Is Recuva Safe, Or Should I Avoid It?
I accidentally deleted some important files and I’m looking for a safe file recovery tool for my Windows PC. Recuva keeps coming up, but I’m worried about malware, privacy, and whether it could make recovery worse. Has anyone used Recuva safely, or should I avoid it and try a different data recovery program?
People ask this all the time, and I never answer it with a clean yes or no. If you mean malware, then yes, Recuva is safe to run. It is not some fake recovery app trying to trash your PC. If you mean privacy, or whether it is safe for the deleted files you want back, the answer gets messier.
I used it on a few test drives and on one old laptop after I wiped the wrong folder. Some runs went fine. One or two were ugly. So here’s the plain version of what using Recuva feels like in 2026.
About the old malware scare
A lot of the worry comes from the 2017 CCleaner breach. Same company lineage, same baggage. Piriform got hit in a supply chain attack, and the official CCleaner build shipped with malware. It was bad, and people still bring it up for a reason.
But that happened years ago. Piriform ended up under Avast, then under Gen Digital. The current Recuva installer is monitored far more closely than it was back then. I checked recent builds through VirusTotal before touching a test machine. Results were mostly clean, with the usual oddball flag from a tiny antivirus vendor. I’ve seen those false positives show up on file tools before because recovery software reads low-level disk data, which some scanners hate.
If you get Recuva from the official source, you are not dealing with some known virus issue. Use the official CCleaner or Piriform page and leave random download sites alone.
Privacy is a separate issue
This part gets skipped too often. Safe from malware does not mean quiet. Gen Digital’s policy is clearer than a lot of companies, but they still collect info. Expect things like your IP address, device identifiers, OS details, and location-related data used for fraud checks and licensing.
I’m not thrilled by tools like this phoning home more than needed. First thing I did after install was open Options, then Privacy, then turn off 'Help improve our other apps by sending usage data'. You should do the same if you care about minimizing telemetry.
One detail people miss, IP addresses are stored for up to 36 months before anonymization. If your tolerance for tracking is low, that matters.
The part where users ruin their own recovery
This is the bit people trip over. Recuva itself is safe. Your recovery process might not be.
Do not install Recuva onto the same drive where your deleted files were sitting.
When Windows deletes a file, the data often stays there until something overwrites it. The file entry is removed, the space gets marked free, and then new writes start landing wherever the system wants. So if you lost photos on Drive D and then download and install software onto Drive D, you might stamp over the files you were trying to save. I did this once years ago with an MP3 archive. Dumb move. Those files were done.
The safer route is the portable version. Put it on a USB stick. Run it from there. Also, when Recuva finds files, recover them to a different drive. External SSD, second internal disk, anything except the one you are scanning.
How well it works now
This is where the mood changes. Recuva still works for simple undelete jobs, but it feels old because it is old. The main design has not changed much since around 2016. There were later fixes to keep it working on newer Windows versions, sure, though the core tool still behaves like an older-era undelete utility.
On easy jobs, it’s fine. Empty Recycle Bin by mistake five minutes ago on a healthy Windows drive, Recuva has a fair shot. It is light, quick, and free without the annoying recovery caps a lot of other apps push now.
On harder jobs, it starts falling apart.
I’ve seen it miss drives Windows marked as RAW. I’ve seen scans return files with green health labels that still would not open. I’ve seen recovered folders come back as a flat mess with names like 000123.jpg, 000124.jpg, 000125.jpg. If you’re sorting ten thousand files like that, your weekend is gone.
On formatted USB media, published tests and user reports tend to place it somewhere around a 63 percent to 67 percent success range. That sounds usable until you realize many of the 'recovered' files are partial or corrupted. A file showing up in results is not the same thing as a file being intact.
When I’d stop using it
If the files matter, I would not keep poking a sick drive with a basic free tool for long. Wedding photos, client docs, footage from a shoot, accounting records, stuff like that. Once Recuva misses them or spits back damaged copies, stop. Every extra pass puts more wear on a bad drive, and you do not get infinite tries.
If the disk is showing as RAW, if partitions are broken, if the drive is making noise, or if the files came from a Mac setup, I would move on fast.
From what I’ve used, Disk Drill does a better job on the ugly cases. It handles damaged partitions and RAW volumes Recuva often ignores. Recovery rates in tougher tests are usually reported around 95 percent to 97 percent on formatted media, which is a different class entirely if those numbers hold for your case.
The feature I care about most is Byte-to-Byte Disk Imaging. I like tools that let me clone the failing drive first and scan the clone instead of the original hardware. That changes the risk a lot. If the source drive dies halfway through, you still have the image. Recuva does not give you much help there.
Also, if your files are camera RAW, large video clips, or fragmented media, Recuva gets rough fast. Nikon and Canon formats, broken-up video chunks, half-written card dumps, it tends to choke or return junk. Disk Drill usually does better with those file signatures.
