I just bought my first pool table and I’m not sure how to set it up correctly. I’m worried about leveling it, placing it in the right spot, and assembling the rails and pockets so it plays true. Can anyone walk me through the correct way to set up a pool table step by step, including any tools I’ll need and common mistakes to avoid?
First thing, place matters more than most people expect.
Room size and placement
• For 8 ft table, you want about 13 ft x 16 ft minimum with 57 inch cues.
• For 7 ft, about 12.5 x 15.5 ft.
• Leave equal space on all sides if you can.
• Keep it away from direct sun and big vents. Slate hates temp swings and moisture. -
Get the base roughly level before slate
• Put the frame roughly where you want it.
• Use shims under the legs, not under the frame rails. Composite or metal shims are better than wood.
• Use a 4 ft spirit level. Put it lengthwise, then crosswise. Get it close, do not chase perfection yet. -
Slate setup
If it is 3 piece slate:
• Lay the middle piece first, centered.
• Then head and foot slates, push them tight to the center and to each other.
• Use slate screws in every hole, snug but not overtight. No stripped holes.
• Check seams. If you feel a lip with your fingernail, fix it. Use playing cards or thin shims under the slate screws to raise low corners. -
Leveling the slate
• Put the level along the long center line, then on both sides, then across at several points.
• Adjust by loosening a slate screw, adding or removing a shim under the slate, then retighten.
• Do not shim under cushions. Only under slate or leg points.
Take your time here. This decides how true it plays. -
Seaming the slate
• Fill seams and screw heads with beeswax or billiard slate putty.
• With wax, heat it, drip into seams, then scrape flush with a wide putty knife.
• Surface must feel flat, not bumpy or sticky.
If you feel ridges through the cloth later, it messes with slow rolls. -
Cloth on the slate
• Start at head end, staple under the slate backing or on the underside of the frame depending on table design.
• Pull to the foot end, firm and even, then staple.
• Then do sides, starting at middle, working to corners. Pull along the length of the table, not straight down.
• You want no wrinkles, no soft spots.
Take care around pockets, cut small relief cuts, tuck clean, then staple. -
Rails and cushions
• Make sure rail rubber is not rock hard or falling off. If it is, you will need it replaced.
• When installing rails, tighten bolts in sequence, not one side all the way then the other.
• Pocket liners should sit flat with no big gaps at slate.
• Check pocket openings. Standard for home 8 ft is around 4.5 inch at corners, 5 inch at sides. Overly tight or huge will feel bad. -
Final level check with balls
Numbers help here.
• A standard pool ball weighs about 6 oz and is 2.25 inches. It will roll off line on a slope over about 0.02 inches per foot.
Practical version:
• Roll a ball slow from each rail straight toward the opposite rail.
• If it drifts consistently the same way on the whole table, adjust one end of the table using leg shims.
• If only one area is off, adjust slate shims near that spot. -
Lighting
• Center a light fixture over the table, about 32 to 36 inches above the cloth.
• You want even light, no hard shadows, no glare in your eyes on shots. -
Common mistakes to avoid
• Leveling on carpet without checking again a few days later. Carpet compresses.
• Using short torpedo levels only. Longer level shows the real story.
• Overstretching cloth so it tears at staple lines.
• Leaving seams unfilled or screws high.
• Obsessing over perfect numbers but not rolling balls to test.
If you share table size, brand, and whether it is 1 piece or 3 piece slate, people here can give you more direct steps for your exact model.
@mike34 covered the “how to” really solidly, so I’ll hit the stuff people usually find out the hard way and a couple places I slightly disagree.
- Location & room use
Everyone talks about cue clearance, but think about how you actually live in that room.
- Leave a “walk lane” on at least one long side so people aren’t constantly squeezing behind shooters.
- Avoid putting the table exactly centered in the room if it means every door, closet and window is annoying to reach. Slightly off-center is fine if cueing still works.
- If you’ve got low pendant lights or a fan, measure swing height before you finalize the table spot. Fan blades chewing cues is… memorable.
Carpet vs hard floor
On carpet, I’d seriously consider cutting out small pads of carpet just under the leg positions and setting the legs directly on the subfloor with furniture cups. @mike34 is right that carpet settles; I just prefer eliminating that variable instead of releveling 3 times.
On hard floors, use non-slip leg cups. The table can “walk” a bit over time if the floor is slick. -
Tools that actually help
- Get a machinist level if you can borrow one. A 4 ft level is fine, but a precision level across the slates is a different world.
- A feeler gauge or even thin business cards help you verify microscopic lips between slates. If you can slip one card under one slate but not the next, you’ve got a ridge.
Slate seams & fill
I’m less of a fan of beeswax in hot climates. It can get a bit soft and print through the cloth over time. If you live somewhere warm or your room gets hot, I’d lean to billiard slate putty or Durham’s water putty instead. It sets harder and stays put.
Key thing: super thin. People overfill, then sand like crazy, and end up with a shallow “valley” on slow rolls. -
Cloth tension & speed
A lot of DIY installs end up way too tight. That makes the table lightning fast, cushions feel “lively” in a bad way, and balls rattle more in the pockets.
Guideline: pull firm so there are no wrinkles, but if you see the weave starting to “white out” at the staple edge, you are overdoing it. I’d rather you be a hair on the looser side than rip the cloth or distort it around the pockets. -
Rails & pocket behavior
Instead of obsessing about exact opening measurements, focus on:
- Pocket facing angle. If the facings are too square, balls jaw and spit. Slightly rounded facings help balls funnel in.
- Rail height. Top of cushion should be right around half a ball above the slate (so the ball hits mid-rubber). If it rides high or low, bank angles and speed get weird.
When you reassemble, shoot a few test shots: - Long rail bank: hit center diamond to opposite center diamond. If it comes up noticeably short or long on both sides, your cushions or cloth tension are off.
- Humidity and long term leveling
People level once and forget it. Big mistake. Slate and wood frame react to seasons.
- If you’re in a humid area, check level every 3 to 6 months, especially the first year.
- If it is in a basement, use a dehumidifier; that is as important as the initial leveling.
Safety & weight
If it is 3-piece slate, do not try to manhandle a piece alone. They crack if twisted even slightly. Use at least two people per piece and carry close to vertical, not flat and flexing.
Also, check the floor structure if it is an older house and the table is on an upper level. An 8 ft slate table can be 700 to 900 pounds. Put it perpendicular to floor joists when possible. -
When to call a pro
If any of this starts feeling like surgery instead of a weekend project, pay a local installer for the slate/cloth/rails portion and just handle positioning and room setup yourself. The difference in play between an “okay” DIY job and a good mechanic is huge, especially on long, slow rolls.
Once you’re “done,” ignore the level for a minute and trust the balls:
- Slow rolls from all four corners toward the middle.
- If they consistently drift the same direction in the same area, tweak that specific leg corner or slate shim.
Do that final step and you’ll know the table is not just “level” on paper, but actually plays true.
