Can someone help me troubleshoot issues with my Tea App?
My Tea App keeps crashing whenever I try to browse or save new tea blends, and I can’t figure out what’s causing it. I’ve tried reinstalling and clearing cache, but nothing helps. Can anyone suggest possible fixes, settings to check, or logs I should share so I can get this Tea App working smoothly again
Had a similar thing with a recipe app. Crashed whenever I tried to save stuff. Turned out to be a mix of bad data, storage limits, and one buggy version.
I’d try this in order:
  1. Check app version
    • Open your app store
    • See if Tea App has an update
    • If you are on a beta build, opt out, then reinstall the stable version
  2. Storage and permissions
    • Check your device storage, keep at least 1–2 GB free
    • Go to Settings → Apps → Tea App → Permissions
    • Make sure Storage and Network permissions are allowed
    • If it has Photos or Media permission, enable that too
  3. Full data reset
    • Settings → Apps → Tea App → Storage
    • Tap “Clear data” and “Clear cache” both
    • Log back in and try browsing blends before you change any settings
  4. Network tests
    • Try on Wi‑Fi first
    • Then try on mobile data
    • Turn off any VPN or ad blocker for a bit
    If it works on one but not the other, the crash might come from partial responses from their server.
  5. Trigger pattern
    Try to see what exact action kills it:
    • Opening the blends list
    • Searching for a blend
    • Saving a blend with a long name or custom note
    • Adding a photo
    If only custom blends crash, skip custom notes and photos, save a “plain” blend and see if it holds.
  6. Reinstall the “hard” way
    • Uninstall Tea App
    • Restart phone
    • Install again
    • Before you log in, disable battery optimizations for it under Settings → Battery → App battery management
    Some vendors kill apps in the background and they crash when they hit storage.
  7. Check for system issues
    • Make sure your OS is up to date
    • If you use Android, turn off “Force GPU rendering” or dev options tweaks
    • If you use iOS, try offloading the app instead of regular delete, then reinstall
  8. Crash logs
    If you feel up to it:
    • Android: enable Developer options → take a bug report right after it crashes
    • iOS: Settings → Privacy & Security → Analytics → Analytics Data → look for the Tea App entry
    Even a screenshot of the top lines can help support.
  9. Contact their support with details
    Include:
    • Phone model and OS version
    • App version
    • Steps that always crash it
    • If it happens on Wi‑Fi, mobile, or both
    Vague “it crashes a lot” reports often get ignored or get useless template replies, so detail helps.
If you post your device model, OS version, and app version here, people can compare and see if it hits a specific combo.
Couple more angles you can try that go beyond what @mike34 already covered:
  1. Narrow it down to one type of data
    Since it crashes when browsing and saving blends, it might be choking on a specific blend record. Try this pattern:
    • Put device in Airplane mode
    • Open Tea App → does it still crash when going to “Blends”?
    • If it stops crashing offline, that suggests a corrupt server-side item or bad response, not your local storage.
      In that case, try:
    • Log out (if possible)
    • Log back in with a different account, or as guest
      If the other account works, your profile data / blends list on the server is probably corrupted.
  2. Check for account sync conflicts
    Are you signed into the same Tea App account on multiple devices? Sometimes one device saves a weird blend (bad characters, emojis, super long description) and the other device crashes as soon as it tries to sync it.
    • Temporarily log out on all other devices
    • On your main device, log out, clear data, log back in
    • If you can, avoid auto sync / backup options in the app for a bit and see if that stabilizes it.
  3. Look at language / region quirks
    This sounds dumb, but I’ve seen apps crash on:
    • System language set to something they half-support
    • 24‑hour vs 12‑hour time formats
    • Decimal separator (comma vs dot)
      Try temporarily:
    • Set system language to English (US)
    • Set region to US
    • Restart, then open Tea App and try browsing/saving one simple blend.
  4. Keyboard & input stuff
    If it crashes mostly when saving blends, the problem could be your keyboard or what you’re typing:
    • Switch to the default system keyboard
    • In a new blend, only type plain ASCII letters/numbers, no emojis, no special characters
    • Don’t paste from clipboard, type manually
      If that works, the app might be mishandling certain characters.
  5. RAM & background kill issues
    Sometimes it looks like a crash but it’s the OS killing it. You already reinstalled, so try:
    • Close all other apps
    • Disable “RAM cleaner” / “booster” apps if you have any
    • Turn off aggressive battery saving modes temporarily
    • Quickly reproduce the crash and see if it still dies the same way.
  6. Version mismatch & partial install
    You mentioned reinstalling, but not how:
    • If you ever sideloaded an APK in the past, remove that version completely first
    • Make sure you’re not mixing a store version with an older sideloaded build
    • Check in app settings that there is only one Tea App listed, not a duplicate with a slightly different icon or package name.
  7. Capture an exact crash pattern for support
    Instead of “crashes whenever I browse or save blends,” write it like:
    • Open app
    • Tap “Blends”
    • Scroll past 10 items
    • When item #11 thumbnails try to load, app closes instantly, no error
      or
    • New blend → name: “Test 1” → save → instant crash, reopens to home screen
      That kind of precise sequence plus a screenshot of the crash log top lines makes support much more likely to actually fix it.
