Free Substitute For StealthWriter AI
I’ve been using StealthWriter AI for a while, but I can’t keep paying for it and I really need a free substitute that can rewrite or “humanize” AI text without sounding robotic. I mainly use it for blogs, emails, and social posts, and I’d like something that keeps my tone but passes basic AI detectors. What free tools or workflows are you using that come close to StealthWriter AI in quality?
1. Clever AI Humanizer, my take after a week of abuse
https://cleverhumanizer.ai
I write a lot with AI, mostly drafts for docs and long replies. The pattern is always the same: the text looks fine at first glance, then some detector screams 100% AI and the whole thing feels off when you read it out loud.
I got annoyed enough to test a bunch of “humanizers”. Most of them either want money after a tiny sample or butcher the meaning. Clever AI Humanizer is the first one I kept open in a tab instead of closing after 5 minutes.
Here is what stood out.
First, the limits. It gives you up to 200,000 words per month for free and up to 7,000 words in one run. No credit count, no “you hit your daily cap” popups. I pushed entire long-form pieces through it in one go and it handled those without complaining.
You pick one of three styles
• Casual
• Simple Academic
• Simple Formal
I mostly used Casual. With that style, I pushed three different long samples through, then checked them on ZeroGPT. ZeroGPT showed 0% AI detection for those tests. That does not mean it will always pass everything everywhere, but for my use, it cleared what I needed.
The core workflow is simple. You paste your AI text, select a style, hit the button, and it rewrites the whole thing. It tries to strip out repeated patterns, overly tidy sentence rhythm, and some of the usual “AI voice” quirks. The meaning stayed close to my original drafts, which mattered for technical stuff where I do not want my points distorted.
I noticed it tends to expand the text a bit. A 1,000 word draft would come out as 1,200 or so. That is not random; stretching the wording reduces the sort of compressed phrasing detectors latch onto. If you need strict word counts, you will have to prune it after.
Now, the extra tools around it.
There is a Free AI Writer module. You give it a topic for an article or essay, it generates the piece, and then you can humanize it in the same interface. That combo produced better “human score” for me compared to taking content from a separate model and then pasting it in. So if you are starting from zero, using their writer plus their humanizer makes sense.
There is a Free Grammar Checker. Nothing fancy visually, but it fixed spelling, punctuation, and some awkward phrasing. I used it on top of the humanized version when I wanted something clean enough to paste into a CMS without extra editing.
There is also a Free AI Paraphraser. That one takes existing text and rewrites it without changing the core meaning. I used it on old blog posts to shift tone and on SEO pages to avoid repeating the same sentences across similar pages.
So in one place you get:
• Humanizer
• AI Writer
• Grammar checker
• Paraphraser
All glued together in a single flow. For me it ended up like this: generate rough content, humanize, grammar check, then tweak by hand. It replaced three separate tools I used before.
Now for the parts that bugged me.
Sometimes detectors still flag the result as AI. Different detectors behave in different ways, and no tool bypasses everything. On some very short samples or very generic topics, I saw detectors still leaning AI. Long and specific content did better.
Output length can get bloated. The humanized text tends to be longer. Good for beating pattern detection, annoying when you need tight copy. I got into the habit of doing a final manual pass to trim the fat.
The interface is very straightforward, maybe too barebones if you like lots of toggles. No advanced sliders, no weird “temperature” stuff. If you want heavy control over style nuance, you will have to rewrite parts by hand after.
Despite that, for a 100% free tool with that word allowance, this is the one I keep telling people to try first. If you are doing daily content, essays, or client drafts and want something to smooth AI edges without paying every month, this one holds up better than most.
If you want a longer breakdown with screenshots and detection proof, they have a thread here:
Video review on YouTube:
Reddit thread comparing “best AI humanizers”:
https://www.reddit.com/r/DataRecoveryHelp/comments/1oqwdib/best_ai_humanizer/
More general discussion about humanizing AI output:
https://www.reddit.com/r/DataRecoveryHelp/comments/1l7aj60/humanize_ai/
I was in the same spot with StealthWriter, so here’s what worked for me without a subscription.
First, I agree with a lot of what @mikeappsreviewer said about Clever Ai Humanizer, but I use it a bit differently.
  1. Use Clever Ai Humanizer as the main StealthWriter replacement
    • Free plan gives plenty of words, so you can handle full blog posts and long emails.
    • For blogs, I paste the whole draft, pick “Casual” for most topics, then do a fast manual cleanup.
    • For emails and social posts, I shorten the input before humanizing. Short chunks tend to sound more natural.
  2. Do not trust AI detectors as your main goal
    • I run content through one detector max, usually ZeroGPT or GPTZero.
