Need help understanding Apple’s new Genmoji feature
I’m trying to figure out how Apple’s Genmoji works, what devices support it, and how to create and share these custom emojis. I’ve seen people using Genmoji in messages and social media, but I can’t find clear step-by-step instructions or requirements. Can someone explain how to access Genmoji, what iOS or hardware is needed, and any tips for using it effectively?
Short version. Genmoji is Apple’s AI emoji feature in iOS 18 that lets you type a description and get custom emoji-style stickers you can use in Messages and some other apps.
Here is the breakdown.
  1. Supported devices and OS
  • Requires iOS 18 or later
  • Only works on iPhone 15 Pro and 15 Pro Max right now, because it needs Apple Intelligence
  • On iPad, you need iPadOS 18 and an M1 chip or newer
  • On Mac, you need macOS Sequoia and an M1 or newer
  • Also needs Siri language set to US English and region set to US at launch
If you are on an older iPhone, you will see normal emoji and stickers, but no Genmoji creation.
  1. Where you find Genmoji
    In Messages on supported devices:
  • Open a conversation
  • Tap the apps / plus button near the text field
  • Tap “Genmoji” or the emoji / stickers section that shows a sparkle icon
    Apple keeps moving UI stuff during betas, but it lives in the same area as stickers and emoji.
  1. How to create a Genmoji
  • In the Genmoji panel, tap the text prompt field
  • Type something like:
    • “Smiling cat with sunglasses”
    • “Tired person at desk”
    • “Goofy broccoli with big eyes”
  • Wait a second for it to load
  • You get multiple options
  • Tap one to select, then send it in the chat
You can also base Genmoji on contacts or photos on supported builds:
  • Pick “Genmoji from Photo” or similar
  • Choose a face or person
  • It builds a cartoon style face you use like an emoji-sticker
  1. How to use and share Genmoji
    Once created, you use them like stickers.
  • Tap the Genmoji in the sticker panel
  • Drag and drop onto a message bubble or image
  • Or tap to send as a standalone message
To use outside Messages:
  • In some apps with system emoji picker, you get a “Stickers” section
  • You can long-press a Genmoji in Messages and use “Add to Stickers” if prompted
  • Then paste or select from sticker keyboard in apps that support stickers, like some social apps
    Support is a bit messy right now and depends on the app.
If you want to share to social media:
  • Long press the Genmoji bubble in Messages
  • Use “Copy”
  • Paste into Instagram DM, WhatsApp, or sometimes posts / comments
    If that fails, use screenshot and crop, not ideal but works when an app does not support sticker objects.
  1. Managing your Genmoji
    In the sticker / Genmoji area:
  • Your recent Genmoji show at the top
  • You can usually long-press one to remove or manage
  • There is often a “Recents” or “Custom” section where they collect over time
  1. If you are not seeing Genmoji
    Check:
  • Settings > General > Software Update, install iOS 18 or newer
  • Device model, needs iPhone 15 Pro or 15 Pro Max
  • Settings > Siri & Search > Language, set to English (United States)
  • Settings > General > Language & Region, region United States
    If all that is correct and it still does not show, you are likely on hardware that does not support Apple Intelligence. No real workaround for that right now.
So, to use it like people you see online:
  • You need a supported device plus iOS 18
  • Use Messages as your main Genmoji place
  • Then copy or sticker-paste into social apps that support it
It is still a bit beta-feeling, so some things are buggy and UI labels move around a bit between updates.
Couple extra angles on top of what @boswandelaar already laid out, since Apple made this way more confusing than it needed to be.
  1. What Genmoji actually is (and isn’t)
    It’s not a new Unicode emoji set. Anything you make is basically an AI‑generated sticker that only really “exists” inside Apple’s ecosystem.
    So:
  • It won’t show up as a real emoji on Android or older iPhones
  • Other people just see it as an image/sticker, not as text emoji they can type themselves
  • There’s no Genmoji keyboard you can export or install elsewhere
That part trips a lot of people up because Apple markets it like you’re inventing emojis. You’re not, you’re making cute little PNGs with extra steps.
  1. Support is actually more limited than it looks
    Yes, you need iOS 18 + 15 Pro / 15 Pro Max (or M1+ on iPad/Mac) like they said, but there’s a hidden catch:
  • Apple Intelligence / Genmoji is rolling out region by region
  • If you sideload a beta or change language to US English, sometimes it still won’t show because the feature flag on Apple’s side isn’t live for your account yet
    So if you’ve checked all the boxes and it’s still missing, it’s not always your fault or your hardware. Sometimes it’s just Apple being slow.
  1. Using Genmoji with non‑Apple people
    This is where it gets kinda janky:
  • To Android or non‑supported Apple devices: it sends as an image in iMessage/SMS or other apps
  • The receiver can save it, but they cannot re‑use it as a “Genmoji” unless they screenshot or re‑import it into their own sticker tools
So Genmoji is fun in iMessage groups where most people are on newer devices, less magical in mixed groups.