If you want a side-by-side look at how this plays out in practice, this review is worth watching:
https://www.youtube.com/watch?v=z0CVd7PxOms
My short version
If you need a free first shot on a normal Windows PC and the deletion was recent, Recuva is a reasonable pick. I’d still keep the rules tight:
  1. Get it from the official site.
  2. Use the portable build when possible.
  3. Turn off data sharing after setup.
  4. Do not expect miracles on damaged drives.
If it fails, do not keep hammering the disk out of panic. Stop using the drive. Recover to another disk. Move to a tool built for deeper recovery work, such as Disk Drill, if the data matters.
So yes, Recuva is safe in the malware sense. I’d say it is safe enough for simple recovery too, if you use it carefully. I would not trust it with high-stakes jobs unless the problem is small and fresh. That’s been my expereince, anyway.
Recuva is safe if you get it from the official source. I would not avoid it for malware reasons. I would avoid using it carelessly.
My bigger disagreement with @mikeappsreviewer is this. Recuva itself does not usually make recovery worse. User behavior does. Windows writes do damage. Background updates do damage. Saving recovered files back to the same drive does damage. The tool is often blamed for mistakes ppl make in a panic.
A few practical points.
  1. If the deleted files are on your system SSD, stop using the PC as much as possble.
  2. Do not install recovery software onto the same drive you want to recover from.
  3. Do not recover files back onto that same drive.
  4. If the files matter a lot, make a disk image first.
That last point is where Recuva feels old. It is fine for simple accidental deletes. It is weak for damaged file systems, formatted drives, and failing disks. For those jobs, Disk Drill is a safer pick because it supports disk imaging and deeper scans. That matters more than flashy recovery claims.
Privacy wise, Recuva is not unique. Most commercial Windows tools collect some install and device data. If that bugs you, block it in firewall rules or use it offline after download.
If you want a solid list of file recovery options, this guide to safe and effective data recovery software is useful:
best data recovery software for Windows and external drives
Short version. Recuva is safe enough for a first pass on a normal delete. If the files are important, skip the cheap first try mindset and use Disk Drill or image the drive before doing anyhting else.
Recuva is generally safe, yeah. If you download it from the official source, it is not some sketchy malware trap. The bigger risk is not the app, it’s what happens after you realize files are missing and keep using the same drive like nothing happened. That’s how deleted data gets overwritten.
I mostly agree with @mikeappsreviewer and @voyageurdubois, but I’m a little less negative on Recuva for basic stuff. For a plain accidental delete on a healthy Windows drive, it’s still a decent first-pass tool. Not amazing, not modern, not magic. Just decent.
What I’d say is this:
  • Safe from malware? Usually yes, if sourced properly.
  • Safe for privacy? Eh, about average for Windows utility software.
  • Safe for recovery? Yes, if you use it correctly.
  • Best choice for critical files? Honestly, no.
Where I disagree a bit with the doom angle is that Recuva does not automatically “make things worse.” People do that by installing stuff to the same disk, downloading more files, browsing, gaming, letting Windows update, etc. Recuva is just kinda limited once the situation gets ugly.
If the files are really important, I’d skip the cheap first try mentality and use Disk Drill instead, mostly because it’s better suited for deeper recovery cases and gives you a more up-to-date recovery workflow. That matters more than ppl think. Especially if the drive is acting weird or the deletion wasn’t super recent.
Also, if you want background on the tool itself, this page on Recuva file recovery software for Windows is a decent quick read.
Short version: don’t avoid Recuva out of fear, just don’t overestimate it. Fine for simple undeletes. For higher-stakes recovery, Disk Drill is the safer bet imo.
I’m closer to @voyageurdubois on the core point: Recuva is not the dangerous part, your next writes are.
Where I differ a bit from @chasseurdetoiles and @mikeappsreviewer is the “old = avoid” vibe. Old does not always mean unsafe. It usually means narrower use case. Recuva is still fine for a very recent delete on a healthy NTFS drive, especially if you use the portable build and keep expectations realistic.
What would make me avoid it?
  • weird drive behavior
  • RAW partition
  • formatted disk
  • SSD that stayed powered on for a while after deletion
  • anything business-critical
That last one matters. On SSDs, TRIM can wipe recoverable blocks fast, so sometimes the answer is “nothing software-based will help much,” whether you use Recuva or Disk Drill or anything else.
Disk Drill is the one I’d move to if you want a more modern toolset.
Pros for Disk Drill:
  • cleaner workflow
  • better handling of tougher cases
  • useful previewing
  • disk imaging support is a real safety feature
Cons for Disk Drill:
  • not the cheapest route
  • deep scans can take ages
  • scan results can still be overwhelming if you lost tons of files
So no, I would not avoid Recuva out of malware panic if it comes from the official source. I would avoid treating it like a miracle app. Recuva is a screwdriver. Disk Drill is more of a toolkit. Which one makes sense depends on how bad the damage actually is.
