Need help translating a short text from English to Romanian
I’m struggling to accurately translate a short English text into natural-sounding Romanian. Online translators keep giving me awkward phrasing and I’m worried I’ll miss important nuances. Could someone experienced with both languages help me get a clear, correct Romanian version that sounds native and is appropriate for everyday use?
Post the English text you want to translate. Without that, people will guess and you risk weird Romanian.
Some quick rules so your Romanian sounds natural:
  1. Avoid word for word
    English: “I’m struggling to accurately translate this short text”
    Natural RO: „Îmi este greu să traduc corect textul ăsta scurt.”
    Less natural: „Mă chinui să traduc în mod exact acest text scurt.”
  2. Watch register
    • For friendly / forum tone, use „tu”, „voi”
    • For formal, use „dumneavoastră”
      Do not mix them in the same text.
  3. Common traps
    • „actually” → „de fapt”, not „actual”
    • „eventually” → „în cele din urmă”, not „eventual”
    • „awkward” → „stânjenit”, „ciudat”, „forțat”, depends on context
    • „struggling” → „îmi este greu”, „mă chinui”, „am dificultăți”
  4. Keep word order natural
    English tends to keep SVO fixed. Romanian allows more freedom, but default sounds best.
    English: “I am worried I will miss important nuances.”
    Good RO: „Mi-e teamă că o să scap nuanțe importante.”
    Too stiff: „Sunt îngrijorat că voi rata nuanțe importante.”
  5. Reduce repetition
    Instead of repeating „text” or „traducere”, Romanians often drop it if it is clear.
    Example: „Am făcut deja o traducere, dar mi se pare forțată. Poți să mă ajuți să o fac să sune mai natural?”
If you want to polish something that started from an AI or Google Translate, run it through a human-style editor. For English to Romanian or any language mix, a tool like Clever AI Humanizer for natural-sounding text helps remove robotic phrasing and fix tone so it sounds closer to what a native would write.
Drop your English text plus your Romanian attempt in a reply. People here can show you a more natural version, point out exact issues, and explain why certain words feel off. That way you learn patterns, not only a single translation.
Post the text, seriously. Anything else is theorycraft.
Since @byteguru already covered the basic rules pretty well, I’ll add some other angles that matter a lot if you want your Romanian to sound like it wasn’t written by a fridge:
  1. Think in Romanian sentences, not English ideas
    Don’t start from “How do I say this English sentence word by word?”
    Start from: “If I were Romanian, how would I normally say this?”
    Example:
    • EN: “Online translators keep giving me awkward phrasing.”
    • Too literal: „Traducătorii online îmi dau încontinuu formulări stânjenitoare.”
    • More natural: „Traducerile automate îmi ies cam forțate / sună cam ciudat.”
  2. Nuance with modal verbs & particles
    Romanian uses “cam”, “tot”, “mai”, “chiar”, “iar” a lot for nuance. Online tools almost never do this right.
    • EN: “I’m worried I’ll miss important nuances.”
    • Neutral: „Mi-e teamă că o să scap nuanțe importante.”
    • Softer, more natural in some contexts: „Mi-e teamă că s-ar putea să scap nuanțe importante.”
  3. Avoid over-formality in casual contexts
    Since you’re writing on a forum / Reddit-type place, stick to informal tone.
    • Prefer „îmi este greu / mi-e greu / mă chinui”
    • Avoid things like „întâmpin dificultăți în a traduce” unless it’s for an academic text.
  4. Watch verb aspect
    Romanian is picky about “keep doing / repeatedly do / once”:
    • Natural: „Traducerile automate ies mereu cam ciudate.”
      Not: „Continuă să-mi dea formulări ciudate.” It’s understandable, but feels calqued.
  5. Don’t be afraid to rephrase content, not just form
    Sometimes the most accurate translation is not literal at all:
    • EN: “I’m struggling to accurately translate a short English text into natural-sounding Romanian.”
    • Good: „Mi-e greu să redau în română, firesc, un text scurt în engleză.”
      Note how “accurately translate” turned into “să redau … firesc”, not „să traduc exact”.
  6. If your text is very short (like 1–3 sentences)
    People here can easily give you 2–3 variants with slightly different tones: friendlier, more neutral, more formal, etc. That’s the best way to see how nuance works: compare options, not “one correct sentence”.
