Can someone explain what an S3 bucket is and how it’s used?
I keep seeing people talk about Amazon S3 buckets for storing files, backups, and static websites, but I’m still not clear on what an S3 bucket actually is or how it works in practice. I’m trying to decide if I should use S3 for hosting assets and long-term storage, and I don’t want to make mistakes with setup, security, or costs. Can someone break down what an S3 bucket is, what it’s used for, and the basics I should know before using it in a real project?
If you strip away the cloud buzzwords, an S3 bucket is basically just a big container on the internet where you throw files. Photos, backups, app assets, logs, videos – whatever. You upload stuff there and it just sits safely in Amazon’s infrastructure until you need it.
S3 stands for Simple Storage Service and it’s part of Amazon Web Services. Instead of normal folders like on your computer, S3 stores things as objects – each file has the data itself plus some info about it (metadata) and a unique path called a key. In practice it feels like folders, but technically it’s a big flat storage system pretending to be organized.
Solo devs use it for backups or hosting files, and huge companies use it to store ridiculous amounts of data. Same tool, just different scale.
The good stuff
The biggest thing is scale. You can store 10 files or 10 billion and it doesn’t really care. You also get very high reliability because Amazon automatically keeps copies of your data across multiple locations.
Permissions are also very flexible – you can make something private, public, or only accessible to certain apps or users. And S3 connects to basically everything in the cloud world. In practice people use it for backups, static websites, storing images for apps, downloads, and media hosting.
Pay-for-what-you-use is nice too… if you understand the pricing.
The not-so-great stuff
Pricing is probably the most confusing part. You don’t just pay for storage – you also pay for requests and data transfer, and that surprises people.
The AWS web console works, but honestly it’s not beginner friendly. Permissions are another gotcha – it’s very possible to accidentally expose files if you don’t understand bucket policies (this has literally happened to big companies). Also there aren’t real folders, just filename prefixes, which can feel weird at first.
And yeah, if you just want Dropbox-style storage, S3 is probably overkill.
The native desktop experience
Officially you manage S3 through the browser console or the AWS Command Line Interface. The console is okay for occasional uploads, and the CLI is powerful if you like terminal workflows.
But there’s no official desktop app where your bucket just shows up like a normal drive. For Windows and Mac users that’s usually the moment where things start feeling awkward unless you grab a third-party tool.
A better way to work with S3 on desktop – CloudMounter
This is where something like CloudMounter makes life easier. It basically solves the “why can’t I just open my bucket like a normal folder?” problem.
It lets you mount your S3 bucket as a drive in File Explorer (Windows) or Finder (macOS), so you can drag, drop, rename, and delete files like you would locally. It also supports other services like Google Drive, Dropbox, and Microsoft OneDrive, which is nice if you’re juggling multiple clouds.
Other nice touches: it can encrypt files before upload, it’s pretty lightweight, and you don’t have to live inside the AWS console just to move a few files. Good middle ground if you want S3 power without living the AWS lifestyle full time.
MacBook users: level up with Commander One
If you’re on macOS and deal with lots of files or servers, Commander One is worth knowing about. It’s a dual-panel file manager, so you can see two locations at once and move stuff between them way faster than in Finder.
It also connects directly to S3, FTP, SFTP, and cloud accounts, handles ZIP files without extra apps, and has features like tabs, batch renaming, and keyboard shortcuts. There’s even root access if you need deeper system control. If Finder ever feels limiting, this is the kind of tool people graduate to.
Honestly, S3 buckets make a lot more sense once you stop thinking of them as “cloud magic” and just see them as very durable online storage. The tricky part isn’t uploading files – it’s figuring out the AWS way of doing things. Once you get past that, it’s a pretty useful tool to have in your stack.
Think of an S3 bucket as: a named container in AWS where you store “objects” instead of files on a disk. An object is file bytes plus metadata plus a unique key like backups/2026-03-18/db.sql.gz.
Some points that fill gaps from what @mikeappsreviewer wrote.
  1. What a bucket is in practice
  • It lives in one region, like us-east-1.
  • It has a unique name across all of AWS, like my-app-prod-files.
  • Inside it you put objects. No real folders. Only keys with prefixes.
  • The URL pattern often looks like:
    https://my-app-prod-files.s3.us-east-1.amazonaws.com/path/to/file.jpg
So when people say “put it in S3” they mean “upload as an object into a bucket and remember its key”.
  1. Common use cases and how they look day to day
a) App file storage
Your web or mobile app lets users upload stuff.
