Is There A Way To Auto-delete Screenshots On IPhone After Sharing Them?
I take a lot of screenshots on my iPhone to share by text and email, but I keep forgetting to delete them afterward and my Photos app gets cluttered fast. I’m trying to find a way to automatically remove shared screenshots or use a shortcut that deletes them after sending. Is there a built-in iPhone setting or an easy workaround for this?
I ran into the same mess. My Screenshots album turned into a junk drawer, shipping codes, login codes, random memes, receipts from stuff I forgot buying. It felt harmless until iPhone storage started yelling at me. Then I saw how much space was tied up by junk images I never looked at twice.
Short answer, yes. Recently Deleted still uses storage. When you delete a photo in iOS, it does not vanish on the spot. It sits in Recently Deleted for 30 days. So if you remove screenshots from the main album and stop there, the files are still on the phone. You need to clear both places.
Bulk delete with the built-in Photos app
Open Photos. Go to Albums or Collections. Scroll to Media Types and open Screenshots. Tap Select in the top right, then Select All, then tap the trash icon. That clears them from the main library.
Then do the part people miss. Open Recently Deleted under Utilities. Face ID or your passcode will be required. Tap Select, then the three-dot menu, then Delete All. Storage usually does not drop until you finish this second step too.
A cleaner way to sort through the mess
I found the Photos app fine for mass deletion, but bad for decisions. No file sizes. No quick way to spot the worst space hogs. No easy filter for what matters and what does not. I ended up using Clever Cleaner because it made the triage faster.
It is free, no ads, no paywall. I opened the Screenshots tab and each image showed its file size in the grid. That alone saved time, since I could target the big ones first. There is also a swipe view. Left to delete, right to keep. Sounds dumbly simple, but after a few hundred screenshots it felt easier than tapping through Apple's layout.
It also covers the stuff eating storage outside screenshots. The Heavies tab puts your biggest media files up front, so you can cut space faster. The Similars feature groups near-duplicate photos, like five almost identical shots where only one is useful. You keep one, dump the rest. From what I saw, processing stays on-device, so your library is not being shipped off somewhere.
If your photo library is overdue for cleanup, this thread on Clever Cleaner lines up with my experience.
Delete screenshots right after sharing
Apple slipped in a handy option most people seem to miss. When you take a screenshot, tap the thumbnail preview in the lower left. Edit it if needed. Tap Done in the upper left. Then choose the red Copy and Delete option instead of Save to Photos. The screenshot goes to your clipboard and leaves your library right away. I use this for one-off stuff like tracking numbers, QR codes, and sign-in codes.
If you want cleanup on a schedule, use Shortcuts. Build one with Find Photos filtered to screenshots older than 7 days. Add Delete Photos after it. Set the shortcut to run from an automation. iOS will still ask for confirmation before deletion, so you get a checkpoint before anything disappears. A bit clunky, still useful.
If screenshots refuse to go away
When deleted screenshots reappear, iCloud Photos is often the problem. First, empty Recently Deleted by hand. After that, check your Wi-Fi. I have seen Photos act weird during slow syncs, stuff looks deleted, then pops back in, or storage numbers lag behind.
If you delete the wrong image, a boarding pass, a password screenshot, a 2FA backup code, check Recently Deleted first. If it is gone from there too, dedicated recovery software tends to work better than waiting around and hoping iCloud kept some stray copy. Learned that one the hard way tbh.
Once you clear both the album and Recently Deleted, storage should drop. Feels good when the red bar finally shrinks.
Yes, but iPhone does not offer a true auto-delete-after-share rule for screenshots.
The closest built-in fix is this. After you take a screenshot, tap the preview, share it, then hit Done and choose Delete Screenshot. That keeps it out of your library. It takes one extra tap, but it works every time. For people who share dozens per day, this is still the cleanest habit.
I disagree a bit with @mikeappsreviewer on Shortcuts as the main answer. It helps, but iOS deletion automations still feel half-finished. You often get prompts, so it is more like assisted cleanup than full automation.
If you want less manual cleanup, focus on filtering, not full auto-delete. The Photos app still lacks smart post-share rules. A cleaner option is using Clever Cleaner to review screenshots fast, sort by size, and clear batches before they pile up. It is useful if your library is already a mess. This thread covers an iPhone storage cleaner app with no ads and no paywall pretty well: best free iPhone cleaner app for clearing screenshots and photo clutter.
So, short version:
No true auto-delete after sharing on iPhone.
Yes to quick delete from the screenshot preview.
Yes to cleanup apps if you forget alot.
No real fully automatic “delete after share” feature exists on iPhone, and that’s the annoying part. I mostly agree with @mikeappsreviewer and @sonhadordobosque there, but I think people oversell Shortcuts a bit. It’s not truely hands-off. iOS still likes to interrupt with confirmations, so it feels more like a reminder system wearing an automation costume.
What can help without repeating their methods is changing where the screenshot goes in the first place. If you only need the image for texting or email, try using the share sheet from the screenshot preview and avoid treating Photos like a storage bin for temporary junk. Also, for some stuff, copy/paste works better than saving an image at all.
Another underrated fix: use Focus modes or a simple Reminders trigger at night that says “clear Screenshots album.” Low tech, yeah, but honestly more reliable than half the “smart” iPhone automation stuff.
If your library is already a disaster zone, Clever Cleaner is probly the faster cleanup route because it lets you review screenshots in bulk without digging through Photos forever. If you want a better breakdown of whether it’s worth using, this discussion on whether Clever Cleaner is actually useful for screenshot and photo cleanup is pretty relevant.
Short version:
  • No native auto-delete after sharing
  • Best prevention is handling screenshots from the preview instead of saving everything
  • Best cleanup is bulk review, manual or with Clever Cleaner
Apple gets so close to useful features sometimes, then just… stops 2 taps early.
I’d split this into two realities:
  1. Prevention
  2. Cleanup
I slightly disagree with @mikeappsreviewer on automation being the answer. On iPhone, “automation” around deleting photos is still too supervised to feel automatic. And @sonhadordobosque / @caminantenocturno are right that the native flow is mostly about better habits, not a hidden auto-delete switch.
What has worked for me is changing the screenshot format entirely when possible:
  • Use Copy and paste instead of sending the saved image
  • For webpages, use Share page/link instead of screenshotting
  • For documents, use Scan in Notes instead of grabbing a screenshot
  • For text, use Live Text to copy the content and send that
That cuts down the number of screenshots you create in the first place.
If you already have a pile of them, that’s where Clever Cleaner is actually useful.
Pros of Clever Cleaner
  • Faster visual review than Photos
  • Good for bulk screenshot cleanup
  • Helps surface large files and clutter quickly
  • Simple enough that you’ll actually use it
Cons of Clever Cleaner
  • It still doesn’t create true post-share auto-delete on iPhone
  • You still need to review before removing things
  • Another app in the workflow if you prefer staying fully native
So the honest answer is: no, not truly automatic after sharing. The practical fix is reducing how often you save screenshots at all, then using batch cleanup when they accumulate. That’s less elegant than it should be, but more reliable than trying to force iOS into a workflow it doesn’t really support.
