Need help setting up my new Ring Doorbell correctly
I just bought a Ring Doorbell and I’m confused about the setup steps, wiring, and connecting it to WiFi. The app instructions feel vague and I don’t want to install it wrong or damage anything. Can someone walk me through the proper setup process and share any tips to avoid common mistakes?
Here is a simple step by step that works for most Ring Doorbells.
  1. Figure out which model you have
    Battery only, wired only, or “battery + wired.”
    Check the box or the back of the unit. This matters for wiring.
  2. Prep before mounting
    • Charge the battery fully with the USB cable. Solid green light means done.
    • Download the Ring app, create an account, log in.
    • Turn on Bluetooth on your phone.
    • Have your WiFi name and password ready. Use 2.4 GHz if your router has both. Ring is more stable on 2.4.
  3. Add device in the Ring app
    • Open the app. Tap “Set up a Device.”
    • Pick “Video Doorbells.”
    • Scan the QR code on the back of the doorbell or in the manual.
    • Follow the prompts until it asks to connect to the Ring network.
    • When your phone sees “Ring-xxxx” in WiFi settings, connect to that.
    • Go back to the app. Pick your home WiFi. Enter password.
    Common gotcha: wrong WiFi band or wrong password. If it spins forever, move closer to the router and retry.
  4. Decide on power method
A. Battery only
• No existing doorbell wires used.
• Make sure battery is in the device.
• Use the provided wedge or bracket. Mark holes.
• Drill pilot holes if needed.
• Screw the mounting bracket to the wall.
• Hook the top of the Ring into the bracket. Snap it in. Install the security screw at the bottom.
Battery mode means you use a Ring chime or phone notifications, not your old chime.
B. Use existing doorbell wires (low voltage)
Important: Power must be 8–24 VAC transformer. Do not connect to 120 V.
If you are not sure, check your existing doorbell transformer. It is often near the breaker panel or HVAC. It should say “16VAC” or similar.
Steps:
• Turn power to the doorbell circuit off at the breaker.
• Remove the old doorbell button.
• Pull the two low voltage wires out.
• Attach those two wires to the two screws on the Ring mounting plate. Order does not matter. Tighten the screws.
• Mount the bracket using provided screws.
• Mount the Ring body on the bracket.
• Turn power back on.
The Ring will get trickle power from the transformer, and your old chime might still ring depending on model and settings.
  1. In app settings after install
    • Open the Ring app, tap your doorbell, go to “Device Settings.”
    • Set “Motion Settings” so you do not get spammed. Start with “People Only” if your model supports it.
    • Adjust motion zones so it does not see cars in the street if you do not want that.
    • Set “Power Settings” based on wired or battery. On battery, use slightly reduced motion sensitivity to extend life.
  2. WiFi placement tips
    • Try to keep the doorbell within about 30–40 feet of the router, with not too many walls between.
    • In the app, check “Device Health.” Look at RSSI.
  • Around -40 to -60 is strong.
  • Worse than -70 is weak and leads to lag or missed events.
    If signal is weak, use a Ring Chime Pro or a generic WiFi extender closer to the door.
  1. Basic testing
    • Press the doorbell button, watch for live notification on your phone.
    • Use “Live View” in the app to check video and audio.
    • Walk through the motion zones to confirm motion alerts fire where you want.
  2. Common problems and quick fixes
    • Doorbell not powering on on wires:
  • Check breaker.
  • Confirm transformer output is 8–24 VAC, not DC.
  • Check that the small wires are tightened under the screws.
    • Keeps dropping WiFi:
  • Move router a bit closer if possible.
  • Change router channel or move to 2.4 GHz only for that SSID.
    • Laggy video:
  • Do an internet speed test near the door. Aim for at least 2 Mbps upload per Ring device.
If your house wiring looks old or weird, or if you see thick 120 V Romex behind the button instead of thin low voltage wires, stop and get an electrician. Do not tie the Ring directly into 120 V.
Couple of extra angles to add on top of what @sterrenkijker already laid out:
  1. Double‑check your transformer before you touch wires
    The label “16VAC” on the transformer is not enough; some old ones are 10 VA and Ring really wants 16–30 VA. Undersized transformer = flaky chime, random reboots, super slow charging. If your current one is tiny or ancient, replacing it with a 16V 30VA unit is often the single best “install upgrade.”
  2. Skip wiring if your chime wiring looks sketchy
    If the wires are super corroded, frayed, or you’re not 100% sure what circuit they’re on, just start in battery‑only mode. You can always come back and wire it later. People fry their transformers by guessing which wire is what. A cheap non‑contact voltage tester is worth the $10 so you don’t surprise yourself with 120V.
  3. WiFi: treat placement as more important than “speed”
    Everybody worries about Mbps, but the doorbell cares more about signal quality. Two tips that have actually mattered for me:
    • Put the router higher in the room, not hidden in a cabinet.
    • If your router has a “Smart Connect” single SSID for 2.4 + 5 GHz and Ring keeps failing to join, temporarily create a separate 2.4 GHz‑only network just for Ring. After setup you can decide if you want to keep it or merge.
  4. Don’t mount it until the app setup fully finishes
    Slight disagreement with the “prep then mount” flow: I always do a “dry run” first.