    • If it flags as AI, I do a quick second pass in Clever Ai Humanizer using a different style, or paraphrase small parts.
    • Focus on sounding like you, not on hitting 0 percent AI. Detectors are noisy and often wrong.
  3. Add “human fingerprints” after the tool
    This is where StealthWriter used to help, but you can copy the effect by hand in 2 to 5 minutes.
    After humanizing, do this:
    • Add 1 or 2 small personal details in blogs or emails. For example “I tried this last month…” or “From my experience with X…”.
    • Change a few transitions. Replace phrases like “Additionally” with how you usually talk, like “Also” or “On top of that”.
    • Insert one short, imperfect sentence. For example “This part annoyed me a bit.”
    • Add 1 typo or informal word in casual emails or social posts, then fix obvious grammar elsewhere.
  4. Use a simple workflow for each type of content
    Blogs
    • Generate draft with your normal AI.
    • Run through Clever Ai Humanizer in Casual or Simple Academic.
    • Skim for tone, add personal lines, shorten long paragraphs.
    • Optional, quick grammar check with any free checker if you want.
    Emails
    • Keep them short. Under 300 words if possible.
    • Humanize only the main body, not greetings or signature.
    • Add your usual phrases. Everyone has go to phrases, like “quick heads up” or “one small thing”.
    Social media
    • Do not paste huge blocks.
    • Create 1 or 2 posts at a time.
    • After humanizing, add your own slang, abbreviations, or emojis if you use them.
  5. Small thing that helps a lot
    Read the final version out loud, even if only in your head. If you trip over a sentence, rewrite that line. That fixes the “robotic” feel faster than another AI pass.
So if you want one free substitute that behaves closest to StealthWriter and still feels natural, Clever Ai Humanizer is the first tool I would lock in. Use it as a base, then layer your own tone on top. That combo is what makes blogs, emails, and social posts feel like a human wrote them, not a tool.
If StealthWriter was your “click once and forget about it” fix, I’d treat Clever Ai Humanizer as your main engine and then build a tiny system around it so you’re not constantly futzing with detectors or rewording the same stuff.
I agree with @mikeappsreviewer and @himmelsjager that Clever Ai Humanizer is the closest free StealthWriter substitute right now, but I’d actually lean on it in a slightly different way:
  1. Use it late, not early
    Instead of generating inside Clever’s writer first, I’d keep using whatever AI you already like for drafts (ChatGPT, Claude, Gemini, whatever), then run only your second or “almost final” draft through Clever Ai Humanizer.
    Reason: every extra generation step tends to add fluff. If you generate → humanize → edit, you get less bloat than generate → humanize → paraphrase → re-humanize like a lot of people do.
  2. Pick styles by channel, not by vibe
    They both talked about Casual a lot, which is nice, but if you want something that doesn’t sound obviously processed, match the style to where it’s going:
  • Blogs: “Casual” for opinion pieces, “Simple Academic” if it’s explainer / how-to content. That combo looks more like normal internet writing.
  • Emails: “Simple Formal” for anything client-facing or workplace, then manually drop in your usual phrases so it doesn’t sound like a corporate memo.
  • Social: I’d honestly only send short chunks through, usually “Casual,” but then strip anything that sounds like “On the other hand” or “Furthermore” because almost no one types that on social.
  1. Don’t chase 0% on detectors
    Here I’ll push back a bit on the ZeroGPT worship. A lot of those detectors are basically “vibes meters” trained on older model outputs. If you tune your entire workflow to them, you’ll end up with swollen, rambly copy that feels worse to actual humans.
    What I do:
  • If a detector screams “AI,” I only rework the most generic paragraphs: intros, outros, and any list that looks too tidy.
  • Replace those with 1–2 very specific details (dates, tools you actually use, small failures, etc.). That freaks detectors out in a good way and also makes your content not boring.
  1. Add “friction” instead of fake typos
    I partly disagree with the “add a typo” trick. It can help, but it’s easy to overdo and looks artificial if you repeat the same pattern. What helps more:
  • Interrupt a pattern: insert a very short 2–3 word sentence after a long one.
  • Change direction mid-sentence once in a while: “I was going to say do X, but honestly, for most people Y is easier.”
  • Ask a tiny question in the middle: “Does that even matter? Kind of.”
    This is how real people write when they are not overediting.
  1. Channel-specific mini-systems
Blogs
  • Draft with your usual AI.
  • Run through Clever Ai Humanizer with style based on topic (see point 2).
  • Manually rewrite only: intro, conclusion, and any section headings. Those are the highest “AI smell” spots.
