Need easy way to hide certain apps on my Android phone
I’m trying to hide a few apps on my Android so they don’t show up on the home screen or app drawer, but I don’t want to uninstall them or lock the whole phone. I’ve checked my phone settings and launcher options, but it’s confusing and I’m not sure what’s safe or actually hidden versus just disabled. Can anyone explain the best methods or apps to really hide apps on Android while still being able to use them when needed?
Short version. You have three main options, depending on your phone and how sneaky you need this to be.
  1. Use your launcher’s “Hide apps” feature
    This is the easiest if your phone supports it.
Examples
• Samsung (One UI):
  • Long press home screen.
  • Tap Settings or Home screen settings.
  • Tap Hide apps or Hide apps on Home and Apps screens.
  • Pick the apps, tap Done.
  • App still works through search or direct links, but not in drawer.
• Xiaomi / Redmi / POCO (MIUI / HyperOS):
  • Settings.
  • Apps.
  • App lock. Turn it on.
  • Tap Hidden apps.
  • Pick the apps.
  • Open hidden apps by pinch-out gesture on home screen or special area.
• OnePlus / Realme / Oppo (App lock / Hide apps / Private Safe):
  • Settings.
  • Privacy or Security.
  • Look for Hide apps or App lock.
  • Enable and choose apps.
If your launcher supports it, this is enough for most people.
  1. Use a third party launcher with hide feature
    If your stock launcher has no hide option.
Two common ones: Nova Launcher and Microsoft Launcher.
Example Nova Launcher:
• Install Nova Launcher from Play Store.
• Set it as default home app.
• Nova Settings.
• App drawer.
• Hide apps.
• Tick the apps you want gone from drawer.
They still exist, still get notifications, still open from search or direct links.
This is not strong privacy, more like “don’t show these icons”.
  1. Use work profile / island type tools
    If you want more control.
Tools like “Shelter” or “Island” use Android’s work profile system.
Basic flow with Shelter:
• Install Shelter from Play Store.
• Create work profile when it asks.
• Clone or move apps into the work profile.
• Disable the work profile to hide all its apps in one tap.
Pros
• Toggling work profile hides apps and their notifications.
• No uninstall needed.
Cons
• A bit more technical.
• Icons usually show in a separate tab or folder when profile is on.
Extra tricks if nothing else works
• Disable app in Settings if it is a system app you do not use often.
Settings → Apps → [App] → Disable.
It vanishes from drawer, but also stops working.
• Make a folder called “System stuff” or “Tools” and dump your “hidden” apps there on the last home page. Not real hiding, but most people will never swipe there.
What I would do
  1. Check if your phone’s launcher has a native Hide apps menu.
  2. If not, install Nova Launcher and hide from its settings.
  3. If you need more privacy from snoopy people, use Shelter or a work profile, then turn the profile off when you do not need those apps.
If you tell your exact phone model and Android version, people here can give step by step taps for your device.
If your launcher tricks and the usual “hide apps” toggles aren’t cutting it, you’re basically running into the limits of what Android is willing to hide without treating you like an IT admin. @techchizkid covered the launcher / work profile angle pretty well, so I’ll skip rehashing that and hit some alternatives and caveats.
1. Use “guest” or secondary user profiles
If you’re trying to hide apps from other people using your phone occasionally (family, partner, kids), a separate user is often cleaner than app hiding.
What it does:
Each user profile has its own set of apps and home screen. Apps in your main profile are invisible inside the Guest/other user profile and vice versa.
How to check:
  • Settings → System → Multiple users / Users
    • Turn on “Allow multiple users” or similar
    • Add user or enable Guest
Install or keep the “sensitive” apps only in your main account. When someone wants to use your phone, just switch them into Guest or the secondary user. No icons, no notifications from the hidden stuff in your main profile.
  • Way harder for casual snoopers to stumble onto stuff.
  • Clean separation of data, notifications, history.
  • User switching takes a few taps.
  • Not available on some OEMs or carriers because… reasons.
Honestly, for hiding from other humans rather than yourself, this beats most launcher tricks.
2. Use “Secure Folder” / Private Space type features
On some devices, hiding is basically built in but under a different marketing name:
  • Samsung: Secure Folder
  • Honor / Huawei: PrivateSpace
  • Some others: “Private Space,” “Second Space,” etc.
Instead of just hiding icons, these features:
  • Put selected apps and data in a locked container
  • Optionally hide the container icon itself or make it look boring
  • Keep notifications hidden or generic
If your phone has one of these in Settings under Security / Privacy, it’s usually more robust than a plain “hide app” list.
I’ll slightly disagree with the “work profile apps like Shelter are always the best for privacy” angle: for non-techy users, Secure Folder–style stuff is actually less confusing and less likely to break your notifications or create duplicate apps all over the place.
3. Turn notifications and suggestions off for the hidden apps
Even with hiding, people forget these:
  • Turn off notifications for that app so no banner or preview betrays it.
    • Settings → Apps → [Your app] → Notifications → Off / minimize / hide content.
  • Turn off search & usage suggestions:
    Some launchers and Google app show “recently used” apps or “frequent apps.”
    • Long press home screen → Home settings → Suggestions / Smart suggestions.
    • Or in Google app → Settings → General → disable suggestions that show apps.
You can hide the icon all day, but if your last used app sits at the top of recent apps, someone nosy will still see it.
4. Use “dummy” alternatives and decoys
If you’re trying to be subtle:
  • Replace the visible app with a “clean” alternative.
    Example: keep a normal chat or browser up front, real one in a hidden profile / folder.
