How can I get better results from Dzine Ai on complex designs?
I’ve been using Dzine Ai to create some complex design concepts, but the outputs keep coming out either too simple or not aligned with my prompts. I’ve tried tweaking the wording and style references, but I still can’t get the level of detail and accuracy I’m looking for. Can someone explain what settings, prompt structures, or workflows work best to push Dzine Ai to produce more precise, high-quality designs?
Had the same issue with Dzine Ai on complex stuff. Got better results once I treated it more like a junior designer than a magic button.
Here is what helped, step by step:
  1. Break the prompt into structure
    Instead of one long paragraph, use sections. For example:
    • Goal: hero section for fintech dashboard landing page
    • Layout: split screen, left text, right 3D style dashboard preview
    • Style: brutalist, high contrast, neon accent, flat icons
    • Constraints: no gradients, no photos, no stock-illustration look
    • Audience: senior product managers in SaaS
The model usually follows structured prompts better than long descriptive text.
  1. Define complexity explicitly
    Most systems default to simple visuals. Add lines like:
    • “High visual density, multiple layered elements”
    • “Include secondary details like annotations, micro icons, helper labels”
    • “Avoid minimal, avoid empty backgrounds”
If you want complexity in composition, say “complex composition” or “multi-panel layout” instead of “complex design.”
  1. Give hierarchy, not vague style
    Instead of “complex cyberpunk UI” try:
    • “Primary focus: central dashboard card”
    • “Secondary: 3 side panels with charts”
    • “Tertiary: small icons in header and footer”
Hierarchy helps the model avoid random clutter or over simplification.
  1. Use reference prompts by structure, not look only
    If you give style refs, add what part you want from each:
    • “Adopt color palette from X”
    • “Adopt layout structure from Y”
    • “Adopt typography weight and spacing from Z”
Otherwise the model tends to average all refs into something generic.
  1. Iterate with deltas, not full rewrites
    When you get a bad output, do not rewrite the whole prompt. Add constraints to the next one:
    • “Same layout as previous, but reduce empty space by 50 percent”
    • “Keep colors, replace icons with outlined geometric icons”
    • “Keep hierarchy, add more detail to background”
This teaches the system what “more complex” means for you.
  1. Call out what you do not want
    Negatives often help more than positives with complex designs:
    • “No pastel colors”
    • “No big centered logo”
    • “No generic gradient blobs”
    • “No floating abstract shapes without function”
  2. Use stepwise concept approach
    First prompt: “Wireframe only, grayscale, focus on layout and hierarchy.”
    Second prompt: “Take previous layout, add final colors and style.”
    Third prompt: “Add micro detail, shadows, small icons, patterns.”
If Dzine Ai supports image-to-image or prompt referencing, feed each stage back instead of starting from zero.
  1. Limit style adjectives
    Too many style words confuse the model. Pick 2 or 3 and stick with them. For example:
    Good: “brutalist, neon accent, flat UI”
    Messy: “brutalist, skeuomorphic, retro-future, soft, photo-real, minimal, playful, serious”
  2. Use concrete design language
    Swap vague words like “cool, complex, professional” for:
    • “8 column grid, 24 px gutter”
    • “Bold headings, 16 px body text, tight line height”
    • “Three card layout, each card with icon, title, stat, microcopy”
Even if it does not follow every pixel spec, the output trends closer to what you want.
  1. Save prompts that work and A/B test
    Run two variants side by side:
    Prompt A: simple style phrase.
    Prompt B: same, but with structured sections and negatives.
    Track which prompt type gives better alignment for your use cases, then reuse that pattern.
If you post one or two of your current prompts, people here can try to rewrite them into structured versions and you can compare the difference in Dzine Ai.
Couple of angles I haven’t seen mentioned yet that might be what’s tripping you up.
@ombrasilente’s “treat it like a junior designer” take is solid, but I actually think sometimes that level of structure makes Dzine Ai overfit to text and underfit to visual exploration. For complex stuff, I use a mix of “tight on intent, loose on execution.”
Here’s what I’d try:
  1. Separate “idea exploration” from “final control”
    Don’t ask Dzine Ai to nail complexity and pixel-precision in one shot.
    • Round 1: broad concept, allow it more freedom: “generate 6 variations focused on layout exploration only, ignore polish, exaggerate differences between versions.”
    • Round 2: pick 1 or 2 and then tighten: “refine variation 2 only, keep layout but increase information density and add secondary UI elements.”