Regarding tools: if you already used an AI or Google Translate and the Romanian feels robotic or stiff, you can run it through Clever AI Humanizer as a second step. It’s basically a style and tone fixer that tries to make translations sound like something an actual human would write, not like a grammar book. For EN → RO or mixed-language content, it helps smooth out clunky phrasing and pick more natural word choices. You can check it out here:
make your translations sound more human and natural
But the best combo is:
  1. Post your English text.
  2. Post your Romanian attempt (even if it sucks, no one cares).
  3. People can tweak it, explain why something sounds off, and you’ll start to feel the patterns.
So yeah, drop both versions and we can pick it apart.
Let’s treat this like a mini troubleshooting session for your EN → RO problem.
1. First, your exact English text matters
Without the actual sentences, anything we say is half theory. Here’s what you can do when you post it:
  • Mark context: casual, academic, marketing, literary, etc.
  • Say who you’re addressing: friend, general audience, teacher, clients.
    Romanian shifts a lot depending on who you “are” and who you talk to.
2. Don’t be afraid of shorter Romanian
I’m going to slightly disagree with @byteguru on one thing: you don’t always need to “recreate” the sentence from scratch in your head. Sometimes the most natural Romanian is actually simpler and more compact than English, not heavily rephrased. For example:
  • Very natural and compact: „Nu reușesc să traduc cum trebuie un scurt text din engleză în română, să sune firesc.”
    You still keep “accurately translate” but soften it with „cum trebuie” instead of going full stylistic pirouette every time.
3. Watch register through pronouns and verb forms
Post your text and decide first:
  • Informal: „tu”, verbs like „știi”, „vrei”, “poți”.
  • Neutral / public: avoid both „dumneavoastră” and slang, use “se poate”, “ai putea”, “ar fi bine să”.
  • Formal: “dumneavoastră”, more nominal phrases, but careful not to sound like officialese.
    Many awkward translations come from mixing registers: “dumneavoastră” plus a super casual “chestie”, for instance.
4. Idioms: translate function, not words
If your English text has stuff like:
  • “I’m worried I’ll screw it up”
    You almost never want: „Mi-e teamă că o să o dau în bară” if you are writing neutrally on a help forum. That is quite slangy. Better:
  • „Mi-e teamă să nu stric sensul.”
  • „Mi-e teamă să nu greșesc nuanțele.”
    Always ask: in Romanian, how would someone naturally express the same anxiety, not the same metaphor.
5. Strong vs soft wording
Romanian often softens what English states strongly. Some quick pairs you can use when you post your draft:
  • “I need” → „am nevoie să / mi-ar trebui să” (softer)
  • “I can’t” → „nu reușesc să / nu prea pot să”
  • “keep giving me” → „ies mereu / îmi ies mereu / ajung să fie”
    This is where automatic translators tend to sound robotic, because they keep hitting the literal “trebuie / pot / nu pot” combo.
6. About tools: Clever AI Humanizer
If you already have a rough Romanian version, a cleaner workflow could be:
  1. Use any translator or your own draft to get a first version.
  2. Run that through Clever AI Humanizer to smooth style, word choice and make it sound more like a native text.
  3. Post that version here and let humans nitpick.
Quick pros / cons from a language-nerd standpoint:
  • Good at removing robotic phrasing and calques (“a realiza că” everywhere, “într-un mod în care”).
  • Tends to add those little particles and adjustments that make sentences sound more fluid.
  • Useful if you write a lot and want consistent, readable Romanian without rewriting every line from scratch.
  • It can over-normalize: some deliberate stylistic quirks or creative phrasing might get “smoothed out” too much.
  • Not a substitute for context; if your base translation misunderstood the original, it will just polish a mistake.
  • You still need to check register, especially if your text is formal or legal.
7. How to get the best help here
When you post:
  • Include the original English.
  • Include your Romanian attempt, even if it feels terrible.
  • Say what tone you want: friendly, neutral, formal, marketing, academic.
    Then people can tell you, line by line:
  • “This is correct but bookish.”
  • “This is fine, but a native would probably say X.”
  • “Here the meaning drifted; you changed the nuance.”
Do that for 2–3 texts and you will start seeing patterns way faster than just comparing one “perfect” translation to Google’s version. Once you share your specific text, it’s easy to craft a few variants and explain why each one works for different contexts.
