How To Clear Cache And Cookies On Mac
My Mac’s browser has gotten really slow and some sites won’t load or keep logging me out. I’ve read that clearing cache and cookies might fix it, but I’m worried about losing important data, saved logins, and site preferences. Can someone walk me through the safest way to clear cache and cookies on a Mac (Safari and Chrome) and explain what I should back up or expect to lose before I do it?
Yeah, clearing cache and cookies on a Mac browser can help with slow pages and weird logouts, but you are right to worry about losing saved stuff. Here is how to do it with the least pain.
First thing. Your saved passwords in the browser are separate from cookies and cache. As long as you do not choose options that say “Passwords” or “AutoFill” you keep those.
I’ll split it by browser.
Safari on Mac
  1. Back up what matters
    • Open Safari.
    • Go to Safari > Settings (or Preferences on older macOS) > Passwords.
    • Check your saved logins are there.
    • If you want, export them: click the three dots, Export Passwords, save to a safe place.
  2. Clear cache only, keep most logins
    • In Safari menu, click Settings > Advanced.
    • At the bottom, check “Show Develop menu in menu bar”.
    • Now in the menu bar click Develop > Empty Caches.
    • This clears the cache and keeps cookies and logins.
  3. Clear cookies for problem sites only
    • Go to Safari > Settings > Privacy.
    • Click “Manage Website Data”.
    • In the search box type the site that causes issues.
    • Select it, click Remove.
    • This logs you out of that site, but keeps others intact.
  4. Clear everything if things are still broken
    • Same place, Safari > Settings > Privacy > Manage Website Data.
    • Click “Remove All”.
    • This wipes cookies and site data. Expect to log in again on most websites and lose some site preferences.
Chrome on Mac
  1. Check saved passwords
    • Open Chrome.
    • Go to chrome://settings/passwords in the address bar.
    • Make sure your logins are there.
    • Optionally click the three dots next to “Saved Passwords” and export.
  2. Use “Clear browsing data” carefully
    • Press Command + Shift + Delete.
    • Or Menu (three dots) > Settings > Privacy and security > Clear browsing data.
  3. Recommended options if you want to keep logins
    • Time range: “Last 4 weeks” or “All time” if things are bad.
    • On the Basic tab:
      • Check “Cached images and files”.
      • Uncheck “Cookies and other site data” if you want to stay logged in.
    • Click Clear data.
  4. When you need to reset logins for broken sites
    • Same window, but this time:
      • Check “Cookies and other site data”.
    • This logs you out of most accounts.
    • Your saved passwords in Chrome stay, you will log in again, Chrome will autofill.
  5. Clear cookies for single sites
    • Open the site that acts up.
    • Click the lock icon in the address bar.
    • Click “Cookies” or “Site settings” depending on version.
    • Remove or clear data only for that domain.
Firefox on Mac
  1. Confirm saved passwords
    • Open Firefox.
    • Go to Settings > Privacy & Security.
    • Scroll to “Logins and Passwords”.
    • Click “Saved Logins” to confirm.
    • Export if you want a backup.
  2. Clear cache only
    • Same page, under “Cookies and Site Data”.
    • Click “Clear Data”.
    • Uncheck “Cookies and Site Data”.
    • Leave “Cached Web Content” checked.
    • Click Clear.
  3. Clear cookies for a few sites
    • On the Privacy & Security page, under “Cookies and Site Data”.
    • Click “Manage Data”.
    • Search for the problem site.
    • Remove it.
  4. Full clear if nothing works
    • “Clear Data”.
    • Check both “Cookies and Site Data” and “Cached Web Content”.
    • Click Clear.
Extra stuff that helps speed
  1. Disable or remove heavy extensions
    • Safari: Safari > Settings > Extensions.
    • Chrome: chrome://extensions.
    • Firefox: about:addons.
    • Turn off anything you do not use. Some extensions slow every page.
  2. Keep your browser and macOS updated
    • Outdated versions get weird with new sites.
  3. Check disk space
    • Click Apple menu > About This Mac > Storage.
    • If your disk is almost full, clear files. Browsers slow down when storage is tight.
Minimal-risk path if you are nervous
  1. First clear cache only, do not touch cookies.
  2. If issues remain, clear cookies for specific sites.
  3. Only then consider full cookies wipe.
That way you keep most logins and preferences and still fix the lag and broken pages.
If you’re worried about losing stuff, think of this more like a “tune up” than a “factory reset.” @nachtdromer already covered the click-by-click, so I’ll try to fill in the gaps and give you some safer strategies and tradeoffs.
