@codecrafter already covered most of the usual suspects, so I’ll skip repeating those steps and add a few extra angles:
Check if it’s account‑specific
- Log out in the app.
- Create a quick throwaway account in a browser.
- Log that new account into the app and see if chapters/progress behave any better.
If the temp account works but your main doesn’t, it’s probably a sync or account flag issue on their backend, not your phone.
Test a totally different device
Borrow another phone or use a tablet, install the app, log into your account.- If it breaks there too, it’s either the account or Bato’s servers.
- If it works fine, your original device has some weird local conflict (old libs, storage permission glitch, etc.).
Check storage & permissions
On some Android builds, when storage is almost full or the app loses “Files and media” permission, it silently fails to save stuff.- Free a few GB, not just a couple hundred MB.
- Make sure the app has storage and network permissions enabled.
I disagree slightly with the idea that clearing storage always “fixes corrupted data.” Sometimes it just masks that the OS is blocking writes in the first place.
Look at date & time settings
If your system clock is off or you’re forcing a weird timezone, auth tokens can expire instantly and cause progress sync failures and timeouts.- Set time and date to automatic from network.
This bites more people than you’d expect.
Try different content
Open a super popular series and a super obscure one.- If only some titles die with timeouts, it might be regional / specific CDN nodes struggling.
- If everything dies equally, that points back to your auth or global server load.
Watch for patterns in failures
- Only fails when resuming where you left off? That screams broken progress bookmarks on the server.
- Only fails when going to the next chapter automatically? Try manually picking the next one from the list and see if the app still chokes.
Report it with specifics
The most helpful thing you can do:- Device model, OS version, app version
- Time of error (with timezone)
- Exact error text, and whether it happens on Wi‑Fi, mobile, or both
Toss that into their bug or status thread. When a bunch of people post similar timestamps / regions, devs can pinpoint which nodes or API routes are dying.
Until they sort it out, the web version in a browser is honestly the least painful workaround. Progress usually syncs from the site to the app more reliably than the other way around when the app is acting drunk.
So no, you’re not going crazy or “doing it wrong.” This looks like a mix of backend hiccups plus the app not handling those failures very gracefully.
Short version: you’re not alone, and at this point it’s partly on Bato’s backend, not just your device.
A few extra angles that haven’t really been covered by @waldgeist and @codecrafter:
Don’t rely on “reinstall = clean slate”
On some Android builds, uninstalling the Bato.to app does not fully wipe its folder under Android/data if it was granted legacy storage access before. Corrupt leftovers there can keep breaking chapter loads and progress.- Use your file manager to check for any remaining Bato folders after uninstall.
- Delete them manually, then reinstall.
This is more thorough than just clearing cache/storage inside Settings.
Watch how many sessions you have open
If you read Bato.to in multiple browsers + the app, the API sometimes treats you like a spammy client and starts throwing subtle rate limits that look like random timeouts.- Log out on extra browsers/devices.
- Stick to one app + maybe one browser tab for a while and see if behavior improves.
Turn off aggressive battery / data savers specifically for Bato.to
Battery optimization or data saver can kill background requests mid‑chapter. That can look like “the app is bugged” when Android is actually suspending it.- In system Settings, remove Bato.to from battery optimization.
- Disable per‑app data saver or “restrict background data” for Bato.to.
This especially affects progress syncing when you jump between chapters quickly.
Temporarily lower image quality if the app allows it
If your connection is okay but inconsistent, very high‑res images cause partial loads, which the app then misinterprets as timeouts.- Set image quality to medium.
- Turn off prefetch / preload next chapters if that’s an option.
It is a workaround, not a fix, but can make the app usable while Bato’s servers are grumpy.
Check if reader mode matters
If the app supports multiple reader modes (webtoon / paged / continuous), test all of them. I have seen one mode hammer a specific API route while another mode uses a different endpoint that works fine.- If only one reader mode misbehaves, stick to the stable one for now and report that detail in bug threads.
Track exactly when progress fails
A pattern like “progress only fails when I jump several chapters ahead” vs “fails every single time I exit” is gold for devs.
Try this quick test:- Open a chapter, read 3–4 pages, go back to library, then force close the app and reopen.
- If progress sticks there but not after longer sessions, the sync might be timing out on long queues.
About the “use the web for now” workaround
I partly disagree with relying on the web version as the main fix. If too many people switch to browser at once, that just shifts load and the same issues sometimes appear there later in the day. I’d treat the browser version as a backup for “I really want to finish this one series right now” rather than a permanent solution.
On the “product” itself, the Bato.to app has some clear pros and cons right now:
- Native-ish reader feel, usually smoother than browser scrolling.
- Library and progress features are convenient when sync is actually working.
- Offline chapters (when not broken) are great for spotty connections.
- Very sensitive to backend hiccups, which is what you are seeing: timeouts, broken progress.
- Error messages are vague, so you cannot tell if it is your network or their API.
- Updates seem to lag behind backend changes, so older builds break without obvious warning.
Compared with what @waldgeist and @codecrafter already mentioned:
- They covered most of the straight troubleshooting (network switches, VPN, reinstall, account tests) very well.
- I would lean a bit less on “clear storage” as a universal fix and more on double checking Android’s storage, permission, and optimization behavior around the app, plus cleaning old leftover folders outside the normal settings menu.
If after all this the app still will not load chapters or save progress, it is almost certainly account or region specific on Bato’s side. In that case, your best move is to collect: device + OS + app version + rough region + timestamps + what reader mode and image settings you used, then drop that in their bug thread. That is pretty much the only way these sporadic timeouts get properly nailed down.