  2. Use contradictions on purpose
    Models often flatten to generic “nice” design. To push complexity, add a few tension points:
    • “High information density but avoid visual noise.”
    • “Strong visual hierarchy but very busy interface.”
    • “Functional enterprise UI with slightly chaotic cyberpunk details in background only.”
      That paradox forces it to find more interesting compositions than just “clean dashboard with big hero card.”
  3. Anchor with a “primary metaphor” instead of style spam
    Instead of stacking style labels, give it a conceptual anchor:
    • “Interface should feel like an air-traffic control room for SaaS metrics.”
    • “Design like a command center for risk monitoring.”
      Then add 1–2 style tags max. Dzine Ai tends to respond better when it has a mental “scene” than when it’s drowning in adjectives.
  4. Control complexity via regions, not global commands
    Instead of “make it more complex,” specify where complexity lives:
    • “Background: highly detailed technical pattern, subtle, low contrast.”
    • “Main cards: medium complexity, easily readable.”
    • “Peripheral zones (footer, sidebars): dense clusters of tiny icons and labels.”
      That stops it from either oversimplifying everything or turning the whole page into clutter.
  5. Exploit failure modes on purpose
    If it keeps giving you simple layouts, ask for something you don’t want but that forces complexity, then correct:
    • Step 1: “Overly complex, borderline unreadable trading dashboard with maximal data density.”
    • Step 2: “Take previous, keep data density but improve legibility and typography.”
      Sometimes it’s easier to tone down chaos than to get it to ramp up sophistication from a minimal base.
  6. Describe relationships between elements, not just elements
    Complex designs feel complex because of interaction between parts:
    • “Cards should slightly overlap and intersect, suggesting depth.”
    • “Secondary panels should visually ‘dock’ to the main panel using shared borders and alignment.”
    • “Background grid should subtly align with all card edges.”
      Mention alignment, overlap, rhythm, repetition. Dzine Ai often ignores this unless it’s spelled out.
  7. Constrain color & typography hard, let layout be wild
    If the whole thing keeps collapsing into “dribbbley minimal,” try:
    • “Color palette restricted to 3 colors only, no gradients.”
    • “Use one sans-serif font style, two weights only.”
    • “Within those constraints, highly experimental and complex layout.”
      Tight constraints in some areas usually free the model to explore complexity elsewhere.
  8. Prompt around failure cases directly
    Literally name what usually goes wrong, almost like a bug report:
    • “Previous outputs suffered from too much empty space and too few secondary elements. This time, fill most of the canvas with content modules and micro-elements, keeping only small breathing areas.”
      You’re already doing something like this, but make it explicit and tied to past behavior, not just preferences.
If you’re up for it, post one of your “failed” prompts and what it gave you. The exact phrasing plus the outcome usually reveals what Dzine Ai is latching onto and what you need to reweight in the text.
Short version: Dzine Ai struggles when “complex” = “too many simultaneous asks.” You can often fix this by changing how you talk to it, not just what you ask.
I’ll skip what @chasseurdetoiles and @ombrasilente already nailed (prompt structure, hierarchy, staged workflows) and add some angles they did not lean on.
1. Switch from “describe the image” to “describe the brief”
Instead of telling Dzine Ai what the final screen looks like, write the prompt as if you are giving a creative brief to a design agency:
  • Context: what business problem the design solves
  • Task: what this specific screen / layout needs to achieve
  • User behavior: what you want people to do first, second, third
  • Risks: what would make the design fail in real life
Example:
“Marketing website hero for a fintech risk tool. Main job: convince skeptical CFOs this is credible and powerful. First action: read the headline, then scan 3 benefit cards, then notice the data screenshot. Avoid anything that looks like a playful consumer app.”
This shifts the model away from generic “cool UI with charts” and toward intent-driven composition.
2. Use narrative complexity, not just visual complexity
A lot of prompts say “complex cyberpunk dashboard” which the model translates as “more neon, more panels.” Instead, embed a story:
  • “Show the before and after of a chaotic risk landscape becoming organized.”
  • “Top area expresses ‘threats everywhere,’ bottom area expresses ‘control and clarity.’”
  • “Left column: ‘problem,’ right column: ‘solution.’”
Complexity that is narrative (problem → solution, chaos → control) tends to be handled better than just “add more stuff.”
3. Ask it to explain its own layout, then correct that
One trick: after it generates something, run a follow-up like:
“Describe the layout decisions and hierarchy in the previous design.”
Then prompt again:
“Regenerate, but fix the following issues:
• Headline is not clearly dominant.