1. What you actually lose vs what you keep
People lump “cache & cookies” together, but they’re different:
  • Cache: Temporary copies of images, scripts, etc. Deleting this:
    • Speeds things up if it’s bloated or corrupted
    • Does not remove saved passwords
    • May make some sites load a bit slower the first time after clearing
  • Cookies / site data:
    • Control logins, “remember me,” dark mode toggles, language, etc.
    • Deleting them logs you out and nukes those preferences
    • Does not erase passwords stored in the browser’s password manager
Where people freak out is mixing this up with:
  • Saved passwords / AutoFill: That’s a separate setting entirely. Do not check any box that says “Passwords” or “AutoFill” and you’re fine.
I actually disagree a bit with the idea that you should jump to “All time” cleaning if things are bad. That often wipes more convenience than it’s worth. I’d try shorter time ranges and targeted sites first.
2. Lowest-risk order of attack
Use this general approach regardless of browser:
  1. Step 1: Clear cache only
    • Safari: use the Develop > Empty Caches trick
    • Chrome / Firefox: only select “Cached images and files” / “Cached web content”
    • Result: You stay logged in almost everywhere. Often fixes slow / half-loading pages.
  2. Step 2: Target only the broken sites
    • Use Manage Website Data / Site settings / Manage Data
    • Search just the annoying site and remove its data
    • Result: You log in again only on those sites, not everywhere.
  3. Step 3: Broader cookie cleanup if things are still cursed
    • Then clear “Cookies and site data” with a time range, not necessarily “All time” right away.
    • Pick:
      • Last 7 days
      • Or Last 4 weeks if stuff has been weird for a while
    • This is the “okay, I’m ready to re-login to a bunch of stuff” stage.
3. Before you touch anything: quick safety net
Even though passwords are technically separate, I’d still:
  • Check your password list once
    • Safari: Settings > Passwords
    • Chrome: chrome://settings/passwords
    • Firefox: Settings > Privacy & Security > Saved Logins
  • Make sure you know how to get back into key accounts
    • Email
    • Banking
    • Work stuff
Optional but smart: Export passwords like @nachtdromer said, but if that feels scary, at least confirm they’re present and synced with iCloud / Google / Firefox Sync.
4. Things that feel like cache problems but aren’t
From experience, sometimes you can wipe cache 10 times and nothing changes because the bottleneck is:
  1. Extensions
    • Ad blockers, “security” extensions, coupon finders, or anything that “optimizes” browsing can absolutely wreck performance.
    • Try disabling all extensions once, restart the browser, test.
    • If it suddenly flies, re-enable one by one until the culprit shows up.
  2. Sync conflicts
    • Chrome / Firefox sync sometimes re-downloads junk from other devices.
    • You can:
      • Temporarily pause sync
      • Clean cache/cookies
      • Turn sync back on and see if it behaves
  3. System-level problems
    • Disk nearly full
    • Old antivirus / VPN client hooking into every web request
    • Old macOS version glitching with newer browser versions
Those don’t get fixed by nuking cookies, and people end up repeatedly clearing data for no benefit.
5. Strategy if you really hate logging back into everything
If your main fear is “I don’t want to re-login 500 times,” use this slower but kinder approach:
  1. Clear cache only in your main browser.
  2. Pick 3 problem sites and clear cookies just for those.
  3. Use a second browser as a test lab:
    • Install Firefox or Chrome or use Safari if you don’t normally.
    • Log in to just one problematic site there.
    • If it works perfectly in the fresh browser:
      • That’s more evidence your main browser’s site data is bad.
    • If it breaks there too:
      • Could be the site itself, your network, or your account, not your cache.
  4. Only if things are still acting possessed:
    • Full cookies clear in your main browser, accept the login pain once
    • Let the browser re-fill passwords for you as you go
6. When I personally go “full nuke”
I only wipe all cookies and site data when:
  • Sites keep redirecting in loops or never log me in
  • Layouts are totally broken even after cache-only clear
  • One browser is misbehaving while the same site works perfectly in another
And I do it knowing:
  • I’ll spend the next day logging back in and hitting “Remember this device” a lot
  • But I won’t lose saved passwords or bookmarks
So: you’re not wrong to be cautious. Just don’t treat it like an all-or-nothing choice. Start with cache only, then specific sites, then broader cookies if you’re still stuck. The “selective cleanup” route keeps most of your comfort features while still giving your browser a decent reset.
