My Mac keeps freezing when certain apps stop responding, and I’m not sure of the safest way to force quit them without risking data loss or messing up my system. I’ve tried waiting it out and restarting, but it’s happening more often and slowing down my work. Can someone explain the best way to force quit apps on a Mac, and when it’s okay to use it?
Here is what usually works and keeps risk low.
Use the standard Force Quit window
• Press Command + Option + Esc
• Select the frozen app
• Click Force Quit
This is the safest way. macOS isolates apps so killing one should not break the system. -
Use the Dock
• Right click the frozen app icon in the Dock
• Hold Option and click Force Quit
Same thing as the Force Quit window, just faster. -
Use Activity Monitor for stubborn apps
• Open Activity Monitor- Easiest: Press Command + Space, type “Activity Monitor”, hit Enter
• Find the app by name or sort by CPU to see what is stuck at 100 percent
• Select it
• Click the X button at the top
• Try “Quit” first, if nothing happens choose “Force Quit”
This gives you more control and lets you see if multiple processes of that app run.
Use Terminal if the whole UI struggles
Only if you feel ok with a bit of nerd stuff.
• Open Terminal
• Type:
ps aux | grep ‘AppName’
• Get the PID number of the main process
• Then run:
kill PID
• If it still hangs, run:
kill -9 PID
That last one is the most aggressive. Use it only when nothing else works.
How to reduce data loss risk
• Save often, especially in apps you know freeze
• Turn on autosave or “save backup copies” inside apps like Word, Excel, etc
• Before you force quit, wait 20 to 30 seconds to see if the app recovers and finishes a long task
• If the spinning beachball shows only in one app and the rest of the system works, force quit only that app, not the whole Mac
• If Finder hangs, try relaunching it instead of rebooting
- Option + right click Finder in Dock
- Click “Relaunch”
When to restart the whole Mac
• The cursor freezes or keyboard stops working
• Multiple apps stop responding
• You cannot open Force Quit window
If that happens, try a normal restart first from the Apple menu. If it does not respond, hold the power button until the screen goes black, wait a few seconds, then power on again. That is harsher, so do it only when you have no other choice.
If this happens often with the same app, check:
• App updates in the App Store or from the developer
• macOS updates in System Settings
• Free disk space, keep at least 10 to 15 percent free
• Login items in System Settings, remove stuff you do not need on startup
If one specific app keeps freezing even after updates, it is sometimes easier to switch to an alternative app instead of fighting it forever.
If you’re force quitting a lot, the real “safest” solution is to make it something you almost never need, instead of trying to find a magic no-risk kill button.
Couple of things that build on what @chasseurdetoiles already said, without rehashing the same shortcuts:
1. Figure out if it’s the app or the whole system choking
Before you kill anything, check:
- Can you move the mouse smoothly?
- Can you switch apps with Command + Tab?
- Does the clock in the menu bar keep updating?
If the answer is “yes” to those, it’s almost always safe to nuke just the one app. Data loss usually hits the current unsaved document in that app, not your whole Mac. If the entire system feels like molasses, the problem might be deeper, and repeated force quits won’t really fix it.
2. Prioritize apps that handle crashes well
Some apps are borderline suicidal with data:
- Apps like Apple’s own stuff, many editors, and some note apps have autosave / versions. Force quitting them is relatively low risk.
- Old cross‑platform junk, Electron apps, or poorly maintained tools are more likely to corrupt an open file if they’re mid‑write. For those, it’s worth giving them a bit longer before you kill them.
Test this once on a non‑important file: open a dummy document, make edits, wait for the freeze to happen, force quit, then see what comes back on relaunch. That tells you how risky that specific app is for your real work.
3. Protect yourself before the freeze
If your Mac is freezing “often,” you’re already in the territory where you should assume data loss will happen eventually and plan around it:
- Turn on any autosave / backup / “save backup copy” settings in your main work apps.
- Use cloud or versioning where possible (iCloud, Dropbox, Git, whatever fits).
- Keep plenty of free disk space. When macOS runs low, it can stall hard and make apps look “frozen” while it’s desperately swapping.
- Check memory pressure: too many big apps open at once = more beachballs.
4. Treat Finder and the system UI differently
I don’t totally agree with always treating Finder just like any other app. When Finder or the menu bar icons are freaking out repeatedly, that can hint at:
- Problematic Finder extensions
- Corrupted desktop files
- Network drives / external drives not responding
In that case, instead of constantly killing apps, try:
- Unplugging flaky external drives (after they stop blinking, ideally).
- Disconnecting problematic network shares.
- Removing weird Finder extensions or context menu utilities.
You’re not “messing up your system” with normal force quits, but if system stuff is regularly involved, it’s time to diagnose, not just kill.
5. Look for a pattern instead of one‑off kills
Every time you have to force quit, mentally log:
- Which app was it?
- What were you doing? (opening a huge file, waking from sleep, using an external monitor, etc.)
- Does it always happen after your Mac’s been on for days?
If you notice “It’s always after waking from sleep” or “Only when using this specific app,” that’s your clue:
- Reinstall or update that app.
- Try running your Mac for a day with less background junk (login items and menu bar helpers).
- If it only happens with an external monitor or dock, that hardware can absolutely trigger freezes.
6. The nuclear option is not the power button
Holding the power button is actually the riskiest everyday move, not force quitting one app. macOS is designed so killing a single app is relatively contained. Hard power offs interrupt everything including system‑level writes. So:
- Kill the offending app first.
- Only resort to holding power when keyboard, trackpad, and system UI are basically dead.
TL;DR: Keep using the standard force quit methods, they’re fine. The “safest” approach is:
- Confirm only one app is really stuck.
- Force quit just that app.
- Harden your workflow with autosave and backups.
- Track patterns and fix the underlying cause so you’re not stuck in an eternal force‑quit loop.
And yeah, sometimes the healthiest move is: if the same app is the villain every single time, just replace it. No amount of careful force quitting makes a badly coded app less garbage.