• Call to action is buried.
• Background detail competes with content; reduce contrast in background only.”
You are basically forcing Dzine Ai to “talk design,” which gives you clearer handles to push or pull on. This is different from just saying “make it more complex” again.
4. Use “design review” prompts instead of pure refinements
Rather than only asking for a new version, do a critique-style pass:
  1. “Audit the previous design for:
    • Clarity of hierarchy,
    • Information density,
    • Visual interest.”
  2. “List 3 concrete visual changes to increase complexity without hurting clarity.”
  3. “Apply those 3 changes in a new version.”
This piggybacks on its reasoning abilities, not just its image synthesis. @chasseurdetoiles focused more on structured prompts; this is more about structured feedback.
5. Constrain content, not just style
If Dzine Ai keeps “simplifying” your layout, it might be because your content spec is fuzzy. Try fixing the data and letting it solve around that:
  • “Must include: 5 metrics, 2 line charts, 1 heatmap, 1 activity log, 3 filter chips.”
  • “Do not remove modules; rearrange and restyle only.”
  • “If space is tight, stack modules instead of deleting them.”
Complexity often evaporates when the model silently drops content. Forcing a fixed inventory keeps the screen dense.
6. Be careful with too much negative prompting
I slightly disagree with leaning heavily on negatives like “no gradients, no blobs, no minimal, no empty space, no photos.” Stack too many and Dzine Ai often goes into a safe, flat, uninspired zone.
Try a balanced pattern:
  • 2 to 3 strong positives: “dense dashboard,” “command-center feeling,” “enterprise, serious.”
  • 1 to 2 critical negatives: “no playful rounded cards,” “no pastel color palette.”
If you find a negative that really helps (for many people it is “no generic gradient blobs”), keep that and drop weaker ones.
7. Treat layout & styling as separate “tracks”
Instead of “complex 3D brutalist cyberpunk dashboard with shadows, neons, glassmorphism…”, split concerns:
Round A (layout track):
“Wireframe-style: prioritize module placement and hierarchy. Neutral colors, low contrast. Ignore polish.”
Round B (style track):
“Take the previous wireframe, freeze layout. Now explore 3 visual themes:
  1. brutalist, sharp, high contrast,
  2. dark enterprise, muted, subtle accents,
  3. neon cyberpunk accents only in background patterns.”
This gives Dzine Ai one hard task per round. Complexity comes from combining decisions, not trying to solve everything simultaneously.
8. Push it with “real-world constraints”
Generic prompts yield generic UI. Try giving it constraints that sound like a real project:
  • “Must be legible on a 13 inch laptop at 80 percent zoom.”
  • “Assume this will be presented in a boardroom on a projector; no tiny text for primary messages.”
  • “Design must still make sense if printed in black and white.”
This often nudges the model into more sophisticated, layered solutions that read as “complex but thought-through” instead of “over-designed dribbble shot.”
9. Rotate between freedom and control
Here I am closer to @ombrasilente’s “tight on intent, loose on execution,” but I would explicitly alternate:
  • Prompt 1: “Ignore brand rules; focus on surprising complex layout explorations.”
  • Prompt 2 (after picking one): “Keep this layout exactly; now constrain to 2 brand colors and 1 accent, and improve legibility.”
The oscillation between wide-open exploration and strict refinement yields better complex outcomes than staying super-structured the whole time.
10. About Dzine Ai itself: pros, cons, and competitors
If you are considering whether to keep wrestling with Dzine Ai for complex concepts:
Pros of Dzine Ai for complex designs
  • Pretty good at multi-step workflows when you use review / refine prompts.
  • Handles “brief-like” descriptions better than many tools that only respond to style tags.
  • Iteration is fast, which helps when you are doing layout-track vs style-track passes.
Cons of Dzine Ai
  • Tends to default to safe, semi-minimal aesthetics if you are even slightly vague.
  • Can overreact to stacked negative prompts and strip out interesting detail.
  • Sometimes collapses complex content into fewer modules unless you explicitly fix the inventory.
Compared with voices here like @chasseurdetoiles (more methodical, systems-style prompting) and @ombrasilente (more conceptual and exploratory), Dzine Ai sits in a middle spot: it benefits from structure, but also needs room to “breathe” visually. Your job is to decide when to be its art director and when to be its creative director.
If you want, drop one of your “failed” prompts plus a short description of what came out. People here can help rewrite it into a brief-style prompt and a review-style follow up so you can see the difference in how Dzine Ai behaves.
