How to drag and drop from Google Drive to desktop?
I’m trying to drag and drop files from Google Drive right onto my desktop, but it doesn’t work. I need these files quickly for a project, and clicking to download each one is too slow. Is there a way to make drag and drop work, or am I missing a setting?
Alright, let’s not overcomplicate things. Let’s say you want to scoop your files off Google Drive straight onto your computer, maybe because someone’s pinging you for that one overdue report or maybe because you’re organizing your endless mess of screenshots. Here’s what usually goes down:
The Classic: Google Drive Desktop App Shuffle
So, if you haven’t already, go snag the Google Drive app for desktop (doesn’t matter if you’re on Windows or Mac; Google’s got you covered). Sign in. Simple enough, right?
  1. Pop open the icon after it’s installed. Hit up “Settings” because, you know, there’s always a setting hiding somewhere.
  2. Crack open Google Drive using the app—there’s a handy-dandy “Open in Explorer” option (yeah, that’s Windows speak, but Mac folks get the gist—just open the thing in Finder).
  3. There you’ll see your Drive “magically” appear like any other folder. Browse to whatever you’re looking for.
  4. Now, just drag whatever file you want off of Drive and drop it onto your desktop. Like, for real, just drag and drop.
When You Start Moving WAY Too Much at Once
Here’s where things get annoying. Sure, this approach is fine if you just want a couple PDFs. But start getting greedy, yanking whole photo archives or chunky folders, and, well… the Google Drive app sometimes just nopes out. Transfers freeze, app crashes, or you just get that spinning “thinking” icon forever. You know how it goes.
The Workaround: CloudMounter Rides In
When Google’s own software is being a diva, there’s a workaround that’s saved me more than once. It’s called CloudMounter, and it’s not free, but hey—if you’re yanking huge volumes daily, it pays for itself in saved headaches.
Mount Google Drive as if it’s another hard drive right there on your computer (like it’s plugged in or something). Fire up your file manager (Windows = File Explorer, Mac = Finder), and suddenly your Drive files act just like they’re sitting on your local machine. Grab what you need, drop it onto your desktop, move on with your life. No drama, just transfer.
That’s how I survive my Google Drive extractions—basically, if the official tool chokes, swap it out. Hearing horror stories from friends and watching my own transfers fall apart taught me pretty quick that sometimes you need a little third-party muscle!
Anyways, give it a shot and let the forum know if you’ve got another method that actually works reliably.
Ugh, this whole Google Drive drag-and-drop thing is basically a cruel joke, right? You stare at that browser tab, click a file, try to drag it right smack onto your desktop and…nothing. Zero. Nada. It’s like Google loves teasing us with that false hope of seamless cloud living.
Simple answer: Browsers just don’t have direct access to your file system for security reasons, so dragging files from Google Drive in Chrome/Edge doesn’t do squat. Not a “broken” feature, just crappy UX.
Yeah, @mikeappsreviewer runs through the Drive desktop app angle, which is mostly fine until your system gasps for air. Me personally? Gave up after watching it lock up like a freeze frame in a bad reality show. Third party stuff like CloudMounter is cool IF you want to shell out cash and run one more thing in your menu bar, but I get that “not another app” fatigue.
Old-school move: Multi-file download. Hold Shift or Ctrl/Cmd, mass-select the files you want, right-click, and hit download. It zips 'em up. Sure, you gotta unzip afterward, but unless you’re hauling gigs every day, it’s fine. Not “instant” but better than babysitting fifty downloads.
Amazon cloud users, Dropbox, same deal. The browser’s sandboxed, unless you give some app more rope. Annoying, yes, but safer in theory (lol). If anyone’s cracked real browser drag-and-drop from Google Drive to desktop—no app, no plugin—please, let us know. Otherwise, gotta live with Google’s piecemeal approach or get creative with third-party tools like CloudMounter. Not pretty, but that’s life in the cloud, I guess.
Yeah, it’s the ultimate tease: you stare at Google Drive in your browser, drag a file toward your desktop, and… nothing. Just a limp “nope” cursor, like the world’s meanest prank. Honestly, I’m convinced Google keeps it this way to herd us all into their apps. Browsers can sometimes allow drag and drop for downloads (like dragging images), but with Google Drive files it’s a security wall—browsers are sandboxed, so they can’t just pluck files off Drive and throw them on your desktop (unless it’s a photo or something particularly cooperative, but actual Docs or big files? Nope).
Some folks above hit the desktop app and third-party tool angle. Personally, the “Install Yet Another App” approach just makes my CPU fan scream in protest. Had the Drive desktop app melt down on me mid-transfer more than once. @mikeappsreviewer’s trick about settings works, but only up to a point. @sternenwanderer’s CloudMounter shout is solid if you’re up for paying and running more stuff in your tray or menu bar.
What no one is talking about: Google Takeout. If you’re trying to bulk export a ton of stuff and can’t stand manual zipping or desktop apps, Takeout actually gives you a full fat export of everything, no fuss, no browser-meddling. Downside? You might wait ages, and the zip files are gigantic.
Still, we shouldn’t need a hack or an extra app for something so basic, right? But unless you want to live dangerously with browser extensions (which can get sketchy fast, privacy-wise), it’s either:
A) Install Google Drive for Desktop and deal with its quirks
B) Embrace third-party managers like CloudMounter (which genuinely does what Google should’ve years ago)
C) Mass-download and extract zips
D) Scream into your keyboard about the state of modern cloud UX
I’m honestly curious if anyone’s actually seen straight-up drag and drop from the browser to desktop work on any cloud platform, ever. I’ve just come to expect disappointment and bloatware. Anyone cracked this with some weird extension or maybe a hidden Chrome flag?
TL;DR: Nope, browser can’t do it (not a bug, “it’s a feature!”). Try the Drive app, CloudMounter, or curse the cloud gods. Welcome to a world where download buttons still rule.
Use the “Download” folder trick.
  1. In Drive, select the files you need.
  2. Right click, choose “Download”.
  3. Your browser saves them to the default downloads folder.
  4. Open that folder once and keep it next to your desktop.
  5. Drag files from Downloads to your desktop.
Example on Windows: press Win+E, open Downloads, sort by “Date modified”.
You grab the newest files fast, without extra apps or Drive syncing.