  • For vault-style apps that hide things, choose one with an innocent icon and name. Avoid those obviously titled “HIDE EVERYTHING” that scream “click me.”
Some people use a second browser with no synced history in the main profile and the “main” browser only inside Secure Folder or a secondary user.
5. Be realistic about what “hiding” means
This part most people skip:
  • Apps you haven’t fully disabled can usually still be:
    • Seen under Settings → Apps
    • Seen in Play Store → Manage apps
  • Any moderately techy person who has full, unlocked access to your phone for more than a minute can find some trace via Settings, not just the home screen.
If the threat model is “curious partner who only glances at your phone screen,” hiding icons + muting notifications + suggestion cleanup is fine.
If it’s “someone determined and tech comfortable,” you really want:
  • Separate user profile
  • Secure Folder / Private Space
  • Or simply: do not keep that stuff on a device other people can rummage through at will
6. If everything on your device is locked down by OEM
Some budget or carrier versions neuter multiple users, Secure Folder, and even custom launchers.
In that worst-case scenario:
  • Dump the apps into a boring folder on the last home page.
  • Rename folder to something no one wants to tap (Example: “Carrier Tools” or “System Services”).
  • Turn notifications and suggestions off.
  • Clear recents often.
Not pretty, not high security, but for casual glance-proofing it can be “good enough.”
If you drop your phone model and Android version, someone can usually point to a more specific feature on your exact skin. Right now you might just be missing a Privacy / Security / Users menu that would make this way easier.
Short version: once you hit the limits of your launcher and built‑in “hide app” toggles, your options are basically to (1) disguise apps instead of hiding them, or (2) split where they live so they are less visible in normal use.
I’ll bounce off what @techchizkid already covered (guest / work profile / Secure Folder). All solid, but there are a few extra angles and some tradeoffs worth calling out.
1. Disguise instead of hide
If you can’t truly hide, camouflage works surprisingly well.
What you can do:
  • Use an app that:
    • Renames itself to something boring (like “System Services” or “Backup Manager”).
    • Changes icon to a generic gear / settings logo.
  • Put that app into a folder with other boring stuff:
    • Example folder names:
      • “SIM Tools”
      • “Device Help”
      • “System Updates”
Effectively you’re not hiding it from Android, just from humans who casually swipe around.
Cons vs what @techchizkid suggested:
  • Unlike a proper Secure Folder or second user, the data is still in your main profile.
  • Someone techy going into Settings → Apps can still spot it.
  • Fast to set up.
  • Works even on phones locked down by carriers that block extra profiles or fancy privacy features.
2. Hide your tracks in “Recents” and default apps
Even if the icon is invisible, your last used apps can still betray you.
Do this:
  • Open Recents view and clear it often, especially after using anything sensitive.
  • Change your default apps:
    • If the hidden thing is a browser / gallery / messenger, set a boring one as default.
    • That way, when someone taps a link or an image, it does not suddenly jump into your “hidden” app.
This is the part people usually skip. @techchizkid talked about notification and suggestion cleanup, but Recents + default apps are equally loud.
3. Think about backups and sync
One thing the “Secure Folder / PrivateSpace / second user” crowd rarely mentions: backups.
If you stash sensitive apps in any kind of separate space, check:
  • Does that space sync to a cloud account with its own login?
  • Are those backups visible from a laptop or web dashboard?
If yes, anyone who knows that cloud password could see the apps or data even if your phone looks clean.
So:
  • For ultra‑sensitive stuff, consider disabling cloud backup just for those particular apps.
  • Or keep them in a profile or folder that is not tied to your main Google / OEM account if your device allows that.
This is one place where I slightly disagree with leaning too heavily on OEM secure spaces alone. They are convenient, but many users never realize how or where that data is getting backed up.
4. Security level vs effort: be realistic
Break it down by who you are hiding from:
  • Glance‑level snoops
    Just looking at your home screen or opening your app drawer for a second.
    • Camouflage icon and name
    • Disable its notifications
    • Clear from Recents
  • Casual but curious
    Might open Play Store or scroll through apps.
    • Separate profile / Secure Folder / work profile if possible
    • Or deeper disguise with boring folder names, no notifications, no cloud sync
  • Tech‑savvy & determined
    Has time and knows where Settings → Apps, Play Store → Manage, and system logs are.
    • Real answer: do not keep stuff you are truly worried about on a shared or inspected device at all
No trick on a single unlocked user profile will defeat someone motivated who knows Android basics.
5. Brief note on “” (and pros / cons)
Since launcher tricks are giving you trouble, privacy‑focused tools like “” sometimes show up in searches around this topic. They tend to behave like a hybrid of a vault and a disguised app.
  • Often let you hide or mask sensitive icons under a bland name.
  • Some support additional locking (PIN / fingerprint) just for the hidden section.
  • Can centralize sensitive apps and files so you don’t have to configure each individually.
  • If the disguise is obvious (fake calculator, “vault” in the name), it can attract more attention than it removes.
  • Extra layer means extra maintenance: app updates, compatibility with your Android version, possible performance hits.
  • Still usually visible somewhere in Settings or Play Store if someone knows what to look for.
Compared to the built‑in guest / Secure Folder solutions that @techchizkid mentioned, these kinds of tools are more flexible on locked‑down phones, but they also rely on you trusting a third‑party developer with sensitive data.
Bottom line: since launcher hiding already hit its ceiling for you, I’d focus on (1) camouflaging, (2) clearing traces in Recents and notifications, and (3) deciding if your situation actually deserves the overhead of a separate user / secure space or if you just need to beat casual glances.
