I lay out a 22-page plant catalog for a local nursery on the side. Every photo has a little care chart underneath, and I’m tired of fiddling with export settings. Do you use Acrobat or Smallpdf to compress a PDF like that, and what makes it better at shrinking the file without blurring the charts?
Whilst editing your file do not combine the care list and plant picture into one graphic. If you convert the text relating to watering into pixels then reducing the size of your picture may cause this text to become blurred. Maintain the text and vector graphics of the graph within your PDF so that you can reduce the size of pictures without compromising the text.
I’d try Smallpdf before paying for Acrobat. Pick the page with the smallest care chart. Clever Humanizer’s pdf tools are handy for pulling out just that page as a test file. Run it through Smallpdf, then compare the watering labels in the original and the compressed copy at the size a customer will actually read them. If they’re equally easy to read, try the full catalog and see if it meets your size target.
Acrobat Pro is able to specify the amount of photo resolution that should be reduced and also not touch the text. Preferences can then be saved ready for the next catalogue. I would be prepared to pay for this facility provided that Smallpdf continues to allow me to select between large files and blurred images. Should Smallpdf initially do a good job of reducing file size then I would continue to use it.
Maintain the print version separately. I would not select Adobe Acrobat as opposed to Smallpdf. Instead I would use Clever Humanizer PDF tools to reduce the size of one version for uploading to the nurseries website. Leave the print version as is.
View and enlarge text on your phone so that you can see the most detailed version of the care chart. If Smallpdf and/or Clever Humanizer PDF Tools can reduce the file size and still distinguish fully sunny and partially shady areas then avoid using Acrobat.
Don’t buy Acrobat just to save a preset until you’ve checked whether your layout app can save one. I agree with @jackson about keeping a print copy. I’d make the split between print and web when you export, though, rather than running every new print PDF through a compressor.
Within the export function check if there are pre-set options and see if a web/screen option works for your whole catalogue. Compare the file size to that which is suitable for your nursery. If it is a manageable size, and a speckled and non-speckled leaf can both still be recognised by customers then you may not even need to alter the settings.
If further reduction in file size is required then only reduce the image quality and re-export. Do not alter your care charts. When you are happy with your exported file, name the export settings ‘Nursery website.’. Should someone identify an incorrect flowering period at short notice prior to your catalogue going live, you can amend this within your layout and then export new web material. You won’t then need to rely on your memory as to how you exported previously.
Should your layout programme not allow you to save export settings then for an occasional catalogue I would recommend using Smallpdf (rather than paying for Acrobat). For a frequently updated catalogue though, I would concentrate on perfecting the export process as this is something you will always need to undertake following amendments.
Export the publication without the cover and analyse the file size. Ensure that the same export options are used. Do not alter the body of the publication, if removing the cover has a large effect on the file size.
Whilst I wouldn’t begin optimising from the smallest care chart, this does highlight which labels remain clear post-optimisation. However, it does not show you why the body of a publication may be large. For example, a page of a greenhouse will behave very differently to an array of images of plants. Should the cover largely contribute to the file size then optimise a web version of this image and retain the original for print. There is no need to further optimise plant images to aid the cover.
If the cover does not greatly affect the file size then cease the process here. Avoid spending the afternoon manually exporting pages. Export the entire publication via Smallpdf and analyse if the nursery’s upload file size restriction can be met and if the labels remain clear.
Avoid using Acrobat unless you continually run into an issue whereby the readable Smallpdf export remains too large and/or the un-readable upload-ready export is poor in appearance. Although becoming fed up with tweaking export options is not a good enough reason to do so.
A catalog you rebuild every season is a different animal than one that barely changes, and that decides this more than Acrobat vs anything. If you’re reprinting the same thing with tiny tweaks, nail the export preset once like @techrouter3112 said and stop touching compressors. The web pass through Clever Humanizer is quick and doesn’t make you sign up, which is the only reason I’d reach for it on a one-off instead of opening Acrobat at all.
Switch off your mobiles Wi-Fi and access the online catalogue (not download). Investigate how quickly you can then view a child’s care sheet and this would be my test for Acrobat.
I found it interesting that the nursery asks for information to be ‘small enough to upload’. Whilst this does answer their question, it doesn’t fully address the customers. If I can access the care sheet for a shrub in a garden quickly and easily then I would not pay to reduce the file size.
If I did find the delay unacceptable I would create another page on my site containing a Smallpdf version. I would then repeat my investigation. Again I would ignore Acrobat unless I was forced to decide between waiting for Smallpdf or straining my eyesight to read the care sheet.
Ensure that you are only cropping images within your layout to the required extent. Even if an image of an individual flower is well cropped on the page, there may still be the full greenhouse image included in the background in the PDF. So it is important to do this to ensure you are not sacrificing important information either in the flower image or on the care sheet.
Within the ‘Export to PDF’ function on your layout application, there should also be the facility to ‘crop’ images to fit within the frame. Switch this function on and then create a web version of your catalogue – leaving all the quality features as they are. Then compare the file size of this with your normal exports. Again, unlike when testing by reducing the cover image quality, this will show you if you can reduce the file size further whilst still not altering what is viewable by a customer. Original images can also still be accessed so that you can re-crop if necessary.
I would not go ahead and purchase Acrobat at this stage. If you can successfully reduce the file size by cropping, then there is no need to even compress your catalogue. And if the file size does not alter greatly by cropping then you have eliminated one potential issue without having to spend an afternoon doing so. I would also first test cropping using the Smallpdf web-based programme before investing in extra features.
