I’m trying to check if my writing is flagged as AI-generated by Quillbot’s detector, but I keep getting mixed results. Has anyone tested its reliability or compared it with other tools? I need help understanding if I can trust its accuracy for academic use.
Honestly, you can’t rely on Quillbot’s AI Detector to give you a straight answer every time. I tried running my own stuff through it—some original essays and a few prompts I ran through ChatGPT—and the thing flagged me as an AI robot on stuff I 100% wrote myself, then totally missed actual AI content more than once. From what I’ve seen on Reddit and other forums, most of these detectors are just guessing based on ‘AI-like’ phrasing or certain sentence structures, but it’s not an exact science at all. Also, their outputs change sometimes if you paste the exact same thing twice, which is honestly infuriating. If you’re seriously worried about being flagged, don’t put too much faith in Quillbot (or any other single detector, tbh). Your best bet is probably to run your text through a few different tools—GPTZero, Originality.ai, ZeroGPT, etc.—and see if there’s any consensus, but even then, take it with a massive grain of salt. None of these are courtroom-level accurate. Human reviewers are still miles better at figuring out if something sounds ‘off’ or artificial. So yeah, use it as a rough guide, not gospel. And maybe stop stressing about it if you’re not obviously copying and pasting, because the detectors aren’t even close to perfect.
Not to be that guy, but “reliable AI detector” is basically an oxymoron at this point. I ran Quillbot’s detector side by side with a couple others (GPTZero, ZeroGPT, the whole gang), partly for work, partly because I was bored, and honestly? It’s kind of a circus. I had Quillbot label the same three-paragraph chunk as “likely AI” one day, then “likely human” the next. Meanwhile, GPTZero flagged it as suspicious every time. ZeroGPT didn’t care either way.
Honestly, @sternenwanderer’s right on: these tools are not precise. It’s not even like they’re trying to be; they mostly just do a word salad analysis, snitch on predictable phrasing, and then spit out an answer half the time that might as well be a coin flip. If you tweak punctuation or swap out a synonym, you can get different results—doesn’t exactly scream “scientific rigor,” you know?
If you need a real test, try having an actual person read it (bonus points if they’re your professor or boss). Humans still have a much better BS detector for tone and flow. Most of these “AI detectors” are more for novelty than anything reliable. Like, sure, run your stuff through a few tools if you’re genuinely nervous, but don’t burn too much energy worrying about a single red flag from Quillbot or any other one. For now, the only consensus among detectors is how inconsistent they are, and that’s not exactly comforting if you want a clean bill of health for your doc.
tl;dr: If you want certainty, you’re out of luck. If you’re just curious, treat the results as loose hints at best. Detectors are still fumbling in the dark. Not sure we’re gonna see huge progress anytime soon, either.
Instead of chasing detector scores, keep proof of your writing process. Draft in Google Docs or Word with version history turned on. Save your outline, notes, sources, and early drafts. A document showing 12 edits across two days gives your professor or boss clearer evidence than a detector percentage. If questioned, share the revision history and explain two or three choices you made. This takes little effort, avoids mixed scores, and protects you from false flags. Also, dont paste sensitive work into random detector sites.
The score flipping day to day isn’t random, it’s the point. Most of these detectors, Quillbot included, grade how predictable your word choices are. Clean, plain, grammatically tidy writing reads as predictable, so it gets flagged. That’s why polished non-native English or anything you edited heavily tends to trip it. If your writing is competent and simple, you’re actually more likely to get a false positive than someone who writes in a messier, looser style.
@deep_hawk has the only advice in here that actually protects you, and I’d lean on it harder than the detector talk. The version history is the real safeguard because it moves the argument off ‘what does a tool say’ and onto ‘here’s how this came together.’ The one thing I’d tweak is don’t wait until you’re questioned to think about it. Turn on history before you start, not after, or you get one giant paste as your first revision, which looks worse than no history at all.
Running your text through a few tools for consensus is fine as a nerves check, but keep in mind the person who might flag you probably isn’t running three detectors either. They’re running one, once, and reading the number. So a clean score somewhere doesn’t cancel out a red flag they got somewhere else. That’s the part worth stressing about, not whether Quillbot likes your paragraph today.