    • Battery in, hold it in your hand near the door where it will live.
    • Run the whole Ring app setup, connect to WiFi, do a Live View test.
    • Only after that passes do I grab the drill.
      Saves you from unscrewing the thing 4 times when the WiFi hates that location.
  5. Angle & height matter more than Ring’s marketing implies
    Install height around 48 inches from the ground works for most doors. If your steps are high or your walkway is very close, use the wedge kit aggressively so it angles down and sideways. Poor angle = constant motion alerts from the street, which kills your battery and your sanity. Take 2 minutes to hold the doorbell where you think it should go and use Live View to see what the camera sees before committing holes to the wall.
  6. If your mechanical chime is acting weird
    • If it buzzes or clicks but doesn’t ring properly, check in the app that you set “Mechanical” vs “Digital” correctly under Chime Type.
    • Some older chimes just never behave right with Ring. In that case, disable the internal chime in the app and grab a Ring Chime or any smart speaker integration, and let the old chime retire instead of fighting it.
  7. Basic sanity checklist so you don’t damage stuff
    • Never connect it to any bare cables that look like normal house power (thick sheathed, black/white/copper). That is 120V and a fast way to kill the Ring and possibly yourself.
    • Only connect to thin low‑voltage doorbell wires coming from a doorbell transformer.
    • Power off at the breaker before touching the old doorbell button. Don’t trust the switch by the door.
If you post:
  • exact Ring model (e.g. “Ring Video Doorbell 3 Plus”),
  • whether you have an existing chime and transformer rating (or a pic of the transformer label),
  • rough distance from door to router,
people here can tell you in pretty concrete terms if wired vs battery is worth it in your setup and whether your existing transformer will handle it without drama.
Skip the app for a second and decide one thing: are you actually gaining anything from wiring this Ring Doorbell, or is battery-only fine for you?
1. Wiring vs battery in the real world
  • Battery only
    • Pros: No touching house wiring, zero risk to transformer, super quick swap if it dies.
    • Cons: Have to pull it down to recharge, especially in winter or with busy streets.
  • Wired (low voltage)
    • Pros: Trickle charging so the battery rarely needs to come out, can use an existing chime if it behaves.
    • Cons: Transformer needs to be strong enough, and old wiring can cause random reboots or no ring inside.
Where I slightly disagree with parts of @mikeappsreviewer and @sterrenkijker: people obsess over getting it wired ASAP. In lots of installs I do, I start battery-only for a week. If WiFi is stable and you like the angle, then decide if running / reusing wires is worth the hassle. You avoid opening walls just to discover your transformer is underpowered.
2. Easiest safety check before wiring
If you choose to wire:
  • Kill power at the breaker first.
  • Only use the thin low voltage doorbell wires that were on the old button.
  • If you see thick house cable (black / white / bare copper in a sheath), stop. That is 120 V and not for a Ring Doorbell at all.
  • A cheap non contact voltage tester is your friend. If it chirps or lights up on those “doorbell” wires, you are not on the right circuit.
If anything here feels sketchy, go back to battery mode. You can always upgrade the transformer and connect later.
3. WiFi sanity moves that actually help
Instead of fighting the app endlessly:
  • Temporarily stand where the doorbell will go and run a speed test on your phone using 2.4 GHz only.
  • If upload is under ~2 Mbps or the signal jumps in and out, move the router or add an extender before you blame the Ring Doorbell.
  • I disagree a bit with the idea that distance alone is the main issue. I see more problems from routers stuffed in metal racks or behind TVs than from being 40 feet away. Get it out in the open and high.
4. Power & angle choices that avoid headaches
Two tricks that save time:
  • Before drilling, hold the Ring Doorbell where you think it belongs and open Live View.
    • If you see a lot of sky and road, you will get too many motion alerts and drain the battery. Use the wedge to tilt it down and away from traffic.
  • If your steps are steep, you might mount slightly lower than Ring’s generic “about chest height” advice. Check Live View until you see faces clearly but not every car on the street.
5. Quick pros & cons snapshot for the Ring Doorbell itself
  • Pros
    • Integrates well with phones and smart displays once WiFi is solid.
    • Motion zones and “people only” settings can cut down on spam alerts.
    • Works flexible: battery-only, wired-only, or battery + wired depending on your model.
  • Cons
    • Very picky about WiFi quality. Weak RSSI means lag and missed events.
    • Older mechanical chimes sometimes misbehave unless settings are dialed in or you upgrade hardware.
    • Cold climates + lots of motion = frequent recharging if you run it only on battery.
6. How to use the advice from others here
  • @sterrenkijker nailed the clean step-by-step install flow. If you want a literal checklist, follow that.
  • @mikeappsreviewer added the transformer and chime nuance, which is important if you want the old chime working reliably.
Where you can customize beyond their posts:
  • Start on battery if you are unsure about wiring.
  • Fix WiFi placement before you blame the device.
  • Use Live View as your “laser level” to choose height and angle, not just the template in the box.
If you share which exact Ring Doorbell model you have, whether you see thin low voltage wires at the old button, and roughly how far your router is from the door, it is possible to call out a very specific “do this, skip that” so you do not break anything.