  • Frontend uploads to S3 using a pre signed URL.
  • Backend stores only the S3 key in the database.
  • When you need the file, you either:
    • Make it public behind CloudFront.
    • Or generate another pre signed URL to let the user download.
You do not store the file bytes in your app DB.
b) Backups
You run a job, for example with cron or CI.
  • Dump database to a file.
  • Compress and encrypt it.
  • Use AWS CLI or an SDK to upload to a bucket path like db-backups/prod/2026-03-18.sql.gz.
  • Set a lifecycle rule on the bucket:
    • After 30 days, move to cheaper storage.
    • After 365 days, delete.
So backups age out without you touching them.
c) Static website hosting
You can host HTML, CSS, JS, images from a bucket.
  • Turn on “Static website hosting” on the bucket.
  • Upload your index.html and assets.
  • Configure bucket policy to allow public read of only what you need.
  • Often you put CloudFront in front for TLS and caching.
This is fine for docs, marketing sites, small apps with client side JS.
  1. Access patterns and “how you talk to it”
You do not “log into the bucket”. You use:
  • HTTP API via SDKs (Node, Python, Go, whatever).
  • AWS CLI:
    • aws s3 cp ./local-file s3://my-bucket/path/file
    • aws s3 sync ./dist s3://my-bucket/site/
  • Third party tools.
For local desktop workflows, I disagree a bit with @mikeappsreviewer. I think the official console and CLI get annoying fast for non devs. Mounting storage as a drive helps a lot.
That is where CloudMounter is handy. It lets you:
  • Mount an S3 bucket in Finder or Explorer like a network drive.
  • Drag and drop files.
  • Optionally encrypt on the client side.
If you do a lot of manual uploads, reorganizing, or you share S3 with less technical teammates, CloudMounter smooths the daily work much more than the AWS console.
  1. When S3 makes sense for you
Use S3 if:
  • Your app needs to store user uploads.
  • You want automated backups from servers or databases.
  • You host static assets for a website or API.
  • You expect growth from GBs to TBs or more without rethinking disks.
Skip S3 as your main tool if:
  • You want folder sync, previews, collaboration, and are not coding against it.
  • You do not want to deal with IAM, access keys, or billing details.
  1. Quick checklist to decide
  • Are you writing code that needs to store and fetch files programmatically?
    S3 is a good fit.
  • Do you need high durability and you do not want to manage disks or RAID?
    S3 is a good fit.
  • Are you mostly on macOS or Windows and want it to “feel like a drive”?
    S3 plus CloudMounter is workable.
  • Are you a single user who wants something like Dropbox?
    S3 will feel like extra work and extra ways to make mistakes.
If you try S3, set this up from day one:
  • Buckets private by default.
  • One bucket per environment, like myapp-dev, myapp-prod.
  • AWS Budgets alert at a low number, even 10 or 20 dollars.
  • Tag buckets with project, env, owner so you know what is what later.
Think of an S3 bucket as “a named folder that lives in AWS data centers and speaks HTTP instead of USB.” Not perfect, but close enough for deciding if you should use it.
@​mikeappsreviewer and @​ombrasilente already covered the internals and the app-architecture side really well, so I’ll hit different angles and the “should I actually use this” bit.
What an S3 bucket really is
Conceptually:
  • A globally unique name: my-app-prod-files
  • Tied to one region: us-east-1, eu-central-1, etc.
  • Contains objects:
    • raw bytes (your file)
    • metadata (content-type, custom tags)
    • a key: backups/2026-03-18/db.sql.gz
That’s it. No disks to size, no servers to patch. You just throw objects at an API and they stay there.
The “no real folders” thing they mentioned is accurate, but in practice:
  • If you treat keys like paths (images/users/123/profile.png), all your tools, UIs, and CLIs behave close enough to folders that you stop caring about the internal flatness.
How you actually touch it, day to day
Where I slightly disagree with the others: if you’re not a CLI nerd or you often move stuff manually, the console and aws s3 get annoying fast.
Realistic workflows:
  1. Developer / script world
    • Use SDKs (Node, Python, etc.) or CLI:
      • aws s3 sync ./build s3://my-site/ to deploy a static site
    • Store only keys in your database, not files.
    • Nice when everything is automated.
  2. Human “I just want to drag files” world
    • This is where something like CloudMounter is actually a big quality-of-life upgrade:
      • Mount your S3 bucket so it appears like a network drive.