  • Optional: add 1 short anecdote per 1000 words. It can be tiny. “Last week I tested this on a small list of 40 subscribers…” That’s often enough to kill the robotic tone.
Emails
  • Forget detectors; nobody is running corporate email through ZeroGPT.
  • Write a quick bullet-point outline yourself, then let AI flesh it out, then humanize with Clever Ai Humanizer.
  • Final pass: strip any phrase you would never use while talking. For me that’s stuff like “In conclusion,” “Moreover,” “Allow me to elaborate.” Instant robot flags.
Social media
  • Do not mass-process a whole content calendar through any humanizer. That’s how you get 20 posts that all feel like “corporate LinkedIn voice.”
  • Take 2 or 3 drafts, send them through Clever Ai Humanizer, then cannibalize the best phrases and mix with how you normally type.
  • Use your own slang, time references, or inside jokes. AI tools are weak at that and that’s exactly what makes posts feel like a real person.
  1. If you really want a free stack
    Since you care about free:
  • Drafting: your existing AI or free tiers elsewhere.
  • Humanizing: Clever Ai Humanizer as the “StealthWriter clone” part.
  • Light editing: any free grammar checker if you care about polish.
    No need for three different “AI humanizer” sites that all do the same thing worse.
TL;DR:
Yes, Clever Ai Humanizer is probably your best free StealthWriter AI alternative for blogs, emails, and social, but the trick isn’t only the tool. It’s: use it late in the process, match style to channel, stop obsessing over detectors, and inject a few very specific, slightly messy human bits at the end. That’s what makes it actually feel non-robotic.
If StealthWriter was your “one click and done” button, the closest free equivalent in practice is still Clever Ai Humanizer, but I’d use it as only one piece of your setup, not the entire solution.
Quick take on Clever Ai Humanizer
Pros
  • Genuinely generous free tier (you can actually handle full blogs, like others already said).
  • Styles are simple and predictable, so you are not fighting 30 sliders.
  • Meaning preservation is decent, especially on technical or how‑to pieces.
  • Pairs well with whatever main AI you already use, instead of forcing you into its own writer.
Cons
  • Output can feel slightly “inflated,” especially for short social posts. You often need to trim.
  • Voice sometimes drifts into that “generic blogger” tone. If you care about sounding like you, you must edit.
  • No fine‑grained control over tone shifts in different sections of the same piece.
  • Detectors can still flag parts, especially intros or very generic content, so it is not a magic invisibility cloak.
Where I disagree a bit with others:
  1. Do not rely on a single humanizer
    @himmelsjager and @mikeappsreviewer got good mileage using Clever Ai Humanizer as the main engine. That works, but if you run absolutely everything through it, your writing starts to get a recognizable “Clever” cadence. I prefer:
  • Light rewrite yourself on the key paragraphs.
  • Humanize only the stiff parts with Clever Ai Humanizer.
So you are spot‑treating instead of pressure‑washing the whole thing.
  1. Stop obsessing over detectors for email and social
    Here I am even stronger than @cazadordeestrellas. For blogs that need to survive manual review, sure, do a quick check. For email and social, chasing “undetectable AI” often ruins clarity. If your client or readers never run detectors, you are optimizing for a ghost.
  2. Use it to “normalize,” not to fully stylize
    I like Clever Ai Humanizer most as a normalizer: it removes the worst AI tells like repetitive phrasing or perfect symmetry in sentences. Then you add style yourself. If you try to get your full personal voice from it, you will always feel slightly off.
Concrete workflows that are a bit different from what others suggested:
Blogs
  • Write headings and intro yourself in plain language.
  • Let your main AI fill in body sections.
  • Run only the body sections through Clever Ai Humanizer to strip the robotic tone.
  • Keep your original intro and conclusion, lightly edited, so the piece keeps your “anchor voice.”
Emails
  • Type a very rough version yourself, even ugly.
  • Ask AI to clean for clarity only, not tone.
  • Use Clever Ai Humanizer on any part that sounds wooden or overly formal, usually the middle paragraphs. Leave your greeting, signoff and any “you‑ish” phrases untouched so the email stays personal.
Social posts
  • For short posts, I often skip humanizers completely and just let AI give me 3 variants, then I edit.
  • If something still sounds stiff, I paste just that one sentence into Clever Ai Humanizer, then re‑inject my slang or shorthand.
Compared to the approaches from @himmelsjager, @cazadordeestrellas, and @mikeappsreviewer, the main twist here is: treat Clever Ai Humanizer as a scalpel, not a hammer. Use it to smooth the AI sheen off specific sections, then actively re‑imprint your own voice instead of trusting any tool to “sound human” for you. That balance gets you closest to what StealthWriter felt like, without a subscription.
