Filezilla vs Filezilla Pro: Which Do You Actually Use?
I have been using the standard free version of FileZilla for years to handle standard site updates over FTP and SFTP. I know they offer FileZilla Pro, but I am not sure if it is worth paying for.
What exact functions and tasks does each version perform? Does the Pro version fix any of the transfer bottlenecks or add anything useful beyond basic file transfers?
I had to solve the issue for my small web project after one of my colleagues asked me if paying for the FileZilla pro would take away any steps from our usual processes. What I did was I wrote down the things we transfer, where they are hosted, and how frequently someone needs to shift from the regular desktop experience to something else in order to get work done.
The dividing line is where the files live
For a standard website, I don’t see much mystery in the free version. It connects a local machine to a server through FTP, FTPS, or SFTP, which covers the usual jobs: uploading a build, replacing assets, downloading backups, and making basic changes on a remote host. If that’s the whole workload, the expected benefit from paying looks pretty small, especially once the secure connection options are clear from the FTPS protocol notes and the separate FTPS reference page.
Pro starts making sense when the file locations stop being ordinary web servers. It can connect directly to Amazon S3, Google Drive, Microsoft OneDrive, and Dropbox, then handle cloud buckets, batch renaming, and transfers between those services from one client. That changes my calculation because I’m no longer comparing basic upload speeds, I’m counting how many separate tools and browser tabs the team needs, which is the real distinction described in the FileZilla Pro details, along with the broader idea behind cloud storage basics and this cloud storage overview.
So my rough rule is pretty simple. If nearly everything goes between a computer and a conventional web server, free FileZilla already covers the requirement. That seems consistent with the advice found through FileZilla forum guidance and other FileZilla forum discussions.
The client window may be the bigger issue
There’s a separate workflow question that’s easy to miss when comparing feature lists. Both FileZilla versions still work as standalone transfer clients, so files are generally moved manually through their own window rather than appearing as normal drives in Finder or File Explorer. That may be fine for occasional uploads, but repeated download, edit, and upload cycles add friction fast, a point that also comes up in the Reddit admin thread and the related Reddit transfer discussion.
That’s why I’d treat CloudMounter as a different type of option, not a direct feature-for-feature FileZilla rival. It mounts remote servers and cloud accounts as local drives, letting desktop apps open, edit, and save remote files without a manual upload step. For me, the deciding metric would be time saved per recurring edit rather than the number of supported services, so has anyone measured whether that workflow actually feels faster after switching to the CloudMounter app listing?
The type of the connection provided by your host defines the details. If it allows to provide SFTP access to the shared web server, the free FileZilla client will do. Just save the login credentials in the Site Manager, define the default local and remote folders and upload the updated folder on weekly basis.
The cloud-storage distinction @zoetheproxy described is accurate, but it probably doesn’t apply to your setup. Pro is useful when the destination is a supported cloud service rather than standard hosting. It won’t meaningfully simplify a basic recurring website upload.
Regardless of the client (including FileZilla), CloudMounter, or another tool used, it is necessary to watch out for messages about overwriting and remote computers. The former problem is more significant than the latter if you have to choose between making a mistake with edition levels and directories. It is better to keep a local copy before uploading, use SFTP (Secure File Transfer Protocol), and only then proceed to changes within the free version of the service if storage conditions are altered.
Uploading only the changed photos is a simple and controlled operation; replacing the entire remote folder every Friday is where the accidents and wrong directory uploads happen. For such a scenario, I would use the free FileZilla and save the site in the program to upload only the modified files. Pro would not make this process significantly easier.
Pay attention to capitalization in filenames. Many web servers treat Banner.jpg and banner.jpg as different files even when your laptop does not. That trap is the same with FileZilla Pro, CloudMounter, or any other transfer method. If an image looks unchanged after upload, check the remote filename and browser cache before assuming the transfer failed.
Establish a connection in free FileZilla, upload a throwaway image, make sure it appears on the expected web address before opening the real folder to work with – that way you avoid the most costly mistake of all: establishing a connection successfully but in the wrong remote directory.
I’d say skip Pro for this task – the additional cloud-service support it offers does not make an everyday SFTP upload any safer or more routine. Go over the transfer queue after the operation is complete, paying close attention to the failed and skipped items tabs, because a single forgotten file can be buried under the seemingly successful upload.
I’d save the host and folders in Site Manager but think twice about storing the password on a shared or untrusted laptop. The expense of Pro would not justify the risk.
“Replacing the folder” in FileZilla doesn’t exactly replace, you are actually merging the folders. You upload the images that you added or changed, the images you deleted or renamed stay there, possibly forever. I think the word “replacing” does a lot of magic there.
That matters more than the free-versus-Pro choice. Suppose header-old.jpg becomes header-new.jpg. Uploading the updated folder adds the new file, but it may leave the old one sitting remotely. Pro does not magically turn this into a clean deployment or make the server match your laptop exactly.
For your use case I would stick with regular FileZilla, save connection and paired folders, look at changed filenames before transfer and delete stale remote copies separately if something was renamed or deleted. Avoid deleting entire remote image directory first before upload, in case of connection loss it would be left hanging.
The paid version only sees use here if you’re uploading to a cloud service or need any of other specific features. It is not the ‘same website upload but with fewer Friday afternoon clicks’ version. If you eventually want automated mirroring that is a different use case and should be handled by a deployment or sync utility instead of assuming Pro provides it.
Honest answer for a weekly photo push: nobody needs Pro here, and I’d trust @cipher9763’s point about merging over everything else in the thread. The stale-file trap is the real risk, not the client you pick.
Where I’d push back on how CloudMounter got framed earlier is the ‘faster editing’ angle. For this job the interesting part isn’t skipping upload clicks, it’s that dragging a folder onto a mounted drive can actually mirror deletes and renames instead of quietly leaving old images behind, which is exactly the thing plain FileZilla won’t do for you.
A mounted drive is not smart enough to replicate deletions/renames, it’s up to the file manager or sync tool to implement such features, which is why CloudMounter cannot be considered deployment software.
FileZilla Pro mainly offers direct access to the cloud/object-storage services and has no features turning SFTP uploads into a deployment process with scheduled commits, version tracking or exact replicas. As a rule of thumb, I would use the free client for regular website maintenance and only invest into the Pro if a particular cloud destination requires it.