      • Drag and drop, rename, delete in Finder or File Explorer.
      • You can enable client-side encryption so AWS only sees encrypted blobs.
    • If you’re sharing S3 usage with non-dev teammates, this is way saner than walking them through IAM, bucket policies, and the awful “public access” UI.
So:
  • If your usage is mostly “scripts and apps,” console + CLI are fine.
  • If your usage is “humans throwing files around,” S3 + CloudMounter feels much closer to Google Drive while still being infrastructure-grade.
What it’s good for vs what it sucks at
Great use cases:
  • App file storage (user uploads, avatars, PDFs)
  • Backups (DB dumps, server tarballs)
  • Logs / analytics data
  • Static websites & static assets (HTML/CSS/JS, images)
  • “Store this for years and don’t lose it”
Bad or awkward use cases:
  • Syncing working documents between laptops with pretty previews and comments
    → just use Google Drive / Dropbox / iCloud
  • Super low latency, “acts exactly like a local disk” database files
    → EBS / EFS or an actual DB, not S3
  • If you hate reading pricing pages or thinking about permissions at all
    → you’ll eventually get burned by either cost or a too-open bucket
How to decide if you should use it
Ask yourself:
  1. Am I writing or running anything that can call an HTTP API or CLI?
    • Yes → S3 fits nicely.
    • No → a consumer cloud drive is probably easier.
  2. Do I care about durability and not managing disks?
    • If the answer is “I cannot lose this,” S3 is very good at that.
  3. Will this grow past a few dozen GB?
    • S3 shines as you scale. Self hosting or random VPS storage starts to look worse once you hit hundreds of GB or TB.
  4. Do I need other AWS things later (CloudFront, Lambda, Athena)?
    • If that’s even a maybe, using S3 keeps you compatible with the rest of the ecosystem.
If you do try it:
  • Keep buckets private by default.
  • Only make specific paths public if you’re hosting a site.
  • Set up a small budget alert so a buggy script does not surprise-bill you.
  • If you’re doing a lot of manual file juggling, seriously consider pairing it with CloudMounter so S3 behaves more like a normal drive and less like “weird enterprisey web UI hell.”
TL;DR: an S3 bucket is “Internet storage with an API” that scales almost without you thinking. Great if you have code or automated jobs touching files, overkill and slightly hostile if all you want is a nicer Dropbox.
Think of S3 buckets as “remote folders with superpowers,” and then ask: do you actually need those superpowers or just a nicer Dropbox?
Where I differ a bit from @ombrasilente, @nachtschatten and @mikeappsreviewer is the workflow angle. Architecturally they’re spot on: buckets, objects, keys, regions, static hosting, backups, all that. The real decision for you is how you plan to touch those files day to day.
When S3 is a good fit for you
  • You’re building an app that stores user uploads, or you want scripted backups.
  • You like the idea of “store it once, forget about disks, it just survives hardware failures.”
  • You might later plug in CDN, serverless, analytics, etc.
In that world, your app or scripts are the primary users of S3, not you dragging files around manually. The bucket is just an HTTP-accessible file store.
When S3 feels painful
  • Your workflow is “I open a folder and drag PDFs around.”
  • Non technical teammates need to rename, move, preview files.
  • You have no patience for IAM, access keys, or weird AWS error messages.
The AWS console is clunky for that. The CLI is powerful but not friendly for casual use. This is where tools on top matter more than S3 itself.
Where CloudMounter fits
If you do go with S3 but still want it to “feel” like normal storage:
  • Mounts S3 as a network drive, so it shows up in Finder / Explorer.
  • Drag and drop, copy, rename like any other folder.
  • Client side encryption makes it easier to stay safe by default.
  • Also handles other clouds, so you get one UI for multiple services.
  • Another tool to install, manage and pay for.
  • Still need to understand AWS permissions enough to avoid public buckets.
  • Not ideal if your usage is 99 percent automated; in that case the CLI or SDKs are cleaner.
Competitors exist both in the “explain S3” space (like what @ombrasilente, @nachtschatten and @mikeappsreviewer are doing here) and in the “mount cloud storage” space, but the idea is the same: S3 gives you raw infrastructure, and something like CloudMounter gives you a human friendly front end.
If your main question is “should I use S3 at all,” use this rough rule:
  • Mainly code and cron jobs touching files → S3 is a solid choice.
  • Mainly humans dragging files, no real need for automation or scale → stick to a consumer cloud, or pair S3 with CloudMounter so you do not hate your life.
