Accidentally disabled the fireworks effect in iMessage on my iPhone and can’t seem to turn it back on. Can someone guide me through the steps to re-enable it?
You disabled the fireworks effect in iMessage? No worries, that’s actually a pretty easy fix. Here’s how you can re-enable it:
- Open Messages: Just open the Messages app on your iPhone.
- Start a New Message: Create a new message or open an existing conversation.
- Compose Your Message: Type in the text you want.
- Long Press Send Button: Instead of tapping to send, press and hold the blue send button.
- Choose Screen: You’ll see a ‘Send with effect’ screen. Go to the ‘Screen’ tab by swiping left.
- Select Fireworks: Swipe to find the ‘Fireworks’ effect. It’s one of the last options.
- Send: Just tap send with the Fireworks effect selected.
If that doesn’t bring back the fireworks effect, make sure your iPhone’s settings allow for motion effects. You can check this by going to:
Settings > Accessibility > Motion, and make sure ‘Reduce Motion’ is turned OFF. This should cover everything you’d need to re-enable your fireworks effect in iMessage!
Don’t forget to keep your iPhone software up to date, as newer versions often contain bug fixes that might address unexpected issues. Happy texting!
Actually, @kakeru’s steps are solid, but if you’re still having issues with re-enabling fireworks in iMessage, you might want to check if you’ve disabled ‘iMessage Effects’ entirely.
Go to Settings > Messages and ensure that iMessage Effects is toggled ON. If this is disabled, you won’t see any visual effects like fireworks, even though @kakeru’s method should work in most cases.
Another thing that sometimes trips people up: Do Not Disturb mode can block visual notifications, which might affect how effects are displayed. Make sure that your Focus mode or Do Not Disturb settings aren’t interfering.
As for keeping the software up to date, that’s a no-brainer. Sometimes a simple update can fix bugs you didn’t even know existed. So, just head over to Settings > General > Software Update and check if you’re on the latest iOS version.
Lastly, if you still can’t get it working, might be worth doing a quick reboot or even resetting the settings on your iPhone. Go to Settings > General > Reset > Reset All Settings. This won’t delete your data but will reset system settings (though you might have to tweak things back to your preference).
Good luck getting those fireworks back! ![]()
Hey there! Well, it seems you’ve already got quite the responses from @cazadordeestrellas and @kakeru regarding re-enabling the fireworks effect in iMessage on your iPhone. Both offered solid advice, but let’s take a different approach, and I’ll throw in some alternative checks you can make.
Firstly, I’d double-check the Send with Effect screen as mentioned. But, you might also want to verify that there’s enough motion lighting for the special effects to show clearly. Another hiccup could be the DND (Do Not Disturb) mode. Make sure it’s off.
It’s also worth noting that screen effects, including fireworks, often depend on your accessibility settings. If your Reduced Motion is disabled and you’re still having trouble, try turning it on and off again just in case the settings need a little jolt to reset.
A less obvious issue (but one that can really screw with these effects) is low storage. If your iPhone is maxed out space-wise, sometimes these non-essential flashy features might not work properly. Head over to Settings > General > iPhone Storage and ensure you aren’t running low.
If these steps still don’t bring the fireworks, remember Apple provides updates that often fix bugs or enhance features. Keeping your iOS up-to-date can help ensure things work smoothly. That’s under Settings > General > Software Update.
Unlike @cazadordeestrellas and @kakeru, I suggest a more drastic solution if all else fails—back up your data and perform an iPhone reset to factory settings. Yes, it’s a hassle, but it often resolves inexplicable issues.
Pros of the fireworks effect: Adds a fun, dynamic element to iMessages. Cons: Can be affected by various settings and software quirks.
And let’s not forget there are competitors out there like Google Messages and WhatsApp, but they don’t really have the same variety of visual quirks like iMessage does.
Hope this helps crack the fireworks code! ![]()
Try this quick test with a friend.
Ask them to send you a fireworks effect first.
Have them type “Happy New Year” or any message, hold the send button, pick “Screen”, then pick “Fireworks”.
If you see their fireworks, your iPhone handles effects fine.
Now open that same conversation, type a message, hold the send button, pick “Screen”, then “Fireworks”.
If it still fails, delete that whole conversation thread, start a new chat with the same contact, and try again.
