How Can I Recover Data From My Mac Hard Drive?
My Mac hard drive suddenly stopped working, and I can’t access important files, photos, and documents. I’m looking for safe Mac hard drive data recovery options or software before I risk losing anything permanently.
First thing: stop using that drive as much as you can. Missing files on a Mac are not always gone for good, but the more you use the drive, the more you risk overwriting whatever is still recoverable.
When macOS deletes something or a drive gets formatted, it often just marks that space as free. The actual data may still be sitting there until something new gets written over it. So avoid downloading anything, installing apps, copying files, or doing much browsing on that Mac. If it’s an external drive, unplug it for now. If it’s the internal drive, keep activity to a minimum.
Check the easy stuff before running recovery tools. Look in the Trash first. If the missing files were on an external drive, that drive may have its own hidden trash folder. Plug it in, open it in Finder, then press Shift + Command + Period to show hidden files. Look for a folder called .Trashes. If the files are in there, right-click them and choose “Put Back.”
Also check Time Machine if it was turned on before the files disappeared. Open Time Machine from the menu bar, go back to a point where the files were still there, select them, and hit “Restore.”
If there’s no Trash copy and no backup, then recovery software is usually the next reasonable step. Something like Disk Drill can scan Mac drives formatted as APFS or HFS+ and may still find files even if the folder names or original filenames are gone.
The better recovery tools usually do more than read the file directory. They can deep scan for file signatures, which means they look for patterns inside common file types like photos, videos, documents, and archives. If the drive seems flaky, slow, or keeps disconnecting, don’t keep hammering it with scans. Make a byte-for-byte image first if you can, then scan the image instead of the physical drive.
Internal SSDs are trickier. Many newer SSDs use TRIM, which can clear deleted blocks automatically. Once that happens, normal recovery software may have nothing left to recover. That’s another reason to stop using the Mac right away if the deleted files were on the internal drive.
If the drive is making clicking, grinding, repeated spin-up sounds, or any other weird mechanical noise, skip the software route. Unplug it. Recovery apps can’t fix physical damage and may make things worse. If the files matter enough, that’s when a professional recovery service makes more sense.
After you get through this, set up backups so you’re not stuck in the same situation again. Time Machine is fine for a local backup, and a reputable cloud backup gives you a second copy somewhere else. For now, the order I’d follow is: stop writing to the drive, check Trash and Time Machine, then recover from another drive or from a disk image if needed. I’ve been in this kind of panic before, and careful handling really does matter.
Pick a separate drive for the recovered files before you scan anything. A lot of people miss that part and then save the “rescued” photos right back onto the problem disk, which can overwrite more recoverable data. If the Mac still sees the drive, I’d mount it read-only if possible, run First Aid only if you’re trying to repair the volume and not recover deleted files, and use a recovery app like Disk Drill from another Mac or another boot drive. If the drive does not show up in Disk Utility at all, or it appears and disappears, I would stop there and treat it as a hardware problem rather than a software job.
The hidden catch with a lot of Mac recovery advice is that it assumes the drive is readable long enough to scan, and that is not always true. If the drive is slowing down, freezing Finder, or making the whole Mac beachball, every “just try another scan” attempt can waste the limited time the drive has left.
Before buying or running anything, I’d separate this into two cases. If the Mac boots and the drive mounts normally, then software recovery is reasonable. Use another Mac or boot drive if possible, save results somewhere else, and preview files before paying if the app allows it. Disk Drill is one of the common options, but I would treat it like a scanner, not a repair tool. Don’t let it “fix” the problem disk first if your goal is file recovery.
If the Mac itself is dead or the internal drive is involved, check whether FileVault was enabled and what model Mac it is. On many newer Macs, the internal storage is tied closely to the machine, so the old trick of pulling the drive and putting it in a USB enclosure may not apply. In that case your Apple ID, login password, recovery key, Time Machine backup, or iCloud Desktop/Documents sync might matter more than the recovery app. For an external drive, I’d try a different cable, port, and powered enclosure before assuming the disk is gone. For an internal SSD that vanished completely, I’d stop experimenting pretty quickly and decide whether the files are worth a professional quote.
The hidden downside with recovery software is that a “found 80,000 files” result does not mean you’ll get back a neat folder full of usable stuff. A deep scan may recover a pile of JPGs, PDFs, and videos with random names, duplicates, damaged previews, and no original folder structure. That’s still better than nothing, but set your expectations before spending hours on it.
I’d be more cautious about First Aid than some Mac guides suggest. If the data matters, copy or image the drive first, then try repairs later. First Aid can be helpful when you only care about making the volume mount again, but it can also change the file system. That’s not what you want if the directory is already damaged and you’re trying to recover files.
For a practical order, I’d do this: check whether the drive shows up in Disk Utility at all, even if it doesn’t mount. If it shows there, recover to a different disk with plenty of space. Disk Drill is fine to try as a scanner, especially if it lets you preview files first, but don’t install it onto the same drive you’re trying to recover from. If the drive doesn’t appear in Disk Utility, System Information, or a different enclosure/cable setup, software probably isn’t your next step. At that point it’s either backups, iCloud/Time Machine, or a recovery lab if the files are worth the bill.
