Can someone help me restart my iPhone 17?
My iPhone 17 froze and the screen is not responding, so I can’t restart it the normal way. I need help with the correct steps to force restart or reboot an iPhone 17 so I can get it working again.
Force restart it like this:
  1. Press Volume Up, then let go.
  2. Press Volume Down, then let go.
  3. Press and hold the Side button.
  4. Keep holding until the Apple logo shows up.
Do it pretty fast on the first two buttons. The timing matters a bit. If you hold the Side button too early or too long before the sequence, it might not work.
If the screen stays black, plug it into power for 15 to 30 mins, then try again. If it still wont reboot, connect it to a Mac or PC and put it into recovery mode with the same button sequence, but keep holding the Side button after the Apple logo until you see the recovery screen.
For most newer iPhones, including the iPhone 17 line, this is the correct reboot method. If it froze from low storage or an iOS bug, it should start back up after this. If it keeps freezing, check storage space and update iOS after it turns on.
One extra thing besides what @nachtschatten said: if the phone is frozen because the touchscreen crashed but iOS is still sort of alive, give it a minute on a charger before assuming the force restart failed. Sometimes it looks totally dead when it’s just hung up hard.
Also, small disagreement here: I would not jump to recovery mode too fast unless the force restart fails multiple times. Recovery mode is more of a repair step, not the first thing I’d do.
What I’d check after it boots:
  • battery health / whether it was super drained
  • free storage, because near-full iPhones get weird
  • iOS update
  • app that was open when it froze
If it keeps doing this over and over, that’s when I’d suspect either corrupted iOS or hardware being flaky. If it won’t respond even after charging for a bit, try a different cable/brick too. Sounds basic, but yeah, it matters alot.
