Need help clearing cookies and cache on iPhone?
My iPhone has been running slowly lately, and I think it might be due to a build-up of cookies and cache. I want to clear them, but I’m not sure how to do it. Can someone guide me through the steps?
Sure thing! Let’s talk iPhone maintenance 101. First, to clear cookies and cache on your iPhone, follow these simple steps:
  1. Open Settings: Tap the gear icon.
  2. Scroll to Safari: It’s the browser you’re probably using.
  3. Clear History and Website Data: Tap this option. It’s hard to miss.
  4. Confirm: A pop-up will ask if you really want to do this. Tap Clear History and Data.
For other apps:
  1. Settings: Go back here.
  2. General: Scroll down and tap on this.
  3. iPhone Storage: This shows all apps.
  4. Single Out Apps: Click on each app to see if it has an option to clear cache or only delete and reinstall.
If that doesn’t help, maybe your phone’s just tired. It happens to the best of us.
Check out this detailed tutorial on how to clear cache on iPhone for faster performance and more storage space. Follow easy steps to enhance your iPhone experience.
You can blame cookies and cache for your iPhone’s sluggishness, sure. But have you made sure it’s not filled with useless apps and pics as well? Anyway, here’s another way to tackle the issue:
  1. Open Settings: The gear icon is your new best friend.
  2. Scroll and Tap on Safari: Assuming you’re using Safari for browsing, of course.
  3. Scroll Down to Advanced: Yep, hidden here.
  4. Tap Website Data: See how much junk is in there.
  5. Remove All Website Data: Confirm and watch the magic.
Now, for apps that are misbehaving:
  1. Settings: You’re here again.
  2. General: Tap it.
  3. iPhone Storage: Takes a bit to load.
  4. Pick Offending Apps: Some apps let you clear cache without uninstalling. If not, just delete and reinstall.
Let’s be real; sometimes clearing cache is just a temporary fix. If your phone continues to drag, consider a reset or even a visit to an Apple store. Or maybe, just maybe, it’s time for an upgrade.
Follow these simple steps to significantly boost performance and storage: How to Clear Cache on iPhone in 2025.