  1. Social media use that actually works decently
    What I’ve seen work best:
  • Make Genmoji in Messages
  • Long‑press > Copy
  • Paste into apps that support pasting image objects directly into the text field (Instagram DMs, Telegram, WhatsApp, Discord usually behave better than, say, Twitter/X)
    If it pastes as plain text or nothing shows, that app just isn’t respecting Apple’s sticker object. Screenshot + crop is the ugly fallback, like @boswandelaar said, but honestly I’d rather just export a Live Sticker pack or use a meme app if I’m going to that trouble.
  1. A small thing people miss: expressions & variations
    Apple quietly does a decent job with:
  • Emotions: “annoyed”, “chaotic”, “unbothered” in the prompt actually change the face
  • Style hints: “3D”, “flat”, “minimal”, “sketchy” sometimes tweak the look
    Not perfect, but you can get more consistent “characters” if you keep reusing similar phrasing. So you can kind of build your own little Genmoji persona set if you’re patient.
  1. Privacy / data angle, since nobody talks about it
    Apple claims Genmoji generation runs with “Private Cloud Compute” when your device can’t do it locally. Translation:
  • For some prompts, your data leaves the phone
  • They say it’s processed on special Apple servers without being stored or used to train models
    If that stuff matters to you, avoid using names, addresses, or anything sensitive in the prompts. Most people won’t care, but it’s worth noting.
  1. When it’s actually worth using
    Genmoji is great for:
  • Inside jokes with friends where no standard emoji fits
  • Quick “reaction” stickers for group chats
  • Making goofy avatars of friends from photos
    It’s overrated for:
  • Cross‑platform communication
  • Anything where you need consistency or professional look
  • Replacing real emoji, because it never will
tl;dr:
  • You’re not missing a hidden tutorial, Apple just shipped a half‑baked but fun sticker generator tied to new hardware.
  • Treat Genmoji as disposable, chat‑only stickers, not real emojis.
  • If your device isn’t on the supported list, there’s no legit workaround yet, regardless of settings tweaks.
Couple of extra angles that might clear up confusion, without rehashing what @ombrasilente and @boswandelaar already covered.
1. Think of Genmoji as “lazy-mode custom stickers,” not a feature you must master
Where I slightly disagree with others: you don’t really need a big workflow. The most realistic use is:
  • Open Messages, type a quick prompt, send, forget.
  • Treat them as disposable reactions, not a curated collection.
Trying to “manage” a library of Genmoji usually turns into more effort than it is worth.
2. Why you might not want to rely on Genmoji too much
Cons people hit after a week or two:
  • Lock-in: Everything lives in Apple’s walled garden. No universal emoji, no standard keyboard export.
  • Inconsistent style: AI output can shift from one update to the next. A “character” you liked may not be reproducible later.
  • Patchy app support: Some social apps treat them like proper stickers, others flatten them or reject paste entirely.
  • Hardware gatekeeping: Older iPhones are hard-stopped out of Apple Intelligence, so there is no soft workaround with settings tricks.
So if you are hoping to build a personal “emoji brand” that works across platforms, Genmoji is the wrong tool.
3. Where Genmoji quietly shines
Pros that do make it worth trying if you have iOS 18 and Apple Intelligence:
  • Inside jokes at speed: You can describe a very specific situation and have a visual gag in seconds.
  • Face-based reactions: Turning a friend’s photo into a cartoon reaction can land better than a standard emoji or Memoji.
  • Promptable emotion: Adding adjectives like “exhausted,” “overwhelmed,” “smug,” “chaotic” actually changes the expression in useful ways.
If you stick to that narrow use case, the feature feels fun instead of frustrating.
4. Genmoji vs what you already have
Compared with classic emoji and static sticker packs:
  • Genmoji
    • Pros: Infinite variety, hyper specific prompts, integrated in Messages.
    • Cons: Not portable, not standardized, hardware restricted.
  • Normal emoji
    • Pros: Universal, predictable, tiny data footprint.
    • Cons: Limited set, slow standards process, no true “inside joke” visuals.
  • Sticker packs / third party apps
    • Pros: Cross-app use when properly packaged, consistent style.
    • Cons: Fixed content, more setup, often paywalled.
This is why I’d treat Genmoji as a complement, not a replacement.
5. About what @ombrasilente and @boswandelaar said
Both already nailed the “how-to” and device lists in detail.
Where I’d add nuance:
  • They’re right that Genmoji is not real emoji, but I’d say that is actually a benefit if you like ephemeral content that does not clutter your long-term emoji keyboard.
  • They emphasize region and language toggles; I would not bother trying to game that if you are outside the official rollout. Waiting for Apple to flip the switch is usually less painful than chasing hidden flags.
6. Pros & cons of using Genmoji as your main “reaction system”
Even without a product title to name here, you can think of “Apple Genmoji” as its own little product:
  • Pros
    • Extremely fast creative reactions.
    • Deeply integrated in iOS 18 Messages.
    • Fun for groups where everyone has recent hardware.
  • Cons
    • No true cross-platform compatibility.
    • Dependent on Apple’s rollout schedule and servers.
    • Hard to keep consistent visual identity.
If that tradeoff sounds okay, Genmoji is worth using exactly where it excels: quick, throwaway, context-specific reactions in Apple-only chats, not as a universal emoji solution.
