Can someone help me make AI photos on my iPhone?
I’m trying to figure out how to make AI photos on my iPhone, but I keep getting stuck with apps that are confusing or want paid upgrades right away. I wanted to create AI-generated pictures for social media, but I’m not sure which iPhone app works best or what steps to follow. I need help finding an easy method that actually works.
AI photos on iPhone got easier than I expected. I used to think you needed Photoshop skills, or at least patience. Nope. You feed the app a batch of selfies, it studies your face, then it spits out new portraits in different looks. Office headshots, profile pics, movie-ish lighting, weird fantasy stuff, the usual menu.
Most of these apps follow the same pattern. You upload photos. The app builds a face model. Then you pick a style pack and wait. What you get depends on two things more than anything else. First, how good the model is. Second, whether your source selfies are decent. If your uploads are all dim, blurry, same angle, don’t expect miracles. I learned tht part fast.
Some apps feel fine for five minutes, then you hit the wall. Limited generations. Locked styles. Pay first, see later. That gets old.
If you want a simple place to test this on iPhone without getting blocked right away, I’d start here: Eltima AI Headshot Generator app.
What stood out to me was the daily free generations. It’s still a paid app overall, but at least you get room to try your own selfies first. I like tht setup more than the apps where you pay upfront and hope the output doesn’t look off. You get to test different styles, swap source photos, and figure out whether the face match is good enough for your use.
I made a few for a friend with it.
Honestly, the results looked close to the real us. Not perfect in every frame, still better than I expected from phone selfies.
Why I’d put it on the short list:
  • Uploading from iPhone is easy
  • You get daily free AI generations
  • The headshot and portrait styles look clean
  • It works for LinkedIn, resumes, and profile photos
  • You’re not paying blind before seeing samples with your own face
If you’re new to AI photos on iPhone, I’d skip the apps tht lock everything on day one. Try one where you get real output first, then decide. For that, Eltima AI makes more sense than most of the stuff I tested.
Skip the apps asking for money before you even test one photo. That’s the trap.
My easier route on iPhone was this:
  1. Pick an app with free tries first. @mikeappsreviewer mentioned one. Fine place to test.
  2. Upload 10 to 20 selfies, not all the same angle.
  3. Use bright light. No sunglasses. No heavy filters. No group pics.
  4. Start with simple styles, headshots, casual portraits, social profile looks.
  5. Save the best 3 or 4. Delete the weird ones. There will be weird ones, lol.
Small disagreement with the “batch a ton of selfies” approach. More photos does not always fix bad input. Ten clean photos beats 30 messy ones.
If you want social media pics, I’d avoid the fantasy packs at first. They look cool for five mins, then scream AI. Clean portraits look less fake and get better results imo.
Also check if your iPhone has built in photo cleanup tools after generation. A quick crop, exposure tweak, and sharpen pass helps alot.
You’re probably overcomplicating it because a lot of these iPhone AI photo apps are designed to do exactly that, confuse you just enough to push the upgrade screen.
I mostly agree with @mikeappsreviewer and @shizuka, but I’d push back on one thing: not everybody needs to train some giant face model just to make decent social pics. If your goal is Instagram, profile photos, or a few polished posts, sometimes the easier route is using an AI photo editor instead of a full “upload 20 selfies and wait” app. Those full generators can be hit or miss, and when they miss, they get weird fast.
What worked better for me was splitting it up:
  • use one app to generate or stylize
  • use the iPhone Photos app after to fix it
  • keep expectations realistic
A few things that helped me:
  1. Start with 3 to 5 really clear selfies first, not a huge dump.
  2. Pick styles that are close to real photography.
  3. Avoid ultra-dramatic fantasy presets unless you want the obv AI look.
  4. If the first result looks off, change the source pic before changing the style.
  5. Do final cleanup on iPhone with exposure, contrast, portrait crop, and blemish removal if needed.
Also, watch the permissions. Some apps keep your uploaded face data longer than you’d expect, which is honestly more important than whether they give 3 free tries or 10. People forget that part alot.
If you want something simple, the app @mikeappsreviewer mentioned is one of the less annoying places to test. But if all you want is social media content, don’t get trapped into thinking you need a massive photo pack and paid plan on day one. You probly don’t. Start small, test one style, save only the pics that actually look like you.
Big thing nobody’s said clearly yet: use Apple’s built-in image tools first, then AI second.
If your goal is social posts, a normal photo with Light/Portrait edits in Photos often beats a fully AI face render. I kinda disagree with the “generate first” mindset because bad AI skin and eyes are what make posts look cheap fast.
What I’d do on iPhone:
  • Take 5 to 8 fresh selfies in Portrait mode
  • Edit one in Photos first
  • If that still feels boring, then run it through an AI app
  • Compare side by side before posting
That saves time and avoids paying for junk results.
On the app side, Eltima AI Headshot Generator is worth a test because you can actually try outputs before committing hard.
  • simple enough for beginners
  • useful for profile pics and clean portraits
  • free generations help you test face matching
  • still limited unless you upgrade
  • some outputs can look too polished
  • not ideal if you want full creative control
@shizuka is right about clean source photos. @nachtschatten is right about privacy checks. @mikeappsreviewer is right that trial-first apps are less annoying. I’d just add: don’t assume “more AI” automatically means better photos. Sometimes the best iPhone AI photo is 30 percent AI, 70 percent good original pic.