If you post:
  • Device model
  • OS version
  • Tea App version
  • Whether it also crashes in Airplane mode / with another account
someone can probably spot a pattern. Right now it smells like either a corrupt server record in your account or some weird character / locale edge case more than just basic storage or cache.
Short version: what @shizuka and @mike34 covered is the “classic” stuff (storage, versions, locale, data corruption). I’d look at a few deeper angles that often get missed, especially when an app like Tea App dies specifically on browsing and saving blends.
1. Treat it as a database bug on their side
If browsing and saving are the only two crash triggers, that often points to:
  • A bad schema migration in the Tea App database on your device
  • A specific field in one blend that the new version cannot parse
What you can try that goes beyond a simple “clear data”:
  1. Install Tea App on another device with a different OS version if you can (even an older phone or tablet).
  2. Log in with your same account.
    • If the other device also crashes in the same place, your account data on their server is probably corrupted.
    • If the other device works fine, the problem is more likely the local database format on your main device.
If it looks account‑specific, contact support and explicitly ask them to:
“Purge or reset my blends list on the server, or at least remove the last N blends I added before the crashes started.”
Support usually reacts faster when you suggest a concrete operation rather than “please help, it crashes.”
2. Look for specific UI components causing it
Sometimes it is not the network or storage at all, but a widget:
  • Thumbnail images for blends
  • A particular font or icon pack
  • A problematic theme
Try:
  1. In Tea App, if there is a “compact list / no images / low data mode,” enable that and then open the blends list.
  2. If there is a theme or dark mode inside the app, switch between them and see if one mode crashes and the other does not.
  3. Turn system font size and display scaling back to default, then retry. Some apps genuinely crash when fonts are oversized and layout code hits an exception.
If the crash only happens with thumbnails visible, it might be choking on one specific corrupt image tied to a blend.
3. Notifications, background sync and widgets
I disagree slightly with focusing only on in‑app actions. On a bunch of apps, the “crash on open” problem is actually caused by:
  • A corrupted notification payload
  • A home‑screen widget that references invalid data
Try this:
  1. Remove any Tea App widgets from your home screen.
  2. Long‑press Tea App → App info → turn off notifications for a few minutes.
  3. Force stop the app, then reopen and browse blends.
If the issue disappears, it is likely a broken notification / widget referencing a bad blend. Report that pattern to support: “Crashes stop when Tea App notifications and widgets are disabled.”
4. Backup / restore conflicts
If you recently moved to a new phone, a cloud backup might have restored an older internal database for Tea App that does not match the new version.
To rule that out:
  1. Uninstall Tea App.
  2. In your OS backup settings, turn off “auto restore” or “restore app data” specifically for Tea App.
  3. Reinstall Tea App so it starts as a fresh install with no restored internal DB.
  4. Log in and test browsing blends before changing any settings.
This is different from a basic clear data because it prevents the OS from silently restoring an incompatible backup.
5. Security / privacy tools and “overlay” features
Not just VPN and ad blockers. Some tools overlay data or intercept traffic in ways that can crash apps:
  • Screen filter / blue light filter apps
  • Floating bubble apps
  • Accessibility services that modify views
Try:
  1. Temporarily disable any screen filter, bubble messenger, or special overlay app.
  2. In system Accessibility settings, temporarily disable any third‑party accessibility service that is not essential.
  3. Open Tea App and go straight to blends.
If the crash goes away, something about the view hierarchy plus overlays is triggering an exception.
6. Treat Tea App as a product with tradeoffs
Since you mentioned Tea App specifically, it might help to think of it like any other product, with pros and cons.
Pros of Tea App (from how people typically use it):
  • Focused on tea blends instead of generic note‑taking, which makes browsing and saving blends feel natural.
  • Usually offers structured fields like temperature, steep time, ingredients and notes.
  • Syncs blends across devices, which is handy if you experiment a lot.
Cons of Tea App (especially relevant to your issue):
  • Appears sensitive to data corruption in accounts, where a single weird blend or image can crash core screens.
  • Crash handling seems weak: instead of failing gracefully on bad data, it exits entirely.
  • Updates sometimes change data formats without great migration logic, so upgraded installs hit more bugs than completely fresh ones.
If stability keeps being an issue, it can be useful to keep a backup log of your blends in a simple notes app or spreadsheet until you are sure the crashing is truly fixed.
7. Competitor & support comparison
Both @shizuka and @mike34 already covered a lot of solid angles: version checks, storage, locale, input quirks, network conditions. They clearly went broad. In contrast, I would push hard on:
  • Cross‑device test with the same account
  • Fresh install without automatic backup restore
  • Removing widgets, notifications, overlays
When you next contact Tea App support, send them:
  • Exact device & OS
  • App version
  • Whether it crashes on a new fresh install with backup restore disabled
  • Whether it also crashes with your account on a different device
  • Whether disabling widgets/notifications/overlays changes anything
If you reply here with that matrix (main device vs second device, with/without your account, with/without widgets/overlays), people can help narrow it down to either “your account data is poisoned” or “your particular device + OS + Tea App version combo has a specific bug.”
